How to secure battery? Keeps coming loose and moving around? - LotusTalk - The Lotus Cars Community
Old 11-12-2012, 07:26 AM   #1 (permalink)
L0tus's Avatar
My battery keeps coming lose from its lock in position and moves around when driving. I am under the impression that the only thing holding it down are the two carpet clamps? Doesn't seem like a good design given how bump/rough the ride is. Any ideas how to secure the battery down so it doesn't come loose?
L0tus is offline   Reply With Quote
Old 11-12-2012, 07:37 AM   #2 (permalink)
brgelise's Avatar
Images: 9
OE battery had a ridge at its base that the retainer firmly pinched up against. many replacement batteries don't have that ridge so the stock method doesn't work.
04 Skip Barber Race School, Competition certificate
04 Jaguar XJ Vandan Plas Radiance Red Ivory leather
08 Isuzu Ascender Lux Flint Grey, Grey leather
10 Lotus Evora Persian Blue, Charcoal w/Ivory header
11 BMW Xdrive35d, Vermillion Red w/Cinnamon Brown
2005 Elise gone but never forgotten as it taught me to drive quickly!
brgelise is offline   Reply With Quote
Old 11-12-2012, 08:02 AM   #3 (permalink)
Mine was doing the same, so I ditched it and got an Odyssey PC680 with an aluminum hold down. Now it's perfect.
Tracker is online now   Reply With Quote
Old 11-12-2012, 08:09 AM   #4 (permalink)
L0tus's Avatar
Might consider upgrading the battery then. Pretty crappy design on Lotus's end IMHO.
Old 11-12-2012, 09:16 AM   #5 (permalink)
glb
Unattractive Nuisance
glb's Avatar
Assuming your battery has the ridge:
Glue rubber to mount
Bend mount so it's tighter
Put rubber, or 2 pcs HD Velcro under battery.
My Interstate never moves a bit.
edit: Oh, push mount against battery when tightening mount bolt. Check rear mount bolt, too.
"Political language is designed to make lies sound truthful and murder respectable." G. Orwell.
"Incontinence Emergency Hotline- Can you please hold?"
glb is online now   Reply With Quote
Old 11-12-2012, 09:35 AM   #6 (permalink)
I took some aluminum bar stock from Home Depot and made a strap that bolts to the back side mount and the wraps/folds around the back of the battery and then makes it way down under the front side clamp. Weighs nothing, was very inexpensive and works well.
It's three segments pop-riveted together.
glagola1 is offline   Reply With Quote
Old 11-12-2012, 10:03 AM   #7 (permalink)
curtis's Avatar
Could you possisbly snap a few pics of how the strap works that you made? Thanks..I am having the same problem as the op and sorry for hijacking this thread!
05 Saffron yellow,LSS ,hard top and nothing else!
curtis is online now   Reply With Quote
Old 11-12-2012, 10:07 AM   #8 (permalink)
JavierBayArea's Avatar
Dude don't drive the car hard with the battery like that. I have a friend who had to replace the clam because the loose battery smashed it.
Sport Elise #30
BMW Z4 sdrive35i
JavierBayArea is offline   Reply With Quote
Old 11-12-2012, 10:26 AM   #9 (permalink)
Here you go. Sorry for the lousy phone pic. Super easy and solid as a rock.
Old 11-12-2012, 10:30 AM   #10 (permalink)
brgelise's Avatar
Images: 9
If you're a track junkie, an Odyssey 625 will do just fine. IUts smaller, lighter and more CCA but less reserve. had mine since May 2008 and never an issue even when cranking stereo with sub etc>>>
Old 11-12-2012, 11:38 AM   #11 (permalink)
glb
glb's Avatar
good job.
Old 11-12-2012, 04:46 PM   #12 (permalink)
sturgeongeneral's Avatar
Doesn't Sector 111 sell an upgraded battery clamp? Definetely do NOT drive without the battery secure. It WILL bounce around the trunk and crack the clam.
05 Elise
56 VW Dune Buggy
Lightweight fiberglass toys that simulate street legal rocket ships!
sturgeongeneral is offline   Reply With Quote
Old 11-12-2012, 05:44 PM   #13 (permalink)
Industrial velcro the entire bottom of the battery.
Silver_Surfer is online now   Reply With Quote
Old 11-13-2012, 06:01 AM   #14 (permalink)
This is what I made for my optima battery. There is a matching bracket in the back that you can't see.
bcpower is offline   Reply With Quote
Old 11-13-2012, 04:48 PM   #15 (permalink)
hroundy's Avatar
I made a similar bracket for an Optima. I cut it to fit into the battery cell towers. I also put a strap around the battery.
Howard
2005 Elise AP LSS hardtop
hroundy is offline   Reply With Quote
Old 11-15-2012, 06:31 AM   #16 (permalink)
1800lbs club
driftwood's Avatar
i run a pc680 & use the factory bracket to hold it from sliding sideways, but also use a strip of Velcro to keep it from doing the same front to back
never had an issue (but the battery weighing only 12ish lbs probably doesn't hurt my cause
05 ST Elise: DHP custom exhuast, VF NA tune, Sachs SAS, Forge MS radiator, Powerflex inserts, s111 v3 eliminator, s111 DSbrace, Enkei RPF1's, BWR studs...
driftwood is offline   Reply With Quote
