#21 (permalink) |
Plug Whisperer
Just to be clear, you "vent" to atmosphere and you *can drain* back to the tank... If the orange cap vents sufficiently, then you're fine.... although, I wouldn't think the orange cap is a great vent by the looks of it. You need what I would basically call an unrestricted source to vent the gasses out (like a little filter). If you choose to drain the oil back to the pan rather than draining the catch can, then a small oil fitting will suffice, as there's not that much oil that needs to flow back to the pan..
Hope that helps, Phil
#22 (permalink) | |
I used the same setup but located the can in different loaction. And cover the vent cap with a round foam.
2008 Exige S Sport in HK (S240) almost stock. Last edited by HKFEVER : 10-31-2009 at 02:02 AM. |
#23 (permalink) | |
2008 Exige S Sport in HK (S240) almost stock. |
#24 (permalink) | |
The opening on the orange cap is quite big, so big that I need to put a round foam around. Otherwise I need to clean that area all the time.
#25 (permalink) | |
Anyone know what the GT3 car engine's have for this setup? I looked at a couple of photo's and can't tell from them.
'07 Exige S,LSD,2bular Header,SportCat & GT3 Exhaust,Gotham Tune ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler&Pipes,CircuitWorx Oil Pump Gears,Moroso oil pan, Accusump,Fidanza 3.2 Kevlar Clutch & Alum Flywheel,Nitron GT3,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Lotus Racing M Mounts/High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Traqmate. |
#26 (permalink) | |
Frank Amoroso Whatever Press Vehicle(s) I'm driving this week www.twitter.com/famoroso Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it? |
#27 (permalink) | |
Parts scattered about...
My car is modified.
#28 (permalink) |
User, Registered
Of course it's mainly oil, but there's a disproportionate amount of water in it because the water vapor from the crankcase condenses in the catch tank. Normally, that water vapor would be drawn into the intake and eventually thrown out the tail pipe.
#29 (permalink) |
Yes, there could be condensation if the oil is left in the can, but this is in reference to draining immediately back to the pan (see the original question) - that would reduce the amount of condensation since the oil is not sitting and cooling off in the can.
My car is modified.
#30 (permalink) |
User, Registered
No, you're missing my point. All crankcase water vapor will be drawn into, and condense in the catch can, it's not a matter of time.
#32 (permalink) |
This is what I talked about the round foam and you can see those oil mark at the bottom of the foam. If the foam is not there than the oil will stick around the rear glass, the cooler surface.....
2008 Exige S Sport in HK (S240) almost stock. Last edited by HKFEVER : 10-31-2009 at 07:40 AM. |
