Old 04-20-2008, 03:35 PM   #1 (permalink)
You bought a Locust?
wildwhl's Avatar
Ronin motormounts...
OK - so maybe Frank didn't invent urethane, but his posts along the web sure got me to thinking. This weekend I finally pulled the mounts and filled with S-80 Urethane. Really a simple process.
And truly a great result.
My steps:
Remove mounts.
Roughen rubber with dremel/drill.
Clean with Acetone.
Dry with high heat and heat gun.
Tape up one side with packing tape (3") - make sure it is sealed well.
Mix 6 oz. of urethane. Mix thoroughly. Don't rush, you have plenty of working time.
Prop up and level mounts on bench over newspaper or other disposable masking. Pour urethane into mounts. I used a heat gun on low setting to help urethane flow. Let dry. I set the temp in the shop at 80 degrees to insure good results. After 6 hours I moved the mounts into the oven, cooked at 180 degrees for a couple of hours, then just shut the oven off. Left the mounts in overnight. Reinstalled in the morning - elapsed time about 20 hours.
Trust me - this is a worthwhile and simple mod. Test drive today and all I can say is it tightens things up...and improves shifter feel. I had the undertrays off for fluid changes and some other maintenance, so it was the perfect time to do it. Tools needed to pull mounts (after diffuser/trays are pulled): 8mm, 10mm, 13mm, 14mm, 15mm and 17mm sockets (standard and deep) along with same in ratcheting wrenches if you have 'em.
YMMV.
WW
She's gone.
wildwhl is offline   Reply With Quote
Old 04-20-2008, 04:19 PM   #2 (permalink)
Mods are good for you
Dave's Avatar
EDIT/UPDATE: After a little over a year using Ronin's suggestion, my mounts have FAILED. The urethane is cracking and falling apart. AJ has reported the same issue. I would suggest to everyone who did his mod to check your mounts ASAP.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 04-20-2008, 05:23 PM   #3 (permalink)
Lotus F1's Avatar
Originally Posted by Dave View Post
This is a good mod, did it about a year ago. Not to hijack, but I have an extra Devcon Urethane kit if anyone is interested.
I'm interested Dave..how much?
I have the Forced Fed solution.. I wonder how they compare and or would be work even better together
formerly 1FASTMX5
Lotus F1 is offline   Reply With Quote
Old 04-20-2008, 07:45 PM   #4 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
I have the same engine mount mod and highly recommend it.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 04-20-2008, 09:32 PM   #5 (permalink)
Mountain Road Nut
ChrisH's Avatar
Did you notice much more vibration and/or noise in the car after stiffening the engine mounts?
Old 04-20-2008, 09:33 PM   #6 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
a little more vibration at idle.
Old 04-21-2008, 08:36 AM   #7 (permalink)
wildwhl's Avatar
Personally, I've noticed no additional vibration. In fact - IMHO - this is a *free* mod (no negatives). Of course, I like it a little rough in the Exige...so what do I know
WW
She's gone.
Old 04-21-2008, 08:54 AM   #8 (permalink)
Keep it simple and real
Lotusmotion's Avatar
wildwhl, the mounts that you refer to...are they the two upper ones located on each side of the engine? Per the Exige parts manual, it looks like the two lower mounts (front and back of engine bay) consist of bushings, and the two upper ones are rubber.
Also per the parts manual, the passenger side upper mount (passenger side) looks sort of like a rubber Dairy Queen cone (for lack of better description), but I couldn't get enough schematic detail on the driver's side mount. Being that I am at work right now, I have not yet looked at the engine compartment of my car to check out the mounts.
Is the above description correct? Also, where did you buy the urethane kit? Was it Devcon Flexane 80 Putty?
Thanks. This sounds like a fairly straight forward mod.
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: corner balanced - RTD brace - Manly's inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - AIM timer - Green Filter - Larini - oil temp & pressure gauges - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disable switch - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functional.
Lotusmotion is offline   Reply With Quote
Old 04-21-2008, 09:55 AM   #9 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
you are looking for the two mounts under the car for and aft of the motor. Leave the upper mounts alone.
Old 04-21-2008, 10:04 AM   #10 (permalink)
wildwhl's Avatar
Ditto.
You can pull the mounts, and the motor/trans will hang from the upper mounts (though I did place a jack underneath so as not to over-stress things).
They are rubber mounts...look here....
http://www.monkeytuner.com/forum/vie....php?f=4&t=847
WW
She's gone.
Old 04-22-2008, 08:46 AM   #11 (permalink)
Thanks...that helps a lot. Never had the lower mounts off the car before.
Did you use Devcon Flexane 80 Putty (1 lb. package)?
Old 04-22-2008, 11:44 AM   #12 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
I need to do this ASAP!
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 04-22-2008, 12:13 PM   #13 (permalink)
Grrrrrr Baby
Dmbrown34's Avatar
What epoxy should you use? I googled and found:
http://www.acehardware.com/product/i...Id=27307640933
Would that be the right stuff?
2005 Lotus Elise LSS
2003 Corvette 50th Anniversary Convertible
Dmbrown34 is offline   Reply With Quote
Old 04-22-2008, 12:27 PM   #14 (permalink)
GregD's Avatar
No. You need urethane, not epoxy. Check the prior links in the thread.
Racing Green, Sports, Touring, Hardtop, and Starshield.
GregD is offline   Reply With Quote
Old 04-22-2008, 12:35 PM   #15 (permalink)
sleepe's Avatar
Forced Fed engine damper: is this comparable to the urethane solution?
I have the FF engine damper.
The damper really firms things up as well.
Would filling the mounts with urethane and
using the damper be overkill?
Would one negate the other?
-Robert
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
Old 04-22-2008, 12:37 PM   #16 (permalink)
A smile a mile.
NMRJock's Avatar
That Devcon epoxy is probably a Polyacrylate, which is going to dry brittle. You want to make sure that you get polyurethane so that it is a (tiny) bit flexible.
Paul Parkanzky
Magnetic Blue with Biscuit Touring, LSS, Starshield
NMRJock is offline   Reply With Quote
Old 04-22-2008, 12:38 PM   #17 (permalink)
A smile a mile.
NMRJock's Avatar
Wow, I'm slow.
Paul Parkanzky
Old 04-22-2008, 12:43 PM   #18 (permalink)
Grrrrrr Baby
Dmbrown34's Avatar
Devcon Urethane kit - according to post #2.
Googled that and couldnt find it...
Old 04-22-2008, 12:57 PM   #19 (permalink)
TimMullen's Avatar
Images: 19
Google: "Devcon Flexane 80 Putty"
94 Miata R Package - Black
Old 04-22-2008, 12:57 PM   #20 (permalink)
GregD's Avatar
Did a search on Devcon Urethane, and found this one.
http://www.toolstoragewarehouse.com/...D&ProdID=16083
I think there were a couple of links on the monkeytuner website as well.
