Good for you.
Stock: “Excuse me”
Stebel:
“HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
a) Early cars have wobbly shift towers. Look up Stan’s Mod (bolt and spacer;
http://www.billswebspace.com/ShifterReinforcement.pdf) and
Sector 111 long thru bolt that terminates under car:
re-ENFORCER - Shift reinforcement for the Lotus Elise and Exige - Sector111
6. As per some engine builders on these sites, wait AT LEAST 10 (or 20) minutes after coolant has reached full operating temp before engaging cam switchover.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
9. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
How to Search:
