GRP Headlight Installation - LotusTalk - The Lotus Cars Community
 11Likes
  • 2 Post By Klint
  • 2 Post By GregsRaceParts
  • 2 Post By Falsey
  • 2 Post By b3ll
  • 1 Post By GregsRaceParts
  • 2 Post By mpower1226
post #1 of 9 (permalink) Old 03-20-2017, 01:40 PM Thread Starter
b3ll's Avatar
Question GRP Headlight Installation
Hey all,
I just bought a set of replacement headlight lenses (not the full housing, just the lenses themselves) from GRP to replace the current ones I have on my car.
Does anyone have any recommendations or things to keep in mind when swapping them?
I've been told the best way to separate the lenses from their housings is to use a heat gun to soften the glue and then a knife to cut them, but I don't want to damage the housing. I assume that a strong waterproof epoxy of some sort would be used for re-bonding the lenses afterwards.
Has anyone done this before?
b3ll is offline
post #2 of 9 (permalink) Old 03-20-2017, 01:54 PM
Klint's Avatar
I'll ping Greg to chime in for you !
GregsRaceParts and b3ll like this.
2005 SY Lotus Elise Supercharged
(Build date: Sept. 13, 2004 #484)
16th of 115 US 05 same color\trim\options.
Signed by Elisa Artioli
Handmade in England- Perfected by me.
Sponsored by: Difflow Diffusers- GRP (Mention "Keleent" for a discount at checkout )
Follow me on IG:
www.instagram.com/keleent
Klint is offline
post #3 of 9 (permalink) Old 03-20-2017, 02:16 PM
Elise Racer
GregsRaceParts's Avatar
Originally Posted by b3ll View Post
Hey all,
That is about the only way to do it. We place a heat gun in the vice on low, and work the assembly back and forth over it to get even heat across about 6-8" at a time. Using a plastic separator tool. we wedge that in between the lens and housing and work it throughout the heated area. It takes some time so be patient, but as long as you keep the factory glue/adhesive warmed up it comes apart without a huge amount of force.
--If the current lenses are going in the trash you could use something sharper as you wont have to worry about gouging them etc.
102ndcar and b3ll like this.
Check out gregsraceparts.com for all your Carbon Fiber needs and high quality Lotus parts
Email: gregsraceparts@gmail.com
IG: @gregsraceparts
GregsRaceParts is offline
post #4 of 9 (permalink) Old 03-20-2017, 02:40 PM
I threw mine in the oven on thick cardboard with a damp towel inside. (Googled to find temp and time - approx 4 mins I think). Then used a butter knife and they came apart in seconds. I then used rubber butyl from theretrofitsource to seal them back up by again placing in oven for a small period of time again and pressing them together. Just make sure if you go with my method, there's no protective film on the lenses of the headlight.
GregsRaceParts and 102ndcar like this.
Falsey is offline
post #5 of 9 (permalink) Old 03-20-2017, 03:26 PM
Roundabout's Avatar
I was able to remove them quickly using a box knife with a rounded blade and a vice:
How to Separate 2005/06 Headlamp Lens from Base
Don't cut your fingers off!
Roundabout is offline
post #6 of 9 (permalink) Old 03-20-2017, 06:13 PM
Saffron Yellow is Lighter
XtinctElise's Avatar
Are people just using black silicon to glue the new one back on? I don't feel like having glue flavored meals from the oven.
'05 Lotus Elise - Saffron Yellow | Sport Pack | Touring Pack | REV400 - 5.6 lbs/hp | ACT HDSS Clutch | DMC Header | Sport Cat | Larini SE Exhaust | re-Enforcer | LETSLA | SSC Cables | BWR Double-Adjustable Shocks | Shorai Lithium-Iron Battery
XtinctElise is offline
post #7 of 9 (permalink) Old 03-20-2017, 07:12 PM Thread Starter
b3ll's Avatar
Awesome! Thanks so much for the info, it's raining all week, so when it gets slightly nicer outside I'll have a go at it. I'm still pretty afraid of the Oven solution, but the heat gun seems fine. I'll be trashing the old lenses anyways (they're spiderwebbed ).
b3ll is offline
post #8 of 9 (permalink) Old 03-22-2017, 08:45 AM
Elise Racer
I always use a black permatex silicone sealant and have had great results.
102ndcar likes this.
IG: @gregsraceparts
post #9 of 9 (permalink) Old 04-11-2017, 06:36 AM
When I received my lenses for my cf housing from greg, I used black permatex RTV sealant. I used masking tape to leave a clean and small line just enough to fill up and bond the lense to the housing.
Easy but do it slowly. make sure to cover up the lenses too.
mpower1226 is offline
Human Verification
