Cleaner or easier? Because there are plenty of hardwired backup cams that would be a cleaner install than that. None of them would take 10 minutes to install, though...
I thought it would via the speed and RPM or some other checks like that. It does state that the adapter looks at things like speed when describing it on their website and that is what triggers the cameras on.
Speed and rpm are always positive, so they don't give any indication of being in reverse. At best, the camera would automatically turn on when you're just going slow which would be terribly annoying in stop-and-go unless they have an accelerometer, too, that can tell when going backwards
I thought it would via the speed and RPM or some other checks like that and can figure out what gear you are in. It does state that the adapter looks at things like speed when describing it on their website and that is what triggers the cameras on.
I would think the best option here would be to install a better single DIN HU that supports a camera and install a backup cam to go along with it. Costs would be under $500 easily. I had to replace the backup cam video cable on my Evora a couple weeks ago which required removing the rear interior, side sills and parts of the dash. For the Elise I assume it would be much easier to run the cable and then install a license plate mount for the camera. The HU swap on the Elise is a piece of cake and I did that in under 2hrs. That way you get a much nicer system and the camera to boot!
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
