Turbo Lotus Elise..... - LotusTalk - The Lotus Cars Community
Old 12-11-2012, 11:27 AM   #1 (permalink)
Just picked up a N/A Elise over the weekend. I wouldn't call the car fast... I know supercharging seems to be the method of more power here but I prefer a turbo car. I know have a shop make a full custom kit for a killer deal. The only question I have is how well do these motors hold up with appropriate boost and a solid tune?
Sburke is offline   Reply With Quote
Old 12-11-2012, 11:32 AM   #2 (permalink)
TyMurray's Avatar
Are we talking stock long block? If so to be safe I wouldn't go over 8 psi. Also you have to worry about the tranny which will start going out around 300hp...
*edit*
Also it may not be fast in a straight line but it will eat most cars alive on the twisties. I had a FD Rx7 before my lotus that was making right under 500hp, had full suspension all that fun stuff, and was a blast to drive on the straight, and the twisties...after driving an elise I thought the FD responded and felt like garbage =P
1993 VR Rx7 Single Turbo - SOLD
2012 GMC Sierra 1500 -Daily
2005 SY Lotus Elise - Sold =(
Exocet - Current project
TyMurray is offline   Reply With Quote
Old 12-11-2012, 11:54 AM   #3 (permalink)
*edit*
Don't get me wrong the Elise is the best handling car I've ever owned. I test drove one a few months back which left a sour taste as I thought my previous EVO handled better so I bought a Esprit as I've always wanted one. My Elise drives nothing like the one I test drove months back so there must have been something seriously wrong with it.
I would like to keep the stock motor and keep it at 300HP. I'm not wanting a 1/4 mile car but just a little more power. I had it out in the mountains two days after picking it up and it was pure smiles but just wished it was a tad faster on the straight sections.
So 300HP on the stock motor with a good tune and not launching the car I should be able to not worry?
Old 12-11-2012, 11:54 AM   #4 (permalink)
I would suggest you search on turbo and Elise. There a have been bad turbo kits and some good ones. lot of good info on this BBS
one of the harder problems is getting a ECU that will run a correct tune.
I run 275hp force feed turbo kit and would say anyone wanting a turbo Elise should be ready to work through issues.
That said I really like turbo Elise it is alot of fun.
lotus90 is offline   Reply With Quote
Old 12-11-2012, 12:00 PM   #5 (permalink)
Nothing is straight forward and easy with any Lotus!
I should just have a 4g dropped in and call it a day
Old 12-11-2012, 12:43 PM   #6 (permalink)
Cicero's Avatar
I've never heard of a turbo elise that wasent constantly giving trouble. Have you ever seen this?
Vision Function Lotus Supercharger Kit
Cicero is offline   Reply With Quote
Old 12-11-2012, 12:55 PM   #7 (permalink)
100% Braj
SwingLo's Avatar
Look for posts from WhatADSM
I haven't seen his car but my understanding is that he's done some wicked stuff with a turbo and it's north of 400hp at the wheels
You are sleeping. You do no want to believe. You are sleeping.
SwingLo is offline   Reply With Quote
Old 12-11-2012, 01:39 PM   #8 (permalink)
I, too, prefer a turbo over a supercharger but they are A LOT more work on these cars. I'd recommend going with a FF kit (if you can find one) or a Radium kit. Just about everything else is going to require going custom, which obviously can become extremely expensive and can introduce a plethora of new complications. Avoid anything "Hass" like the plague.
You say you know a shop that can make a custom kit for a "killer deal". I've heard this literally dozens of times on here and it rarely ends up being the case. There are a lot of little eccentricities that these cars possess and custom kits almost always end up being huge nightmares.
300hp on the factory engine is doable but I wouldn't go much higher than that. I've heard numbers all over the place for what a non-tracked transmission can handle but from what most people say I think you should be OK with the power 8 psi or so would give you on factory compression. Might want to upgrade clutch, though.
2006 ST Exige - GT-28RS, Darton sleeved/decked/line-honed, ARP hardware, Wiseco 8.8:1 pistons, MWR valves/springs/retainers, RC injectors, Walbro pump, CWorx oil pump, Moroso oil pan, S111 TrackMounts, Spearco intercooler, GReddy catch-can, Turbosmart BOV, Fidanza clutch/flywheel CF Panels/scoops, S111 Rear Diffuser/Rear-Panel Delete/discNOIR Brakes w/SS lines/RTDbrace/Towhook, APR CF Splitter Alpine unit w/MBQuart, CF binnacle/shifter, Schroth harness, S111 shift brace
bpfergu is offline   Reply With Quote
Old 12-11-2012, 02:13 PM   #9 (permalink)
Mini Racer
Definitely need to upgrade your clutch and get an LSD. Other than that, if the car is for street use, all of my research indicates that you're fine at 350 whp!
I'm working on my turbo kit now and hope to be done by February.
GSXtasy is offline   Reply With Quote
Old 12-11-2012, 02:36 PM   #10 (permalink)
All Show and Slow
pray4mojo's Avatar
He has a K-series engine, no?
pray4mojo is offline   Reply With Quote
Old 12-11-2012, 02:43 PM   #11 (permalink)
It's a shop I've had do small work before which turned out great. Also they have out together a ton of impressive builds.
3500$ for manifold, turbonetics 50 trim, turbonetics gate, water to air intercooler, all pluming and exhaust. That's including labor too
Old 12-11-2012, 03:05 PM   #12 (permalink)
No offense, but I"ll believe it when I see it. I think both you and the shop are massively underestimating the time it will take to dimension, fabricate, and install a custom kit for this car. On top of this, finding a way to mount the piping, intercooler, etc., isn't an easy task starting from scratch. Unless they are doing the labor (including fabrication) for free or next to nothing (and even then quality parts will eat up a lot of that 3500 very quickly) I just don't see you getting a quality kit for 3500. Again, please prove me wrong and also tell the shop that is doing it if they can meet these requests to head on over here because they will make a lot of money selling this kit to others.
Old 12-11-2012, 03:06 PM   #13 (permalink)
330.6whp + 1850lbs = fun
rskdsk's Avatar
My car has 281 rwhp at 10-11 psi ... stock internals, upgraded clutch and flywheel ... over 18k miles and running strong.
rskdsk is offline   Reply With Quote
Old 12-11-2012, 03:34 PM   #14 (permalink)
sturgeongeneral's Avatar
Do a serch here. LOTS of issues with turbos. Adding a supercharger is a great choice. All the bugs worked out, the math done, and the ECU tuning is already there.
05 Elise
56 VW Dune Buggy
Lightweight fiberglass toys that simulate street legal rocket ships!
sturgeongeneral is offline   Reply With Quote
Old 12-11-2012, 03:50 PM   #15 (permalink)
tommyc's Avatar
A 4g63 is really heavy. Great motor but is the wrong way frt back for the elise. Also the 2 zz is not as solid. A k24 honda with a k20 head would be best for big power. I would suggest a vf2 or boe rev 400 and you will have permagrin! But as with th evo be prepared to break stuff! Tommy
Sent from my Autoguide iPhone app
05 elise ardent red sport touring VF1 s/c, pro rad, arquay twin, etc etc etc
05 elise GG sport touring BWR s/c Charliex s/p dent in chassis=total loss
11 BMW 128i conv wifes car
03 GMC Yukon
90 eclipse gsx 420 whp sold
04 civic si sold
tommyc is offline   Reply With Quote
Old 12-11-2012, 04:27 PM   #16 (permalink)
Lotus F1's Avatar
For the best in "Turbo"
https://radiumauto.com/index.php?p=p...&id=2&parent=0
Lotus F1 is offline   Reply With Quote
Old 12-11-2012, 06:50 PM   #17 (permalink)
Me!
POWERRRRR!!!!
Me!'s Avatar
Yes he has a supercharged K-series. It looked nicely done too!
Super duper charged 2007 Storm Titanium Exige S w/ sunvisor delete
Me! is offline   Reply With Quote
Old 12-12-2012, 02:14 AM   #18 (permalink)
rskdsk's Avatar
There is nothing like the jet engine like turbo thrust ... and with the FF 275 ... you even get the sound of a turbine engine.
Old 12-12-2012, 02:21 AM   #19 (permalink)
rskdsk's Avatar
slight correction- 9.5 psi gave 277 rwhp, 10.5 psi gave 281 rwhp, currently have boost set at 6 psi at 240 rwhp. also running water/methanal to be safe.
Old 12-12-2012, 04:14 AM   #20 (permalink)
Is there a way to just have my tuner tune with the stock ECU? I would hate to go standalone for a simple bolt on turbo kit that can't even crack 300hp safely......
