Old 06-22-2009, 07:36 AM   #1 (permalink)
GR8 SCAPE
waydui's Avatar
Oil Leak - SC Related
I've had the BWR SC in for a couple of weeks now and noticed oil drips on the undertray. I've never had an oil issues with the engine before.
I've traced the origin to the upper part of the engine, around the Oil Control Valve area, which mounts into the head. Not a big leak, just slow accumulation. No codes, no CELs, car runs fine. All the bolts, nuts, etc. are tight.
Anybody else have a similar experience? Any ideas would be appreciated. Thanks
Regards,
Wayne
_______________________
Old 06-29-2009, 01:31 PM   #2 (permalink)
exlondoner's Avatar
Wayne, this is a shot in the dark but did you also check the dipstick tube to see if it was seated in correctly, might be a possibility that it moved?
Mick
Regards,
Wayne
exlondoner is offline   Reply With Quote
Old 06-29-2009, 01:35 PM   #3 (permalink)
GR8 SCAPE
waydui's Avatar
Hi Mick,
Yeah, I re-checked that too. I put a new O-ring on it and it's tight, so no leak.
I did find that the bolt on the Oil Control Valve was a little loose. Tightened that up and so far no more oil!!
Thanks for getting back to me on this.
I guess you're just waiting on the ECU to get rolling?
Regards,
Wayne
Old 06-30-2009, 06:35 AM   #4 (permalink)
exlondoner's Avatar
AThats great glad you got that figured out. Yep just need to send of the ECU and pick-up a new air filter and spark plugs.
Fingers crossed.
Hi Mick,
Regards,
Wayne
Old 06-30-2009, 09:03 AM   #5 (permalink)
luxige
luxige's Avatar
Which tune are you going with Mick?
luxige is offline   Reply With Quote
Old 07-01-2009, 08:37 AM   #6 (permalink)
exlondoner's Avatar
Greg I'm going to go ahead with the PES tune since it's cheaper - I'm not sure if either is better than the other.
