#141 (permalink) | |
Legend in my own mind
CRC Mass Air Flow Sensor Cleaner?
What are your thoughts on using CRC Mass Air Flow Sensor Cleaner? I've used their products in the past (brake cleaner, carb cleaner etc...) with no issues. CRC Industries Global Home Thanks, Mike
06 ST Elise 02 SLK32 AMG BWR Supercharged w/CharlieX tune, Borla Exhaust, OCC, ACT XTSS Clutch, Zeitronix A/F Meter, LETSLA, Manly Mounts, RTD Brace, ReVerie Diffuser, Scoops, Side Skirts, & Shifter Ball, Forcefed Spoiler, & a bunch of other stuff |
#142 (permalink) |
I haven't started my install because I'm adding a few gagues first. Just trying to get a base line. Does anyone know if PES can remove the second o2 sensor from the ecu program? I would like to use that bung for my afr gauge.
Thanks, Gene |
#143 (permalink) | |
2009 XP National Champion
![]() Join Date: Oct 2003
I don't know as I haven't used them. You can try it but you should get a scan tool and check the calibration afterwards. Additionally, you should check it a while down the road and see if any long-term damage has been done. If it is off, I would spend the money and replace it. Too much $$$ in the car to risk it in my mind.
#144 (permalink) | |
They cannot. This may be something that CharlieX offers, however. You can find him at Temporary goth.am webstore - excuse our dust!
#145 (permalink) | |
Rotary Refugee
#146 (permalink) |
I approve this message
I was wondering the same thing about the MAF cleaner. I have a can sitting in my garage but am somewhat scared to use it.
Murix - Have you used it on the Lotus MAF?
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934# 2004 s2000 - 378 whp 295 trq 2005 Mini Cooper S 2008 Honda Fit - 35mpg y0! 1965 Austin Mini w/ vtec |
#147 (permalink) | |
Mike
#148 (permalink) | |
Exactly. Let me be clear: Lots of YOUR cash to replace an engine! ![]()
#149 (permalink) |
Hope it never comes to that. BTW, S/C runs like a champ!
#150 (permalink) | |
Rotary Refugee
YMMV, but I have no problem with cleaning it and consider it routine maintenance out in Cali's dusty climate. |
#151 (permalink) |
Live to Drive
Apparently mine was so filthy that I was being fed only about 150 g/second as opposed to the normal 220-250 g/second. Needless to say, PES replaced mine...LOL
Be an alpha male. Drive a Lotus. |
#153 (permalink) |
Started install over the weekend
Everything is coming along well without taking off the clam. I have one problem with the kit so far, it's cutting the harness to put the injector connectors. Why not just unpin the stock one's, so your not cutting the harness. The one for the alternator is a little bite harder but it should be soldiered not just clamped and heat shrinked. Is everyone cutting them?
#155 (permalink) |
Just as an FYI, connections on vehicles are rarely soldered. Soldering a wire to something creates a very sharp stress concentration right at the point where the wire enters the solder pocket. If you do solder, make sure the solder is not providing the mechanical support for the wire.
What I was planning on doing was attaching male spade connectors to the wires and just plugging them into the stock plugs. I haven't done my install yet so there may be a reason this is not possible or desired.
2007 Ardent Red Elise, track pack, BWR SC 2004 RX-8, 350z muncher 2004 BMW 325i, kiddie hauler |
#156 (permalink) | |
#158 (permalink) | |
Try disconnecting the battery. While battery disconnected, disconnect & reconnect the ECU. Reconnect battery. Disarm, arm, and disarm the alarm.
#159 (permalink) |
vv My Awesome Wife vv
Fred-
Is it possible to remove the air conditioner unit for good during this install?
2005 SY-BWR Supercharger, Challenger Grill, AreaP single tip exhaust, Ohlin Double Adjustables, RTDbrace, Custom Kirkey 58 Series seats, Schroth 6 pt. harnesses, Multivex mirrors, Odyssey PC625 battery, Micromirror, HID's, V2arms, Sparco removeable steering wheel, 15"/16" Rota's with RA-1's, Pagid RS 4-2 pads, Cup airbox, Saikou Michi catch cans |
#160 (permalink) |
How much hp increase should we expect from this aftermarket BWR s/c? The stock Elise SC says 218, up 29 hp from the stock Elise. Should we be getting more than that?
2005 Solar Yellow Elise touring package, star shield, hard top, soft top, ACT HDSS clutch, Saikou Michi catch cans, LED tail lights and VF II, 288 whp ( )2001 Green Toyota Tacoma, 4 x 4 2008 Red 5455 Massey Ferguson, 6 x 6, cab, ipod, GPS navigation, regular beer holder 2001 Yellow Cat D3G-LGP, custom made beer holder |
