Metallic "rattle" from 3500 - 4500 rpm
I have a fairly loud metallic rattle/buzz coming from the rear of my '05 Elise. It happens from about 3500 - 4500 rpm, cold or warm and is worse when I'm on throttle. It sounds like it's coming from behind or under the engine, but hard to tell. A friend was following me the other day and he said he could hear it very loud and clear.
The local dealership diagnosed it as either loose baffles or a broken exhaust hanger. Neither was the case, since I just installed a brand spanking new cat-back from BOE. The rattle (or whatever you want to call it) is still there! Any ideas what it could be??? Thanks in advance. Last edited by Arjayc; 04-08-2012 at 09:57 AM. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
Ron
Ron Avery Winnetka Ca 2005 Lotus Elise 2011 Lotus Evora 2+0 |
#3 (permalink) | |
Painful Novice
Right around the resonant frequency of the diffuser (depending on whether you are naked back or still closed up). Also the lidbone has been known to make a rattle sound as well. A go-pro camera stuck on the back of your car looking down will settle the issue.
Storm titanium 2005 Elise with carbon fiber spoiler, BWR sway bar, BOE toe links, gPan2, LidBone, sector 111 wheel studs, Grey RAC Monolite wheels with toyo R1R, Team Dynamics 1.4 with Hoosier A6/R6s, Katana2 Supercharger, ECU with 265 flash. PPE headers w/decat, CEL angle eliminator, Silent touch catback, Rear Panel Eliminator, HKS intake, V2 fuel tank, Walbro255 fuel pump. HID lights. |
AKA: Captain Slow
My stage 2 exhaust made the same sounds at certain frequencies. The welds joining the brackets were cracked. (examine them carefully) It was a $10 repair at a local muffler shop. Now it is much stronger than stock, and it has lasted for two years.
2005 BRP Elise Sport, Stage 2 Exhaust, CF side scoops, CF splitter, Composite Worx seats, gunmetal stripes |
All rattles and buzzes are standard equipment on Elises.
I had a terrible buzz at exactly 3200 RPM. I mean loud. I offered a "bounty" on the buzz of $100 to the Toyota mechanic who does my simple maintenance. No luck. it eventually subsided. Now, the squeak behind the passenger seat, the squeak from the rear bushings, the rattle under the headlight switch panel, the rattle under the dashboard, the rattle from inside the drivers side door, they are all still there. I love my Elise, but I hate the way it sounds. And I'm an audio engineer so squeaks and rattles are especially annoying. But, as they say, it is what it is, and the Elise is not finished well.
Driving lights and a Lidbone. Oh, and a supercharger. |
#7 (permalink) |
Are the welds part of the exhaust system itself or are they the brackets that the exhaust hangers attach to or...?? I just replaced my exhaust with a cat-back system, so the mounting rod, muffler, clamps, tailpipe, etc. have all been replaced. So, if the welds/brackets are part of the exhaust itself, I assume they've been replaced.
#8 (permalink) |
to society
I have the 3200 rattle/buzz, the squeaky shocks or bushings and I just took care of the squeaky seat and dangerous speaker covers. The 3200rpm rattle was claimed by Sean of the former Rothrock Lotus to be in the transmission and that many of them do it. I don't believe it because I can replicate in neutral- he might not of heard the same noise I was asking about. I even switched out the belt tensioner since their was a tech bulletin on the 3400~ rpm rattle for the Toyota's with the 2zz but that didn't help. I checked for cracks around the muffler brackets- I might swap it for my extra muffler. Now that it's summer and the windows will be open that rattle will drive me crazy.
#9 (permalink) |
AKA: Captain Slow
Here's a link to my old post. Stage 2 exhaust repair ideas? (photos)
It turns out I spent $20 (not $10), but it was still a bargain. My cracks, as you can see, were on the exhaust itself. The solution was to clamp the brackets back into place and then run a bead weld around the "U" notch in the bracket , connecting it to the rounded surface of the pipe. Much stronger than stock, and no more buzz.
#11 (permalink) | |
1. The search function on this site wasn't horrible. 2. You knew exactly what to search for. I recently had a similar problem and had trouble finding the issue, so I started a thread as well. I hadn't even heard of the Stage II issue that GR82DRV outlines here and that ended up being my problem. Do you search on buzz or rattle? What if someone said they were having a mid-low RPM buzz and I said I was having a 3000 RPM rattle? After trying many of the fixes that I had found searching, I eventually got frustrated and started a thread. It wasn't until HKFEVER mentioned the Stage II issue in my thread that I learned it could be a problem. Sometimes when you have searched and searched and tried many fixes it just makes sense to start a thread. Clark |
#12 (permalink) |
Thank you! That's exactly what I was going to say... When you search for "rattle" you get 24 pages full of threads referring to anything from window rattles to someone that ordered a new Solstice. How is that even relevant?
#16 (permalink) |
J. Caesar
when i had my elise i had to have the brackets re welded twice and the muffler was replaced at least once. (stage 2 exhaust)
if your problem isnt the brackets, the shield, etc, then my guess based on my experience with my car was the packing inside the muffler. nothing you can do except replace the muffler. annoyed the heck out of me. my car was pretty much rattle and squeak free except for that. check it out and let us know what you find.
Vati. C6 ZO6. THE OBITS, YO! KEEP CRYIN! WHAA! REDNECK = PERSON WHO LIVES IN A DUMP BUT DRIVES AN ELISE! I never played by the rules, and I never really cared My nasty reputation takes me everywhere It is admitted by all that he was much addicted to women, as well as very expensive in his intrigues with them, and that he debauched many ladies of the highest quality; among whom were Posthumia, the wife of Servius Sulpicius; and Lollia, the wife of Aulus Gabinius. |
#18 (permalink) |
The Modervingian
Believe it or not, try removing the rear license plate and see if it continues. I went to a full frame around my plate with top and bottom screws (euro type @ auto parts store) and solved a bad rattle. Since you recently had exhaust work done, chances are your diffuser or heat shields are loose or not installed properly as well.
07 Magnetic Blue Exige S "Mostly though, it's just a triumph of British engineering." -Jeremy Clarkson |
#19 (permalink) | |
I made sure all the shielding was tight when I was in there. I also double-checked the diffuser panel to make sure everything was tight and aligned properly. All looks good. I'll have to check the license plate, bracket at the header and O2 sensor to see if any of those are loose. |
#20 (permalink) |
2006 111R Elise,Rev 400 supercharged ,BOE CAB intake, BOE surge tank, Mahle 10.5 pistons, Crower Maxilight conrods, Ferrea Valves & springs, Circuitworx oil pump gear,PPE headers and decat ,HIDs,SSC Harness bar,Nitron SA,Shaved V2 steering arms AP 4 pot calipers CL RC5+ pads,FF engine damper. Saikou Michi catch cans, NGK wideband.Toyota MWR E153 gearbox conversion and Exedy clutch LSD , SSC P&P Adaptronic, CompositeWorx SP1 seats ,Aussie-clamhinge. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
