While the clam is off for recall, what should I replace? - Page 2 - LotusTalk - The Lotus Cars Community
Old 01-16-2013, 09:58 AM   #21 (permalink)
philethier's Avatar
Originally Posted by fitfan View Post
yea, sorry - anti roll bar... or sway bar - shorted the verbiage there! on the formula car we always talk about the "roll" set-up.
As I said, you absolutely do not need to remove a clam to do the front swaybar on an early Elise. In fact, I see no advantage to having the clam off for this.
I swapped my stocker for a "Hardcore SCCA Super Stock" bar myself in an afternoon. Do not disconnect the suspension, just modify an Allen wrench.
Phil Ethier West Side Saint Paul Minnesota USA
2004 Suburban 8.1, Sport Red, the only automatic of the bunch
2007 Saturn Ion 3 2.4, Berry Red
http://www.mnautox.com
philethier is offline   Reply With Quote
Old 01-16-2013, 10:50 AM   #22 (permalink)
Shade-Tree Mechanic
carphoria's Avatar
OK I'm going to probably get flamed for this one but..
do they need to pull the clam for the fix?
To my knowledge (limited) they are just replacing the clamps and shaving the hose. the fittings are just behind the wheel well liner, no?
2006 Exige KoldFire270
modified
carphoria is online now   Reply With Quote
Old 01-16-2013, 11:20 AM   #23 (permalink)
Thanks Pepper
doug_porsche's Avatar
Really carphoria? Didn't you read the......
Well it plainly, ok it doesn't really
Hmmm......
Ok,
I was actually woundering where people were seeing that the front clam had to come off. I have seen a parts list, but no how to included in anything from LOtus.
Enjoying Lotus performance because of its nature, not because of its quantity
it isn't that i'm not a people person, I'm just not a stupid people person!
doug_porsche is online now   Reply With Quote
Old 01-16-2013, 12:23 PM   #24 (permalink)
yeah, do the radiator for sure. I'm in the process of ponying up way too much money to have mine replaced... probably 1600-1700 including the radiatator at an indepenent shop, days before I received the recall letter... so bummed, i could have saved nearly 1000 in labor. The stock radiator is known to fail. Just do a quick search on the radiators or stop on by the "engine cooling" area of the website and see how many people end up with crack on the plastic end caps. Prorad is what's going into mine.
2006 Aspen White Elise. LSS, LSD, Traction control, LS Toe Link Brace, LS Ohlins DA, Rota 15/16's, BOE surge tanks and Sector 111 Gpan2, Red leather, JL speakers all around with Acapulco MP54, CF dash top, gas shock opening rear deck, multi-vex mirros and replaced rear-view mirror with kit off this forum.
ewalberg is offline   Reply With Quote
Old 01-23-2013, 03:58 PM   #25 (permalink)
Originally Posted by aztec1382 View Post
You should just remove them completely and run a Setrab
Sent from my iPhone using AutoGuide.com Free App
What kind of setRab would you use though? they have dozens of different oil coolers...
GronkDaSlayer is online now   Reply With Quote
Old 01-23-2013, 05:09 PM   #26 (permalink)
Originally Posted by Spartacus View Post
I figured I could save some money while the front clam is off while they fix the oil cooler issue. What should I replace or upgrade? I've read about the radiator and the ac. Should I get those replaced even though they are working fine?
Do you really think they’re going to knock off most of a labor charge for a secondary job just because the primary job has made most of the secondary job labor time redundant? Book rate for the primary job plus book rate for the secondary job will be the total bill. If the primary job is warranteed, you’ll be charged full book rate for the secondary. Do you really expect to have the resistor pack replaced (20 minutes once the clam is removed) and the radiator replaced (one hour, tops, to replace, do the coolant and test) for a total1.3 hours labor just because they already have the clam off? Doubt it. If so please tell me the name of the shop – I’d have it all done for $200 labor + parts! They may not charge for two clam removals for those two secondary jobs, but I bet you'll pay for at least one removal.
Sorry for the dealer shop rant - past experiences.
<12parsecs is offline   Reply With Quote
Old 01-23-2013, 05:17 PM   #27 (permalink)
Rob@DietschWerks.com
FYI Oil Line Recall
Please check with your dealer before ordering any parts to be installed while the car is in for the recall.
THEY DO NOT NEED TO REMOVE THE FRONT CLAM TO DO THE RECALL.
Lotus pays the dealer 4 hours to replace the oil line ends.
We don't remove the clam to install our oil line kit(5 hours).
'99 111 Sport 190
'02 111S Tesla Mule 1 - Lightning Yellow
'04 pre production 111R SY/'04 pre production 111R AR
'05 Exige Aubergine/'05 Elise SY
'06 Sport Elise #038 SY/ST
'08 Exige S 240 KG
Dietsch Werks
408.355.0081 anytime
Dietsch is offline   Reply With Quote
Old 01-23-2013, 10:18 PM   #28 (permalink)
Shade-Tree Mechanic
carphoria's Avatar
Yeah, kinda what I was thinking...
modified
Old 01-24-2013, 12:58 PM   #29 (permalink)
DDT
I called Lotus USA and they confirmed that the front clam comes off as part of the recall. The reason I asked is my dealer was doing the recall and noticed the radiator was leaking and wanted to charge me 1700 to replace it. I called to confirm the attempted double-dip.
DDT is offline   Reply With Quote
Old 01-24-2013, 04:21 PM   #30 (permalink)
Like I said.
Old 01-24-2013, 05:25 PM   #31 (permalink)
Probably a dumb question: but can you do this in a non- dealer shop? I have a great guy who does fantastic work and is very fair in his pricing, but the recall letter implies you need to take to a dealer shop.
Tharssus is offline   Reply With Quote
