Old 09-26-2008, 02:56 PM   #1 (permalink)
DENNAB
Stale_Hotdog's Avatar
Question about afr's lambda and wideband sensor
What are normal afr's for a lotus with forced induction?
Stale_Hotdog is offline   Reply With Quote
Old 09-26-2008, 03:08 PM   #2 (permalink)
2007 Exige S
robains's Avatar
I've not heard of Zeitronix?? Got a web site? NGK and Bosch seem popular wideband sensors. Did you calibrate it? Is it hooked up to anything that data logs so you can review?
11.5 - 12.5
Hopefully Kris or Phil and/or others with a lot of experience will chime in.
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." - Carl Sagan
Old 09-26-2008, 03:24 PM   #3 (permalink)
Images: 17
It's normal that it jumps all over when you step/release gas pedal.
Solo2Elise is offline   Reply With Quote
Old 09-26-2008, 05:58 PM   #4 (permalink)
DENNAB
Wide Band Air Fuel Ratio Meter is where I purchased it from. I saw two members who used this setup however one is on a turbo car and the other was on an evo. Calibrate it? I don't see that in the instructions.
Old 10-02-2008, 10:14 PM   #5 (permalink)
2007 Exige S
robains's Avatar
The one I have (which I believe is the same as TurboPhil) NGK wideband has a button on the display box to calibrate. basically hold the sensor up in the air, hit the button and wait for Cali to complete.
Old 10-03-2008, 06:04 AM   #6 (permalink)
Big head man
slaughtr's Avatar
Images: 3
I'd also like to see a brief turorial. I know it's going to go up and down under different loads, but it would be nice to hear a concise opinion. Timing tips would also be appreciated.
Kris or Phil?
My car both sucks and blows.
Now with added all natural smoky goodness!
slaughtr is offline   Reply With Quote
Old 10-03-2008, 07:07 AM   #7 (permalink)
kverges's Avatar
I have used the Innovate WBO2 products for years now - I use an LM-1 for temporary use in tuing and an LC-1 for permanent installs. There are many gauge options, search around. Given the affordable cost of WBO2 sensors, they really are a must for tuning and a decent idea for permanent use, just like oil pressure and water temp. Innovate is the best-supported WBO2 maker out there, it seems to me, and the units can be modified, via software, to output an analog signal as a function of lambda in most any shape you like.
As for A/F ratio, I like to see no more than 12:1 for forced induction, for safety I tune my car to run 11-11.5:1 under boost. At cruise and part throttle (closed loop) you will see 14.7:1 and be wary of trying to mess with that, as you will be fighting a stock computer's algorithm designed to adjust fuel injector duty cycle to achieve that number under closed loop.
kverges is offline   Reply With Quote
Old 10-03-2008, 07:16 AM   #8 (permalink)
Big head man
slaughtr's Avatar
Images: 3
Excellent, thanks. I just bought an LC-1 and gauge package to be installed next week.
