Old 11-07-2007, 01:43 PM   #1 (permalink)
overrev
What type of damage would realistically be caused if a downshift caused a mechanical overrev to 13,000 rpm?
Could the car survive and be driveable...with no apparent damage? Or would some apparent, and likely catastrophic damage in the drivetrain be inevitable?
slipstream is offline   Reply With Quote
Old 11-07-2007, 01:44 PM   #2 (permalink)
13K RPM??? What car is that? Hope not the Elise!!
mcoupe is offline   Reply With Quote
Old 11-07-2007, 01:45 PM   #3 (permalink)
Originally Posted by mcoupe View Post
13K RPM??? What is that? Hope not the Elise!!
Yeah, in an Elise.
Looking for considered answers. Is it feasible the car would survive and virtually no damage apparent, or would serious damage be inevitable?
Old 11-07-2007, 01:46 PM   #4 (permalink)
El Jefe - Agent 111
Randy Chase's Avatar
Images: 761
Probably kill the engine. It could depend on how long it happened.
We have been feeling the buzz since 2002
2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds.
..is a stranger in an open car. Tempt you in and drive you far away
Old 11-07-2007, 01:53 PM   #5 (permalink)
exarkun1178's Avatar
9880is the rpm that the stuff inside on the bottom starts hitting the stuff inside on top.
so 13000 umm your going to have problems!
exarkun1178 is online now   Reply With Quote
Old 11-07-2007, 01:57 PM   #6 (permalink)
Nathan's Avatar
I'm no mechanic... but Id assume no instant catastrophic damage, however I would have the engine "freshened up" and checked out by a mechanic. I'm guessing valves would be the thing to check? Overtime severe damage would occur
Nathan is offline   Reply With Quote
Old 11-07-2007, 02:00 PM   #7 (permalink)
I'd imagine that instantly going to 13K through downshift would also put the transmission at risk as well?
Old 11-07-2007, 02:08 PM   #8 (permalink)
Clearly that's a calculated overrev since the tach doesn't go that high. That's about 100mph in second gear. If you slipped it into gear and let out the clutch and realized you missed the shift, it is likely that it never hit 13K rpm as you probably jammed the clutch right back in. That's my sense of what might have happened.
So tell us, what happened?
RegGuy is offline   Reply With Quote
Old 11-07-2007, 02:13 PM   #9 (permalink)
short angry bloke
codymac's Avatar
Images: 19
13k? Oil pump would likely break up.
Old 11-07-2007, 02:20 PM   #10 (permalink)
TimMullen's Avatar
Images: 19
What others are alluding to is that at that high of a RPM, the valves are likely to "float" - that means that the valve is opened so rapidly by the cam that when the cam has continued to rotate (and is no longer pushing the valve open) the momentum of the valve has continued to cause it to open. The springs do not exert enough force to close the valve rapidly enough. A litle bit of "float" is bad because the valve "slams" shut under spring pressure and can damage the valve seats.
Higher amounts of valve "float" causes more problems by keeping the valve in the area swept by the piston's movement for too long - the valves often open into the area of the cylinder where the piston will occupy when the piston is "up", but the with careful timing the valves will open when the piston is "down" and close when the piston is "up". Servere valve float can cause the pistons to hit the valves. Light "hits" can cause the valve(s) to be slightly bent, keeping them from sealing tightly. Heavy "hits" can cause the valves to bend enough that they can't close (get jammed in place).
At this point, the valves will break or you will get holes in the pistons.
"Light" hits will make the engine run a little rougher. Heavy hits. will make the engine stop completely.
If you are lucky, you didn't get any hits...
94 Miata R Package - Black
Old 11-07-2007, 02:21 PM   #11 (permalink)
gas, gas, gas, gas
choi0706's Avatar
Originally Posted by codymac View Post
13k? Oil pump would be likely break up.
+1
2zzge has a very weak oil pump.. if you rebuild you're engine get the circuitworx pump..
Jay-05' ST, HT, Touring Red
I have a theory that all....
Katana flags 9
VF flag 1
choi0706 is online now   Reply With Quote
Old 01-08-2008, 07:30 PM   #12 (permalink)
update
Ok, not that anyone is still interested, but here's the story.
ECU dump at last service said 13027 RPM as highest RPM. All others embarassingly low.
Looked at highest speed on the ECU dump, did some calculations, and the only way the 13027 rpm could've happened was a mechanical overrev caused by a downshift into first gear at about 68 mph.
That never happened while I drove/owned the car.
So I told my dealer something was wrong with the ECU dump. Dealer contacted Lotus Cars USA, who got the regional Lotus engineer involved. He investigated, contacted the engineers at Hethel, and they acknowledged that in the 06 cars the specific rev of 13027 was an anomoly that showed up in ECU from time to time, and in no way reflected an actual over rev.
Lotus stepped up, and Lotus USA and Lotus Hethel provided written documentation indicating this was not an actual over rev, and that power train warranty is fully intact.
This could've easily gone the other way. They could've written my car off as one they need not support under warranty. Great follow up, fair, good documentation.
Thanks to Lotus USA and Lotus Hethel, and my dealer for the investigation, follow through, and resulting documentation.
Old 01-08-2008, 07:49 PM   #13 (permalink)
disproving HD MTBF daily
charliex's Avatar
yeah i have a bench ecu i run at 13,000 RPM+ i notice the ecu will reset at around 13K so any reading like that must be invalid.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it.
Old 01-09-2008, 06:57 AM   #14 (permalink)
Boosted2.0's Avatar
at 13K you will bend at least all the exhaust valves (probably the intakes too). You will also shatter the oil pump gear. You MIGHT also do any or all of the following:
Introduce a connecting rod or two to daylight
explode the clutch disc
Snap off valve heads
break valve guides
Put peices of valves through pistons
Put peices of valve and piston back into the intake manifold or exhaust
This is not conjecture. This is based on observation of a LOT of over-revved 2ZZs back before the shift pattern was updated on the Celica.
Boosted2.0 is offline   Reply With Quote
Old 01-09-2008, 08:41 AM   #15 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
My 2006 ECM also had the 13027 rpm logged. Was assured by LCU that this is an anomaly.
The oil pump will definitely grenade itself with one quick excursion over 10K rpm. The crank pulley / balancer is known to crack shortly thereafter, and valve train damage can't be far away. By the time you got to 13K rpm I'm quite certain conrods would break too. The whole engine would be completely FUBARed.
xtn
Old 01-09-2008, 08:57 AM   #16 (permalink)
Mikey likes it!
insane's Avatar
Cool
break valve guides
Don't forget the electrical problem....
you know, the one whrere the piston rod coming throught the side of the engine knocks the alternator clean off its bracket.
-Michael
'05 Nighfall Blue with Rallye Stripes!
insane is offline   Reply With Quote
Old 01-09-2008, 10:18 AM   #17 (permalink)
Service animal
dbisbee's Avatar
Thanks!
The word "PASSION" should aways be uppercase.
#349 '05 AS Elise Touring, Hardtop, Starshield, GPS, V1, V1 mirror, Leather console, Multivex, JL stealthbox, Focals, HID, RAC Monolites, A048's, Stage II, Slotted rotors, R4-S pads and Odyssey 925.
Dad had a Europa TwinCam JPS
dbisbee is offline   Reply With Quote
Old 01-09-2008, 12:31 PM   #18 (permalink)
Boosted2.0's Avatar
All depends on which rod and which side it comes out
Old 01-09-2008, 12:51 PM   #19 (permalink)
xtn
xtn's Avatar
At 13K rpm they will ALL come out. Well, except for the one that comes out first will presumably stop the engine's rotation in a turn or two, possibly saving the rest?
Old 01-09-2008, 02:36 PM   #20 (permalink)
Hello Kitty's Avatar
There is another thread here at elisetalk where someone had catastrophic engine damage from a downshift that took him to 10,000
Hello Kitty is online now   Reply With Quote
HTML code is On
