Obviously, Lotus got the engine position all wrong. Anyone who has seen the thing moving in the engine bay knows we're losing torque.
So, on this Saturday I dragged Allen from The LPL out of his place and asked him to open the shop to do the job. Not sure why he has this odd look on his face, but he's open to the idea. Took a while to pull the engine, but we got it! Here we are lowering it back in to the CORRECT position. Why didn't the Lotus engineers think of this?! Dyno to follow. I'll keep you posted. BTW, we did add an extra countershaft to the the transmission so it spins the right way. (saw that question coming)
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
NOT ßANNED!
I'm confused.
perfututum futūtor below
If it's just the engine movement, why not just go with stiffer mounts?
Back to Basics
This is interesting, but I am not sure why you would be expecting any measurable performance gains.
Instead, I would expect: 1) engine bay temps will be higher, probably not significant, however your back will be a lot warmer and you will need to foil the passenger compartment closeout panel 2) heat rejection needs to radiator and oil coolers will be higher 3) Exhaust will be longer and heavier than stock 4) Oil cooler lines will be slightly longer than stock, but probably counteracted by shorter coolant hose run. The instantaneous "losses" you see of torque of the engine moving about the engine bay may be frightening, but I don't believe this will be measurable within the transient accuracy of whatever wheel dyno you will be using... |
NOT ßANNED!
+1
It's not so much about movement, as it is directional momentum, so even if we go with stiffer mounts, that forward energy will be lost.
#7 (permalink) |
Before we started, we hooked a measuring device (Spring and produce scale) to the engine, and the forward movement of the engine in the bay measured about 40 ft lbs. That's substantial, no?
#8 (permalink) | |
I'll shut up now.
#11 (permalink) |
I just got a PM explaining the theory to me. Here's a link to the info that apparently started the thinking process.
180 degree transverse engine turn increases torque Here's the pertinent stuff from the link: wherein the stationary convex surface comprises a contour expressible in polar coordinates as R+(2*R sin(D/2)/(K*cos(D/2)+sin(D/2))), wherein K is a constant between 0.27 and 4.0, R is a length of a radius, and D is an angle of rotation of the radius about a point of rotation. I think it's legit.
#13 (permalink) | |
#14 (permalink) | |
How about delete it? It will throw some OBD codes but who cares? And who cares about the environment? ![]() What about making it smaller? That will keep the codes away. Replacement with miniature charcoal cannister?
#15 (permalink) |
Enemy of the State
I checked my calendar - it says September, not April.
06 Elise, AW, Touring, Sport, Premium, Hardtop, Starshield -- S111 Harness bar, Schroth ASM 6 point Harnesses, Seat Grommets, Front Tow Hook, Rear Tow Hook, Halon fire extinguisher, Polk speakers, MicroMirror, Odyssey PC680, ekological HID kit, Pagid RS14 pads, SS brake lines,CF Center Console, CF AC Surround, urethane motor mounts, Titanium Dave's Sub Belt Bars, Heater Core Bypass , Craftsquare Mirrors, Carbon Splitter, LETSLA, DBW Pedals, Xtender |
#16 (permalink) |
Regurgitated User
it is true, i reveresed my transmisison and drive backwards now - 6 reverse gears and 1 forward. my 1/4 mile times dropped from the low 14's to the high 12's! now that the torq is going the right way... kinda of a pain driving backwards, but it was alot cheaper than the r&d to turn the engine around.
improved 1/4 mile with reversed transmission gears if you don't believe me, here is the video to prove it !
Driving it around!
#17 (permalink) | |
#18 (permalink) |
NOT ßANNED!
Seems like slapping on a supercharger would be alot easier.
#19 (permalink) | |
