Old 10-14-2008, 07:29 PM   #161 (permalink)
I just called your Mom
snuggles1's Avatar
ummm, didnt u go to the BWR site? and click on the dyno chart?
2002 Brian Moore C55 >> 2002 Ibanez AR250 with Gibson Burstbuckers >> 2001 Taylor Grand Auditorium >> 2000 Les Paul Custom 3 pickup >> 1998 Brian Moore C90 >> SRF chassis 543 >> 1976 Rickenbacker 4001 >> 1972 Fender Telecaster >> 1939 Gibson Archtop
snuggles1 is offline   Reply With Quote
Old 10-14-2008, 08:08 PM   #162 (permalink)
Live to Drive
Bavarian Motorist's Avatar
This will be quite a bit faster than an Elise SC.
Old 10-14-2008, 10:04 PM   #163 (permalink)
Phantom's Avatar
Images: 1
FYI:
Step 77 - There's a bracket attached to the bottom of the TB in addition to the four 12 mm nuts*
*2006 Elise
Grab Life by the Wheel
Phantom is offline   Reply With Quote
Old 10-14-2008, 10:10 PM   #164 (permalink)
thegoat's Avatar
I agree with that - 2006 exige.
2009 White w/ Carbon Birkin Super 7 (on order)
2001 Silver Honda Civic Ex (daily driver)
2006 Polar Blue Exige - Sold
2006 Chrome Orange Elise - Sold
2000 Porsche Boxster - Sold
thegoat is offline   Reply With Quote
Old 10-14-2008, 11:26 PM   #165 (permalink)
srw
srwhitman's Avatar
for the install challenged
Got my car back today from ForceFed. They did an awesome job. I am trying to baby it for the first 100 miles (now Fred says "few hundred"). I am up to 50 miles or so but babying it is hard. I am a little concerned about this MAS issue but since I didn't do the install, I don't know where to look for it much less how to verify its reading. Any help would be appreciated.
Scott
srwhitman is offline   Reply With Quote
Old 10-15-2008, 01:33 AM   #166 (permalink)
without a Lotus
FLuXeXigeS's Avatar
so how many has successfully installed their SC?
anyone in SoCal?!?
-Coi- currently having Lotus withdrawals
Facebook | Twitter | Pics | Vids
eBay Store
FLuXeXigeS is offline   Reply With Quote
Old 10-15-2008, 04:32 AM   #167 (permalink)
gtlotus's Avatar
Thanks! Fred about the o2 delete.
Gene
gtlotus is offline   Reply With Quote
Old 10-15-2008, 04:45 AM   #168 (permalink)
Doublklutch
Brikhaus's Avatar
anyone in SoCal?!?
Mine is working awesome - installed by EU Autowerks in Toronto
2007 Elise, British Racing Green, Biscuit, BWR SC , PES Reflash, TP, TC, Stage II, Star Shield, soft top.
2006 Audi A3, 3.2, "S" Line, Quattro,
Brikhaus is offline   Reply With Quote
Old 10-15-2008, 06:02 AM   #169 (permalink)
2009 XP National Champion
fzust's Avatar
Scott
I think it likely requires less than a couple hundred, just trying to be safe. You want to hit alot of different load sites so gradually get into it. I am concerned about the MAS issue too, as the one we took out of Bavarian Motorists's looked like someone dipped it in crud. I am going to call FF today and make sure they test the flow rate on any new ones.
Old 10-15-2008, 06:19 AM   #170 (permalink)
Yahoo! Got my Rotus!
dma550's Avatar
Originally Posted by architect View Post
everying is installed. but won't crank over. BWR kit . Acts like the security system is opperating. Interesting note, the fuel gauge reads emty, but the tank is full.
HELP!
This happened last time my battery went dead. Isn't the interior light position important to the security arming (or is this an urban legend).
If it is what happened to me, there isn’t even a starter motor click, right?
David Avery
05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE
08 BMW 135i Stock
visit Spyderclub.com
dma550 is offline   Reply With Quote
Old 10-15-2008, 06:56 AM   #171 (permalink)
ishur's Avatar
Fred:
I will be getting my car back from FVMC tomorrow. Can you be a little more specific on the "re-break-in"--are you basically saying do it like the first 600 miles on the stock car (except only for maybe 100-200 miles), i.e., mostly half throttle or less with occasional bursts of WOT, and nothing above 6000 rpm or so?
Just want to make sure I treat it right.
ishur is offline   Reply With Quote
Old 10-15-2008, 07:01 AM   #172 (permalink)
thegoat's Avatar
Scott
The MAF is attached to the side of the airbox. I don't have the instructions in front of me, but when you get to the point of removing the airbox (around 80ish) it will first have you unclip the MAF. There is a corresponding picture. Once the MAF is unhooked, you just unscrew the two little phillips-headed screws holding the MAF to the side of the airbox.
Old 10-15-2008, 08:06 AM   #173 (permalink)
fzust's Avatar
Scott
From post #106(bears repeating...)
Additionally, we've done extensive testing and I want to point out something we've discovered. It is CRITICAL that anyone installing ANY supercharger kit inspect & test and/or replace their mass-air sensor element. We've seen that the mass air sensor element can get very dirty(remember in the lotus much dirtier air hits the intake than a car with a front intake.) and this dirt will cause the mass-air sensor to read low(Its a fairly linear change). Aftermarket intakes, higher mileage cars, and cars operated in dustier or dirtier conditions are even more prone to this.
This will cause the ECU to think more air is entering the engine than reality you will have a potentially dangerous lean condition!
You can test the mass-air sensor with a scan tool by having someone monitoring the mass-air sensor while you drive WOT in second gear. You should see ~5grams/sec at idle and 225-230grams/sec at above 8200rpms. If you see much less than this you should replace your mass-air sensor element. These new mass-air elements may not survive harsh chemical cleaning and should just be replaced.
Since this time, others have apparently successfully cleaned the MAF. I would still recommending to replace it to be safe.
Old 10-15-2008, 08:07 AM   #174 (permalink)
architect's Avatar
Correct, just acts as if the security system has it disabled. I've had a dead / removed battery before, but never this issue. Fred had me send the ECU back. As to the legend??????
architect is offline   Reply With Quote
Old 10-15-2008, 08:10 AM   #175 (permalink)
fzust's Avatar
Originally Posted by ishur View Post
Fred:
Make sure they test the MAS air! per the instructions in the post above! As far as break in, a couple hundred miles of moderate driving getting a bit more aggressive as you go. See post #100 from CharlieX(re-posted here for convenience)
add to what fred says
drive the car all over the range, lik you're breaking it in, idle 15 minutes, dont drive at a constant speed/throttle/load for 60 minutes and think it'll be done, it has to vary to each breakpoint on the map, if you have an ecu with a prior adaption it'll start further off and take slightly longer to settle.
in the meantime you might see some off throttle stalling, this isn't an uncommon thing with the cars, (excessive stalling points to vacuum or exhaust leaks )
if you think you're getting any knock you can run higher octane gas till it settles down, if you mix octanes you'd need at least half a tank of each to make a difference, the more of the higher octane , the better.
also if you do get lumpy idles, check the short term fuel trims, if they're excessively negative -12 or worse, look for vacuum leaks, positive look for exhaust leaks.
you're looking for best 0-4, typical -4 to 4
easiest way to pinpoint intake leaks is with a hose pipe and a LIGHT stream of water, don't go powerwashing it, the engine will hestitate when you hit the right spot, you can use contact cleaner or such and spray it around the engine bay, however it can be harder to find the leak and some of that stuff is corrosive.
exhaust leaks are usually pretty easy to find, cat, or the clips.
i'd say 90% of the install problems i've heard about fall into the vacuum leak type, the rest have been trapped wires, incorrect seating of the injectors (those rubber o rings ought to be changed at install, they're cheap from toyota), reversed wiring (check and recheck) .
the injectors are a common place for leaks too, i've seen it where they leak and they don't spray fuel, though i've seen that too, up close!
obviously theres different types of detonation, if its heavy det, then you definitely want to switch to higher octane or look into it, i'm talking about mild barely noticeable stuff , which should happen 4500 - 5800 rpm give or take.
Old 10-15-2008, 08:31 AM   #176 (permalink)
fzust's Avatar
Fred:
Ishur,
I called FVMC a moment ago and spoke to the service manager and told him what to look for and do for the MAS. Make sure you ask them if they tested it etc. when you pick it up. Have fun!
Old 10-15-2008, 08:37 AM   #177 (permalink)
I approve this message
skibum's Avatar
Will one of the rental scan tools from Checker read the MAF? Also, I did not see anything in regards to spark plug gapping. DO we need to tighten up that gap at all?
Fred/BWR - I am only 1/2 way thru the install but I must commend you on what an amazing kit this is. I have done 4-5 other forced induction kit installs and none of them are even close in comparison. From the detailed instructions, photos, support, and the "all-inclusive" approach, it takes the cake. Thank you and I can't wait to turn it over tonight.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934#
2004 s2000 - 378 whp 295 trq
2005 Mini Cooper S
2008 Honda Fit - 35mpg y0!
1965 Austin Mini w/ vtec
skibum is offline   Reply With Quote
Old 10-15-2008, 08:54 AM   #178 (permalink)
fzust's Avatar
First of all Thanks! The manual was a huge effort, however, I've done turbo installs on my old M3 and the manual just sucked. I was determined that would not be the case here.
For the plugs, you do not need to tighten the gapping. The car has no trouble firing through it. I run the stock gapping on the XP car with 14psi, 750cc injectors and 108Octane gas with no trouble. Coil on plug is a good thing! 1 heat range cooler as recommended before is suggested.
Old 10-15-2008, 10:09 AM   #179 (permalink)
Pb Foot
rudaire's Avatar
The dirty element must cause the ECU to think LESS air is entering the engine, which indeed would cause a lean condition.. If the ECU thought more air was entering than in reality, it would then inject more fuel for this erroneously large quantity of air, and you'd have a rich condition..
cheers..
d
"What now? Let me tell you what now..."
06 Audi S4 25Quattro car #100 of 250
06 Lotus Elise
rudaire is offline   Reply With Quote
Old 10-15-2008, 10:23 AM   #180 (permalink)
ishur's Avatar
Ishur,
Thanks, Fred, and also for your break-in answer. I had actually emailed FVMC with your original post on the MAS the other day, and they said they would make sure to test it. My car is an 07 with only 2500 miles on it, so it may be fine.
