Emergency Brake Lever Rattle - LotusTalk - The Lotus Cars Community
Old 12-25-2012, 09:23 AM   #1 (permalink)
Lotastic
me73's Avatar
The emergency brake lever is 2 main parts, the base which has the teeth for the latching mechanism, and the lever itself. The two parts are held together with a somewhat loose pin to allow relative rotation. The pin on mine is loose enough that the mechanism rattles as the lever taps on the base while shifting and while the car is moving. The pin is a permanent rivet, so the two parts can't be separated without cutting off the pin.
Part number 1
http://www.lotusgarage.com/shop/inde..._images&p=2069
Is this pretty common (I think I already know the answer to this one)? Are there any methods for adding a cushion between the parts or tightening the lever onto the base?
Life Lesson #1: If you can't fix it with a hammer, you have an electrical problem.
Life Lesson #2: It's more fun to drive a slow car fast than it is to drive a fast car slow.
me73 is offline   Reply With Quote
Old 12-25-2012, 02:46 PM   #2 (permalink)
Lotastic
me73's Avatar
I am going to run an experiment. I ran a piece of 1/8 inch heat shrink tubing into the top of the lever (from the back of the lever) so it sits between the lever and the top of the base. When the brake is released, the tubing is pressed into the space between the lever and the base and the rattle appears to go away. It's held in place with a little black RTV. It seems to work in the garage. Hopefully this is a long term solution with multiple uses of the e-brake.
Old 12-26-2012, 05:14 PM   #3 (permalink)
Lotastic
me73's Avatar
This seems to have worked very nicely. The tube gets compressed between the top of the base and the lever and keeps the two from rattling against each other. The RTV holds the tube tightly in place and you can't see or feel that anything is there.
Lotus finished about 98% of the design of the car and we get to do the final touches. Gotta love 'em.
Old 12-26-2012, 07:23 PM   #4 (permalink)
mspenard's Avatar
Pictures please!
mspenard is offline   Reply With Quote
Old 12-26-2012, 07:50 PM   #5 (permalink)
Lotastic
me73's Avatar
I should have taken pictures as I did it, but I didn't and now you really can't see anything.
But it's easy to try for yourself.
1. With the brake lever down (released) wiggle it side to side and listen for a rattle. Also run the shift lever side to side with and without pressing on the side of the lever to see if there's a rattle when you aren't pressing on the lever.
2. If it is, you can try to see if it goes away by stuffing the space between the lever and the base. I took the heat shrink tubing and fished it under the lever from the back side with the lever completely released. Keep pressing it in until it stops, then lift the handle a little and the tube will go a little further.
3. Put the lever in the down position so the brake is completely released and try to make it rattle again.
4. If the rattle goes away, you can do the same thing but put some RTV on the tube to hold it in position permanently.
5. One rattle Gone. 99 left to go.
