Old 07-02-2008, 07:23 PM   #41 (permalink)
blah
ZJChaser's Avatar
I was going to have a bit more work done to it opening up the collector a good bit, but I think I'm over it. I wasn't refering to your prices
AJ
06 Aspen White Exige - MWR Stage 4 motor : Exige S manifolds : MP62 : CharlieX Tune : FF 10psi pulley : RLS IC and pipes : Walbro 255 : RC550cc : Moroso Pan : VonHep Single : WR Race Header : JRZ DA Race Coilovers...(tons of other goodies)... 267hp/167tq at the wheels : Dyno
ZJChaser is online now   Reply With Quote
Old 07-03-2008, 12:03 PM   #42 (permalink)
jim-clayton's Avatar
For those who care.
Weapon R long race header is what we went with.
Good deal at No Limit Motorsport. Talk to Dusty. $505.00 shipped
2005 Elise Storm Titanium
Old 07-05-2008, 07:53 AM   #43 (permalink)
MR-2.0T
dustylax's Avatar
Thank you Phil and Jim.
Post up when everything is back together and you get some numbers down, i'd love to see how well these work out for you guys.
Email: Dustin@nolimitmotorsport.com
1.866.381.4618 - ask for Dustin
dustylax is offline   Reply With Quote
Old 07-05-2008, 08:24 AM   #44 (permalink)
Stormy320's Avatar
Ugghh - isn't this stuff just a big waste of money because the stock ECU will eliminate any kind of power gain this stuff provides in about 400 to 600 miles???
240S Chrome Orange EXIGE - fast... very fast
Stormy320 is offline   Reply With Quote
Old 07-05-2008, 08:47 AM   #45 (permalink)
I have EFI stand alone ( Phil too).
No tune out !
Your correct though. With a Lotus ECU it would be pointless.
Old 07-05-2008, 08:51 AM   #46 (permalink)
MR-2.0T
dustylax's Avatar
no no no no...SOME parts you may change will be tuned out, this is the biggest missconception on this forum that limits so many people from modifying this car.
I have tested this over and over and over.
the thread got deleted by the new admin but i will start a new thread just about the results of the header and not for retail purposes.
the summary of the test was this:
dyno stock
installed header
dyno'd with WR header
dyno'd with WR header 2k miles later (i think it was about 2k John ?)
dyno'd again a few months later
results:~9whp gain from stock after 3 months on stock ecu in a daily driver with plenty of miles on it and NO CELS.... THE POWER WILL STAY!!!!
Old 07-05-2008, 08:53 AM   #47 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Dustin has tested this many many times and the net HP gain remained. I also own a weapon-R header.
People commonly use statistics the way a drunk uses a lamppost; For support rather than illumination.
Let my Lotus go...[from the shop]
Old 07-05-2008, 09:27 AM   #48 (permalink)
Stormy320's Avatar
That is great to hear. I don't want the government or Lotus to have that much control over my car .
However, am I correct that the Lotus ECU will override any benefits from a more free flowing non-stock exhaust and the aftermarket intakes?
Thanks for the info.
Old 07-05-2008, 09:43 AM   #49 (permalink)
MR-2.0T
dustylax's Avatar
no that is not completely true either, CERTAIN intakes will make and keep the gains because of the design of them, the Weapon-r intake is one of those also, it was thuroughly tested and designed so that it wont be making power that will be lost from ecu learning/adjusting.
Exhaust i would have to guess that no one makes much power on them over stock stage 2's which most of the cars i have dyno'd already had. The most gain you will see from an exhaust on an NA car would be 1whp on a straight thru design and the biggest gain is really the weight loss.
The WR header sheds off ~15lbs and if you went from a stock exhaust to something light weight im sure there is another 10lbs+ to be lost which combined is a nice diet.
Old 07-05-2008, 01:46 PM   #50 (permalink)
'07 Black Exige S
Pestodude's Avatar
The post before you said:
"results:~9whp gain from stock after 3 months on stock ecu in a daily driver with plenty of miles on it and NO CELS.... THE POWER WILL STAY!!!!
Am I missing something? Which is it , 1 or 9 whp gain?
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, ForcedFed engine dampener, de-snorkle/ vel stack, cf side scoops/ mesh removed, algnmnt set up by Lucent in LA (machined control arms, etc), SS brake lines, 160 deg. thermo, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Stealth signal bulbs, blacked out turn side markers, 5 point harness
Pestodude is offline   Reply With Quote
Old 07-05-2008, 03:31 PM   #51 (permalink)
The 9 whp gain is on the header.
The 1 whp gain is on a straight through design exhaust (muffler).
07 Exige S - PhB., TP, TP, LSD, Rear Panel Delete, Custom Magnaflow Exhaust, Custom AEM Intake, 6k HIDs, Schroth 4pt ASM Harnesses
Sh4rkattk is online now   Reply With Quote
Old 07-05-2008, 03:49 PM   #52 (permalink)
'07 Black Exige S
Pestodude's Avatar
Ahh! So indeed I DID miss something. Sorry.
Randy
Old 07-05-2008, 09:25 PM   #53 (permalink)
MR-2.0T
dustylax's Avatar
yes, exhaust and header i consider 2 seperate things.
weapon r header/de-cat ~9whp
exhaust ~1whp
these are from cars i have dyno'd myself, not based on other results or stuff i have just heard or read about.
Old 07-14-2008, 09:31 AM   #54 (permalink)
I installed the Weapon R race header over the weekend.
Great header for the price but not a direct fit on the muffler side.
I had to modify the u-bend. Something off with the u-bend.
Phil had the same issue.
That being said, no regrets. Looks good, sounds good, and I'm sure it's worth
some HP.
Old 07-14-2008, 09:36 AM   #55 (permalink)
blah
ZJChaser's Avatar
how exactly did you have to modify it, mine will be going in either today or tomorrow
AJ
Old 07-14-2008, 09:56 AM   #56 (permalink)
I cut a 1" wide section out the u-bend. Dead center. Basically cut the tube on either side of the O2 bung. Used an upright belt sander to get the angle I needed and welded it back together. Installed a new O2 bung.
Phil heated his with a torch and jacked it into position. He's a better man then I !
It's possible that it might fit a small dia muffler. The angle of the u-bend pushed my can too far towards the rear of the car. Makes sense?
Old 07-14-2008, 10:08 AM   #57 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
+1 on Jim's comments...
I'm quite certain that there's headers make power. The sound is clearly different.
The U bend is clearly not accurate. It doesn't come a full 180 degree back around and it's angled down too far. The jack and torch method I used only fixed the vertical aspect probelm of the bend and got me back on the road. Where Jim's cut and weld fixed both. I was hoping that I could deal with front to back issue since my exhaust is so small___ and I will *deal* with it in the short run. In the long run, I'm probably going to have to cut the U as Jim did to fix that issue. If anything, the exhaust can is sitting so catty-whompis that it just looks bad through the clamhinge rear panel
I don't also don't regret the purchase, as it is a nice piece in general and half or a third of the cost of others out there... However, it's clearly not bolt on product for the masses----yet. Weapon R or Dusty needs to make a change in the product to fit the car, as I doubt most will have the ability to do what Jim and I did...
Best,
Phil
| '05 GG LSS Elise | Track Chariot | Too Many Mods to List | Collaborative Boosting by Ronin & S111 & BOE | EFI Standalone Engine Management | ClamHinge |
See my car here:http://www.boefabrication.com ----->Last Updated: 6/15/08
Corporate Culture: Passive idiots are much easier to work with than active idiots
Old 07-14-2008, 10:12 AM   #58 (permalink)
blah
ZJChaser's Avatar
yup that makes sense. Did you guys use the solid brackets that hold the two pieces of the header together? I am using springs and hoping that might give me enough play.
AJ
Old 07-14-2008, 10:33 AM   #59 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Once you see how it mounts, you'll see that the springs won't make the difference... Unfortunately, there is little to no play/flex in the system (with or w/o springs). Unless your system is substantially different from ours, you're going to have to get pretty creative to make things come together correctly...
Good luck,
Phil
Old 07-14-2008, 10:37 AM   #60 (permalink)
MR-2.0T
dustylax's Avatar
i talked to the person who engineered this header and brought this to his attention at the time because i had a slight issue myself but was able to muscle it into place on one of them and from one other person said the same thing, i dont know if it was the jig they were using or if something else got messed up during production but im going to bring it to his attention again because this current batch of headers is almost gone so the next batch can be corrected.
HTML code is On
