Looking to buy, many many questions
i'll start off with these few things. yes i know there is a search bar, and ive been using it for some time already. and i'm 21... now if your just going to turn this into a young kids shouldnt own this car and buying one is stupid please dont bother. ive read almost every one of them.
I understand that you dont simply own an elise because its cool. owning an elise is an adventure, for better or for worse. - so i'll get to it. I've lived around high maintenance rear engined cars my whole life so i have an idea of how much time and effort goes into keeping them running. But around how much does it cost per month to maintain? - i'm stationed in texas so one of my biggest fears is weather. from what ive gathered no elise is water tight, no matter what there will always be water somewhere if its raining or wet. what are ways to help prevent this? what are problem areas where water tends to pool? - what about hot/cold weather? Do elises overheat in hot weather? do they have standing issues in traffic? Aside from tires are there any issues driving them in below freezing temperature? - no car is without flaws. there were the recalls for the shifter knob, the oil lines, and the infamous red clutch hose, shoddy radiator walls, the ’05 headlights getting “sunburn”. I’ve heard something about cams wearing out is this true? what about other quirky issues that usually require attention to keep the car runnineg smooth, and is there a place to find a diy for all of them? - i’m not one to put a Gucci folding top on it or lower it and throw oversized rims on it, but I do like to personalize. How well do the stock seats work with a four point harness? Which is more worth while, a clam hinge or a radium clam kit? Which companies make quality products and which ones don’t? Any insight that can give me more perspective on what owning/maintaining an elise is like is very much appreciated |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | ||||||
Guns, Cars & Guitars
1) Don't look directly at it. 2) It can reach dangerous speeds on dry pavement 3) It's made from an unknown green material that fell to Earth from space Just take it easy on the tranny and the engine if possible, don't lift in a turn carrying a lot of speed, check your fluids often, replace all the crap that usually fails or at least be prepared when/if it does, keep it covered or in a garage, drive smart, stay alive, blah blah blah. |
looking to buy, many many questions
05 Arctic Silver Elise, Lotus Sport ECU, LETSLA, Larini SC exhaust, Matte black bandit mask, wheels, fuel door. 02 Wrangler Sahara 93 miata, too many mods. Loved that car. (Sold) 05 Tucson (Wife's car) 05 Yamaha Grizzly 660 (The Beast) |
Link to aforementioned ÜberPost
![]() http://www.lotustalk.com/forums/showthread.php?t=25131 Sent from AutoGuide.com App
Painful Novice
Arizona stop and go traffic in major cities will make your temp climb, if it gets too hot, pull over and let it cool. Because the radiator is fragile, my *must stop now* temp is about 205-210 degrees F. Low temps do not seem to be a problem. Maintenance costs aren't scary, it is the semi-random failures which can be annoying and costly. In the past year, I have had 4 things which made my car undrivable.
1. Would not go into reverse, reverse lockout collar separated from sleeve with cable connected. 2. Front to back shift cable broke, leaving me stuck in second gear. 3. Fuse blew which powered Alarm/central lock, the key alone will not get you into the car. 4. Supercharger had bearing failure within a few thousand miles of install, needed replaced. Expect to go through 2 to 3 sets of rear tires for every set of front tires, this happens to everyone. (I have had to do this) Learn the tachometer/speedometer reset procedure. (I have had to do this) Learn the procedure to disarm the alarm without the key fob, for when it's battery fails. (I have had to do this) Learn the key fob resync process. (I have had to do this) Learn the key fob programming process (I have had to do this) Expect a 5 minute conversation when you stop for gas, doesn't happen every time, but it happens often enough. Bumps in the road will have a chance of making your front turn signals pop out. (this has happened to me).
Storm titanium 2005 Elise with carbon fiber spoiler, BWR sway bar, BOE toe links, gPan2, LidBone, sector 111 wheel studs, Grey RAC Monolite wheels with toyo R1R, Team Dynamics 1.4 with Hoosier A6/R6s, Katana2 Supercharger, ECU with 265 flash. PPE headers w/decat, CEL angle eliminator, Silent touch catback, Rear Panel Eliminator, HKS intake, V2 fuel tank, Walbro255 fuel pump. HID lights. |
Master of the burning log
If you're going to put 4 pt harness in, hopefully its only for show or autox unless you're getting the 'ASM' 4 pts (that ultimately act like 3 pt). If you've got no idea what i'm talking about, google 4pt harness submarining.
Also, if you don't want ppl to make comments or assumptions based on your age, why mention it?
"Give a man a match, and he'll be warm for a minute, but set him on fire, and he'll be warm for the rest of his life." Last edited by jds62f; 01-24-2013 at 04:21 PM. |
#7 (permalink) | |||
anglophile in exile
Welcome to LT
![]() Some good answers already so I'll just add my 2p. ![]() Quote:
![]() Mine doesn't leak in heavy rain (so heavy that you have to stop driving)... but they are hand built cars so all different. If they do leak it isn't significant - I've left mine out in the rain with the roof off ... but it dried out with no issues ![]() Quote:
![]() The radiator plastic end caps are prone to failure - replace when you can. Quote:
HTH
#8 (permalink) |
Thanks for all the helpful advice. Assuming you have a place to work and not factoring clam removal, how difficult is engine work? Will I need to be replacing spark plugs, gaskets and what not on a regular basis? Or do they all hold up like you expect with a normal car?
#9 (permalink) |
Gamera -The Atomic Turtle
imo, the stock car is running on a toyota 2zz with a slightly different tune, so i'd expect it to be maintained like a Toyota Celica, motor-wise. Many folks are over 100k miles now Change the oil on schedule, do the annual brake/clutch fluid, tranny fluid, drive the heck out of the thing. But remember it's a Lotus, so one must be prepared for anything.
Lotus Elise #134 - June/2004 build date - BOE REV400 installed on stock motor w/stock cat/mani 336.4bhp, passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, etc. 0-60 = under 4 seconds. Build thread : http://www.lotustalk.com/forums/f160...seline-114302/ |
#10 (permalink) |
Zombie Hunter
Heck, when I got caught in a drizzle with my top off, I just sped up and amazingly, hardly any water got inside and I zoomed into my garage pretty dry. True story. (twice)
As for weather... it's actually pretty good in the heat, never driven in hard rain but did see water pooling by the sill like it was leaking in the gap between the door and body fender. Nothing major, but also saw water seeping in from window/top juncture during handwash. Other than that, with all the suggestions you have and your background, the simplest thing for you might be to buy a Noble. There are a few in TX and they are easy to register there. Leicestershire FTW!
My 2009 Elise for sale: MoMo SloMo MoFo Joyrides upon request w/lots o' cash money http://www.lotustalk.com/forums/f94/...-995-a-116554/ |
#12 (permalink) |
You need to modify the seats for 4-point harnesses, but doable, safe (got TÜV in Germany for it) and a easy fix. For harnesses for Schroth ASM, safest option, or go 5/6 point.
2011 Evora S 2+0 // carbon grey // diamond cut rims // charcoal leather // Schroth Rallye 3 ASM harness |
#13 (permalink) | |
#16 (permalink) |
Zombie Hunter
Tell that to Madame Helga and the Dungeon of Pleasure.
There is a full airbag in the steering wheel too. Read the embossed letters on the wheel, it will say it right on there that it's got the SRS.
#17 (permalink) |
You'll shoot your eye out kid. JK. Welcome. I think you'll find the Elise more trouble-free than the impression you have of it.
2010 CO Elise SC (R.I.P) 2012 Solar Yellow Evora S |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
