#21 (permalink) |
Chris
Did not notice the clown shoe...I've owned several in the past...
2005 Magnetic Blue Lotus Exige Drivetrain: Honda K20A Type R | Innovative Mounts | Arqray Ti | Innovative Exhaust | Custom Intake | Hondata KPro | proRAD | Setrab Cooler | Innovative Shifter | KTuned | V2 Fuel Tank | Radium Coolant Tank | Aero: Exige Clams | Reverie | TWRD | Craftsquare | Denag | IMRP | BSK Hatch Suspension: Nitron SA | V2arms | RTDbrace | Volk CE28N | Toyo R888 | DBA4000 | Pagid RS14 Interior: Recaro SPG | Willans | WorksBell | Sparco Wheel | aspec Ti knob |
| Sponsored Links | |||
Advertisement | |||
#24 (permalink) |
Looks awesome! I would have had some separation where the access panels usually are, but that's just me. The profile picture of the front says it all. I am very impressed with how well it turned out, given that you molded everything front scratch.
#26 (permalink) |
Professional Russian
Loving it....because of this im finally going to get started on my busted clam and do something similar, so you created the shape with foam and fiberglassed over it?
2005 Elise for sale, PM me or Email lotus (at) team806graphics (dot) com |
#27 (permalink) | |
another forum member goes into more detail about this: Project Build: Elise GT Widebody Just make sure your materials are compatible. Epoxy's pretty good about not eating away at the foam but other materials can make a real mess out things. In my case I cut and prepped my work area with a grinder and then stuck a chunk of foam to the inside of the clam with spray adhesive. After that all you've got to do is shape it how you want it. |
#33 (permalink) |
No. Searched high and low for the manufacturer & type of plug. The male end of the plug might have a manufacturers name on it somewhere but I know the female end gave no clues. Probably the easiest would be to get the plugs off a parts car.
I did work out the pinout though. I have it written down somewhere if you want it. Are you replacing the clam or modifying your existing one? How far into the project are you? |
#34 (permalink) |
Man if you could get me the pinout, that would be awesome and I've already got the lights (off ebay for $1000 for the set) and I'm modifying a hit clam and thats almost done. (about 2 weeks left) and then ill be ready to do the wiring.
Lotus Elise 06' Touring |
#35 (permalink) |
Surprisingly I was able to find it pretty quick unfortunately, I must have written it down pretty quick also cause I can't make out what I have going on with pins 6 & 7 and possibly pin 5. I know they have to do with the turn and driving LED's (nothing special just pos & neg leads).
Connect the ones you know are correct first and finish it up testing a ground on the remaining pins. If you can get some used plugs then It should be easy to guess whats what by the wire color & gauge. If you want the driving lights to dim at night then you could prob accomplish that with a relay that switches when the headlight positive lead is hot. If you think you need more clarification. I can get my clam off and do my best to fill in the blanks for you. So heres what I had scribbled on paper. pin 1. Turn LED - Negative ground 2. Driving LED night (dimmed) + Positive lead 3. Low Beam + (9005) 4. High beam + 5. Driving LED day (bright) + Positive 6. * LED - 7. * LED + 8. High/ Low beam - negative ground 9. (unused) |
#37 (permalink) |
Chris
Impressive teamwork gentlemen. Post your results, I really like the 2011 headlamp shape
#39 (permalink) |
Hey Man so im almost ready to start working on the clam. And I've got a question did you have any problems when the lights were put into place? As in crash structure being to close or modifying anything on the inside?
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
