Windshild cleaner issue - LotusTalk - The Lotus Cars Community
Old 01-01-2012, 02:37 PM   #1 (permalink)
Hello,
My windshield cleaner seems to have petered out this weekend. The tank has a reasonable amount of fluid left (of course) and I don't see anything blocking the nozzles... but when I pull the lever back, I only get dribbles on the front half of the windshield. I figured I'd better ask the experts first before I go dinking around looking for what I'm guessing to be a leak?
ithurtus is offline   Reply With Quote
Old 01-01-2012, 02:49 PM   #2 (permalink)
G-200 Driver
kestrel74's Avatar
I've never used the windshield wiper....let alone the fluid.
Elise #2292 / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
Old 01-01-2012, 03:19 PM   #3 (permalink)
Gamera -The Atomic Turtle
komiko's Avatar
nozzle plugged , or lines leaking, or bad pump. My guess would be plugged nozzle.
Lotus Elise #134 - June/2004 build date - BOE REV400 installed on stock motor w/stock cat/mani 336.4bhp, passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, etc. 0-60 = under 4 seconds.
Build thread :
http://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline   Reply With Quote
Old 01-01-2012, 05:20 PM   #4 (permalink)
Klint's Avatar
stick a needle pin through the nozzle, that should clear up whatever is blocking it.
Lotus Specialist Technician at Dietsch Werks
2005 (Build date: Sept. 04 #484) SY Lotus Elise- Sports Pack, Touring Pack, Black pack
www.Youtube.com/keleentproductions
Klint is online now   Reply With Quote
Old 01-01-2012, 05:48 PM   #5 (permalink)
invictusmaneo's Avatar
check valves may have gone bad as well. lotus garage has them for cheap, and its a quick swap under the front access panels. if the needle trick doesnt work you can pull the check valve out (its just snug fit in there) and blow in it..one way shouldn't allow flow, the other should.
'10 Chrome Orange Evora
invictusmaneo is online now   Reply With Quote
Old 01-02-2012, 04:55 AM   #6 (permalink)
German Reimport
Mr.C's Avatar
I'm 99,98% sure that your little mesh screen in the pump is clogged up from the lag of use because
Just remove the fluid tank (slides out towards the top) disconnect the line, empty the reservoir and pull out the pump.
There is a little mesh screen in there which clogs up when the windshield washer is not used frequently.
What do I win in case that I'm correct
Mr.C is offline   Reply With Quote
Old 01-02-2012, 09:20 AM   #7 (permalink)
Mr. C you're correct. You win the horror show I found inside the extra fluid tank and the needle I used to realign my nozzles after misaligning them so badly they became trunk/engine cleaning nozzles.
Thanks all
Old 01-25-2013, 04:44 PM   #8 (permalink)
kidtroopa's Avatar
Thanks for the heads up about the sludge. That was my culprit as well. This is why I love LT.
kidtroopa is offline   Reply With Quote
Old 01-25-2013, 07:59 PM   #9 (permalink)
How do you see in the rain?
nate379 is offline   Reply With Quote
Old 01-25-2013, 10:17 PM   #10 (permalink)
Yea that stuff is nasty. I sprayed it out with a hose on to my driveway... it was stuck to the pavement for a good month until I manually scraped it off.
Old 01-26-2013, 05:50 AM   #11 (permalink)
G-200 Driver
kestrel74's Avatar
hahaha......got caught in the rain once in 2006 and had rain-x on it, so didn't have to use the wiper.
Old 01-26-2013, 06:11 AM   #12 (permalink)
tommyc's Avatar
Rainx is the best. I have never used the wiper as well!
Sent from AutoGuide.com App
05 elise ardent red sport touring VF1 s/c, pro rad, arquay twin, etc etc etc
05 elise GG sport touring BWR s/c Charliex s/p dent in chassis=total loss
13 BMW 328i conv wifes car
03 GMC Yukon
90 eclipse gsx 420 whp sold
04 civic si sold
tommyc is offline   Reply With Quote
Old 01-26-2013, 06:15 AM   #13 (permalink)
My washer tank has been dry since I bought the car, how weight would it save to just remove it?
Sent from my Autoguide iPhone app
Silver_Surfer is online now   Reply With Quote
Old 01-26-2013, 07:22 AM   #14 (permalink)
The tank weighs a fraction of a pound empty, a few pounds full. Just take a dump before driving instead
