Old 08-06-2009, 11:32 PM   #1 (permalink)
Mediocrity is a sin.
cspak71's Avatar
Images: 9
Spark Plug install??
Hi.
Been searching the forums for a while now and I can't seem to find any posts directly related to this. I'm mechanically inclined, but would like to make sure I do it right the first time.
Is there anyone out there who has done a spark plug change and documented the process? I have no clue as to how easy or difficult this process is.
Also, the recommended spark plug for the stock engine is a heat factor of 6. Is this correct?
Thanks for all your help guys.
'05 SY Elise
cspak71 is offline   Reply With Quote
Old 08-06-2009, 11:38 PM   #2 (permalink)
why are you changing it? how many miles do you have?
Klint is offline   Reply With Quote
Old 08-06-2009, 11:40 PM   #3 (permalink)
cspak71's Avatar
Images: 9
46k.
'05 SY Elise
Old 08-06-2009, 11:47 PM   #4 (permalink)
hmm well i cant find a guide (in celica forums) but all you do is take the coil pack off and spark plugs are down in there. For the celica its best to use Denso or NGK Iridiums.. i think its the same with the lotus since they are the same engine but im not exactly sure what your owners manual says to use... so use that.
Old 08-07-2009, 04:22 AM   #5 (permalink)
Crunchy Smurf
toedrag's Avatar
Images: 25
It's very easy and will only take a few minutes. See pages IG-1 through IG-7 (pg 270-276) of the Celica Repair Manual, Vol 2. Snippets below:
Next, use a 16 mm (0.63 in.) plug wrench, remove /install the spark plugs. Torque: 18 N m (184 kgf-cm, 13 ft-lbf)
The Celica Manual recommends these spark plugs:
DENSO made, SK20R11
NGK made, IFR6A11
But, you might look around both here and newcelica.org to see what people are using these days.
Have Fun
2006 Laser Blue Elise
-aka, Blue Lightning 2.0, The Little Blue Car, my automobile soul mate
toedrag is offline   Reply With Quote
Old 08-07-2009, 07:52 AM   #6 (permalink)
User, Registered
fpitas's Avatar
I have nothing to add besides advising you to put some dielectric grease in the spark plug boots. It will help insulate and keep moisture out, which has sometimes been a problem.
Francis
Old 08-07-2009, 08:10 AM   #7 (permalink)
tesprit's Avatar
The only thing I would add would be to direct a compressed air blast into each spark plug hole after removal of the coil packs and before removing the spark plugs. This will ensure that if any loose object has fallen into the spark plug tube it will be expelled and not fall into the cylinder when the spark plug is removed. Also plug each tube opening with a clean rag if you do not put the new plug in right away. There is nothing worse than dropping a tool like a small socket or a small nut or washer only to see it fall into a spark plug tube and into the cylinder. The only way to get someting out of the cylinder is to pull the cylinder head and that is not something you want to do.
Old 08-07-2009, 08:50 AM   #8 (permalink)
the need for speed
Addictedto's Avatar
Images: 18
+10000000000000 Do them one at a time and follow the above advice. Its super easy to do.
'05 Elise, Storm Titanium, Gullwing top, custom pinstripes, LETSLA, stage II exh, BWR (sitting on coffee table)
Addictedto is offline   Reply With Quote
Old 08-07-2009, 09:22 AM   #9 (permalink)
cspak71's Avatar
Images: 9
Attachment 129843
DENSO made, SK20R11
NGK made, IFR6A11
Have Fun
Peopl have mentioned the gaps on the spark plugs... is this a real issue? Should I be aware of any particular gap issues?
'05 SY Elise
Old 08-07-2009, 01:16 PM   #10 (permalink)
i agree with all of the above.
The spark plugs come pre gapped but i would look at them closely to make sure they havent been dropped or the gap damaged.
Old 08-08-2009, 07:50 AM   #11 (permalink)
glb
Unattractive Nuisance
glb's Avatar
IIRC, we must be careful gapping iridium and platinum so as to not disturb those platings? Is this right?
Also, plugs on most cars can be indexed, so the gap faces the intake valve. You need to mark the socket and try various plugs to do this. I have no idea if it helps for real...
Old 08-08-2009, 03:29 PM   #12 (permalink)
bigDog's Avatar
I replaced them on my son's Celica (same engine as the Lotus) last weekend. It was pretty easy. The hole they are in is really deep so I ended up using two extensions since I didn't have one long enough. I also used a spark plug socket with a foam insert that holds on to the plug to get them out and then I used one without the insert to put them back in.
bigDog is offline   Reply With Quote
Old 08-09-2009, 01:57 AM   #13 (permalink)
choi0706's Avatar
sorry but youre not mechanically inclined if you can't replace spark plugs..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 08-09-2009, 04:53 AM   #14 (permalink)
Haxord but mine
Westrock's Avatar
I'll see if I can put a video on Youtube later showing how to do it
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
Old 08-09-2009, 09:56 AM   #15 (permalink)
glb
glb's Avatar
a brief search turned up no warning on gapping iridium or platinum plugs, but mfgrs say there is little need, as these types of plugs will work, at almost any gap, better than a properly-gapped "normal" plug.
Old 08-09-2009, 10:30 AM   #16 (permalink)
TimMullen's Avatar
Images: 19
Does it help? Yes. Will you notice any difference? No. Maybe if you were running a 1,5000 HP top fuel dragster, but for a normal (or even high performance) street car, it will be unnoticible.
I've been known to mark the plugs and swap them around so that I get the most "indexed" combination, but never to the extent that I would swap other plugs for a larger selection (i.e. I only have four plugs - I make the most out of the four, while still understanding that it isn't going to make a difference...).
94 Miata R Package - Black
Old 08-09-2009, 12:12 PM   #17 (permalink)
glb
glb's Avatar
Wait....my Elise DOESN'T have 1500HP????
I agree w/you.
