Student Driver
Tune your accelerator pedal!
I recently followed the Lotus service note for adjusting the gas pedal to rest lower, relative to the brake pedal -- for easier heel-toe work.
Once I got through the big words in the bulletin and looked at the hardware, I found it's really a flexible and simple system. There is the downward stop bumper that hits the footwell in the car. It's about as hightech as a doorstop. You can adjust it a bit in-place, or remove the bolt and use a shorter one. Or remove the rubber bumper if you like the metallic click-click -- many options. Then there's the up-stop bumper -- a small rubber pad above the pedal arm. The service notes replace this with a bolt and some washers to make a thickness more than the rubber bumper. (They do neglect to mention that a backing nut would be useful, so sketch it out before making a shopping list.) The thicker the washers and bolt head, the lower the pedal rests. No rocket science here. When the pedal is set to your liking, you release the cable clamp in the engine bay and reset it to reset at idle again. Very easy one-man job. I find the recommended adjustment to be perhaps a little too extreme. It makes full-throttle a full depression to the floor, and puts the brake pedal a big reach away. I'll probably end up somewhere in the middle, with one or two washers. This mod, combined with the brake rod adjustment to spec makes the two pedals much more harmonious and responsive. I still have the long mushy brake travel, but at least it's not miles below the gas any more. The point of this post is just to say... get in there and have a look!. It's decidedly low tech, and relaxing fun to work on. Mold the car around the feet you have. And practice your yoga. |
Nice, yes it works great! Here is what I wrote about it some time ago...see a few posts down from the top and thereafter...PICs included too...
http://www.elisetalk.com/forums/show...t=11013&page=3 |
#3 (permalink) | |
insert clever title here
Student Driver
Wow.. the other thread grew since I last saw it. Maybe mods can just toss this one to keep from branching or merge it in. All the good info is over there.
As for the cable stop, if you pop your engine lid and have a look, it becomes pretty obvious. There are two (17mm?) nuts that hold the cable sleeve in place, and after you adjust the pedal, you release the nuts and twist the threaded sleeve in or out to relax the cable back to idle. It sounds complicated but if you look at it and tug on the cam a bit, it's all pretty straightforward. |
#5 (permalink) | |
Simplicate!
2005 Elise BRG, Touring, Hardtop 1991 Elan M100 (for sale) |
#334
Lower accelerator pedal by 1.75"
With some help from Carl4 yesterday, I finally got around to lowering my accelerator pedal. Using a custom bracket, I was able to drop the accelerator pedal all the way to the floor at wide open throttle, which is about 1.75" improvement. It's a better fit for my long legs and provides an excellent heel-n-toe position.
Note the photos of the position of the accelerator pedal position and the bracket. |
#8 (permalink) |
Fly N Lowr
Ground Loop,
Thanks for the new post on this subject. I have read the other but havs not had a chance to get in there yet and I was wondering about the complexity. You make it sound very simple, my kind of job! With the ability to adjust the pedal I'm confused as to why there is still a need for a custom bracket as posted above, can someone clairfy this for me?
If you're not living on the edge you're taking up too much space!www.GoodBodyHealth.com |
#9 (permalink) | |
#10 (permalink) |
#334
Stan is right -- no stop bolt on the bottom of the accelerator pedal.
The accelerator action is pretty much the same: same travel. The spring is stretched more, so it is providing more resistance. This afternoon, I'll stretch it and everything will be back to normal. |
#11 (permalink) |
Team Fiscal Irresponsible
I guess another important thing to point out is #4:
![]() I don't know how you check that by yourself. Don't you need another pair of eyes checking the cable quadrant movement as you adjust the down-stop bumper?
'05 Arctic Silver/Ruby Red - Touring/SS/HT |
#13 (permalink) | |
#14 (permalink) | |
#17 (permalink) |
This is a great thread. Thanks guys. Why isn't there any fighting on this thread?
Dan Parker 92 BMW 325 - JP Race Car 09 Jetta Tdi 06 Z4 M Coupe 09 Child on the way (anyone need a car?) |
#18 (permalink) | |
The bracket would be handy since there is only so much adjustment available on the engine end of the cable. This bracket apparently moves the pedal end of the cable which in turn will make more adjustment available at the engine end. Now the big question is how much is the bracket, and who makes it?
#19 (permalink) | |
Thanks, ct |
#20 (permalink) | |
Student Driver
Raising pedals effectively puts the steering wheel further away. I like it right where it is. The whole cockpit fits me better than any other car I've driven. People with longer arms probably prefer the HnT pad for the same reason. But really, I dunno -- I haven't tried the HnT pad. |
