that dog has a poofy tail
Short throw shift kit?
Hello all,
Just purchased my first Lotus ('05 Elise). the only immediate flaw I can find with the vehicle is the shift action. My DD is a 997 C2 with the factory short throw shift kit; it feels like the proverbial rifle bolt. by comparison, the Elise's gearbox leaves a fair bit to be desired. I'd like to shorten the throws and/or close up the space between gates. I've searched LT, Sector 111, etc. and can't find any info about an aftermarket short-throw shift kit. Anything out there? TIA! |
| Sponsored Links | |||
Advertisement | |||
please don't hit my car
1) Search for the LETSLA kit and also visit this link:
LETSLA Install You can shorten the throws at the expense of effort required with such a kit. I have no first hand experience with LETSLA. A lot of people love it, but then there are reviews like post #16 of this thread: Is the LETSLA a "failed product"? 2) heavier shift knobs help Two other mods that I've actually done have improved my shifter feel tremendously: 3) Reinforcing the shifter housing, which actually moves a bit due to the thin aluminum floor. Do a search and see that you just need some hardware, like bolts and nuts that you can try to source. Sector111 also has the parts off the shelf called the "reEnforcer": http://www.sector111.com/track_parts/re-enforcer.cfm 4) Motor mounts. Basically prevents the transmission / engine from moving around as much. Huge improvement, especially when driving hard. But these cause a bit more vibration in the cabin. For cars driven aggressively on the street or track. http://www.sector111.com/track/highl...trackmount.cfm Edit: There was a shifter recall on some '05 models. Lotus replaced the shaft with something a bit more robust for fear of breakage. May want to check whether yours was ever replaced. Elise Shifter Recall Last edited by Vantage; 02-12-2011 at 04:48 PM. |
No problem. Short of designing a whole new system, this car is never going to feel like the best shifting cars out there, but after the housing mod and motor mounts, I'm pleased. Vast improvement over stock.
There used to be a B&M shifter for these cars, but the new shifter after the recall made them superfluous. |
Home Grown
This might help
http://www.billswebspace.com/ShifterReinforcement.pdf
Here is an article on how to reinforce the shifter housing to the aluminim floor. There is a threaded hole there on an 05that you just have to screw the new bolt into. It tightens up the shifter quite well. You'll have to search the threads on how to take the center console out before you do this mod. Other than that it was quite easy to do. Use these ideas if they look appropriate for you.
2011 Evora Starlight Black/Gold. 2005 Elise Saffron Yellow- (sold) 2001 Porsche Boxster (sold) 2008 Nissan Xterra 2000 Mitsubishi Eclipse GT |
#9 (permalink) |
AKA: Captain Slow
While participating in a track day in northern Illinois last year (Black Hawk), I met a couple of owners who had shortened their shifters. They told me they simply cut down the shaft, and I presume they did some re-threading. As I recall, their modified shifters were at least 1.5 to 2 inches shorter than stock.
I like the idea of a shorter throw, even if it takes slightly more effort. I formerly owned a Miata, and I loved shifting with tight flicks of the wrist. |
#10 (permalink) | |
Teacher + Lotus = How?
I just installed the Letsla kit, and I will say it is a great upgrade, especially with motor mounts. But I noticed that where I have it set up on the 2nd lowest setting (the one troy ships it to you in) giving the cables a little bit more throw gave the shifter a better/more exact response. Where I am not COMPLETELY done with it yet, weather permits the final "tuning" I can say that from what I have so far, the more extra cable the shifter cables have, the better then shifter reacted as well as felt in my hands. My suggestion is to definately get the latest letsla kit from Trueleo, as it comes with the necessary items to do "Stan's shifter mod" (you will need use a grinder to get the spacer and the bolt to your shifters specs, at least I did). And the rest of the install went well, and Troy did an awesome job helping out on the phone, even on a saturday (late into his evening as he lives on the east coast). That is what you call awesome customer support.
2005 Lotus Elise Graphite Grey - Salvaged title being built with SSM class in mind - new replacement. ![]() 1997 Dodge Dakota Club Cab V8 -Nice to have a truck again. 2005 VW Passat Station Wagon TDI (harder to find than the lotus?) 2005 Lotus Elise Starlight Black - Sold |
#11 (permalink) | |
Shortening the shifter shaft also puts the gearshift further from the steering wheel, which isn't ideal for performance driving either.
#12 (permalink) | |
Modded but still NA! |
#17 (permalink) |
I did the shifter brace mod and noticed no difference at all. I was a complete PITA though.
I was really hot for a Letsla at first, but now I've gotten used to the shifter and it doesn't bother me. You can shift with the stock shifter fast enough to lunch the transmission as it is. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
