Oil light flashing. - LotusTalk - The Lotus Cars Community
Old 11-13-2012, 08:02 AM   #1 (permalink)
Head LOONY
tvacc's Avatar
Oil light flashing.
Hi all,
First time we took the Elise out after the trip back from Orlando. We took it to a LOONY breakfast on Sunday. When we got back, still had a few gal of fuel so I wanted to burn that off before putting car away for the winter. Pulled out of the driveway and the oil light flashed. Drove a few blocks and same thing. Not at idle, just driving. I checked the oil level, and all is ok.
First some ideas on what it could be. I am thinking that the wire might be loose on the sender unit. But I had another thought. Perhaps it is time to put in an oil pressure gauge and oil temp gauge.
I see I can buy the cluster holder from blackwatch. Dont see it anywhere else. How about the guages? Mechanical oil pressure with a hose, or do I go with electrical with a sender.
Thanks in advance for the replies.
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus, Drive Fast Take Chances, 93 Caterham 7, 71 Elan.
tvacc is offline   Reply With Quote
Old 11-13-2012, 09:17 AM   #2 (permalink)
Chrome orange is faster!
Drew09's Avatar
Possibly a bad oil pressure switch.
Drew09 is offline   Reply With Quote
Old 11-13-2012, 09:18 AM   #3 (permalink)
I wouldn't assume it's a loose wire on a sensor until you've exhausted every other possibility. Did your car get the oil cooler recall?
Very dangerous to your car's engine to continue driving with the light on!
2009 Elise SC
Surge is offline   Reply With Quote
Old 11-13-2012, 09:24 AM   #4 (permalink)
Drew09's Avatar
The recall isn't out until Jan.
Old 11-13-2012, 09:35 AM   #5 (permalink)
Type82's Avatar
I sent you a PM.
Type82 is offline   Reply With Quote
Old 11-13-2012, 09:59 AM   #6 (permalink)
unamused northeasterner
Jack FFR1846's Avatar
Don't assume it's a bad sender. Perhaps get the sandwich eliminator Toyota adapter and try again without the oil coolers hooked up. If the light's still there, replace the sender, but be ready to do an oil pump.
Jack FFR1846 is offline   Reply With Quote
Old 11-13-2012, 12:56 PM   #7 (permalink)
90% go, 10% show...
Apex_in_sno's Avatar
Originally Posted by tvacc View Post
Hi all,
Go with an electrical gauge, and it's not your oil pump, if it was you'd have the oil light on all the time....
BTW, these types of pressure switches ground when on (on in this case is low pressure), so it won't be a loose wire...
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline   Reply With Quote
Old 11-13-2012, 04:11 PM   #8 (permalink)
You store your car with an empty tank?
2005 Lotus Elise Katana2 and much more
JohnnySniper is offline   Reply With Quote
Old 11-19-2012, 10:21 AM   #9 (permalink)
Head LOONY
tvacc's Avatar
Just saw this. Yes. I store my cars with the tanks as empty as I can. I also put in blue Stabil.
My thoughts are that with the Ethanol in the gas, why would you want more of this corrosive stuff in you tank? Get it as low as you can and then put in an ethanol stabilizer like the blue stuff from Stabil. It is the marine version of the product.
You will get phase separation over the winter. If I can treat 1 gal with something that may inhibit seperation, that is easier then treating 10 gal. And I know that if you fill you tank, you get less chance of absorbing water, but with the tank sealed, will you get that at all? In my other Lotus cars with fuel cells, I try and drain them completely.
Open to more ideas on the subject.
At the cost of this ethanol crap, why dont we put pressure on the goverment to stop it? It is only increasing the cost of gas, food and meat. It is just crazy.
edit. I see you are in Buffalo. Why not join the LOONYs? We do have a good time.
Tony Vaccaro
Old 11-19-2012, 10:25 AM   #10 (permalink)
Head LOONY
tvacc's Avatar
I have purchased the gauge pod from Black Watch. I have ordered an oil pressure and oil temp gauge with a sending unit for both, the light and a T to put it all together. I will install it. Let you all know what happens.
Tony Vaccaro
Old 11-19-2012, 11:23 AM   #11 (permalink)
It's a big go kart!
Ukhtar's Avatar
Good luck with the install, having peace of mind by using that oil gauge is priceless.
David Kaiser
Lotus Technician
Exige and Elise
Ukhtar is offline   Reply With Quote
Old 11-20-2012, 11:00 AM   #12 (permalink)
Gamera -The Atomic Turtle
komiko's Avatar
next on the to do....
Lotus Elise #134 - June/2004 build date - BOE REV400 installed on stock motor w/stock cat/mani 336.4bhp, passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, etc. 0-60 = under 4 seconds.
Build thread :
http://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline   Reply With Quote
