05 Elise - 100K mi. - Fault codes - Input/Opinions? - LotusTalk - The Lotus Cars Community
post #1 of 6 (permalink) Old 01-15-2013, 07:48 PM Thread Starter
lotusdriver2001's Avatar
Car: 2005 Elise, Totally stock, 100K miles (plus a little), no history of any troubles.
Conditions: Parked car at work. After about one hour return to car to leave. Car fires up and idles fine. Back out of parking space, drive about 30 yards to parking lot exit. Accelerate in average way onto main street (same way I've done it for the last 100K). Immediately the engine loses power, begins oscillating RPM, won't accelerate at all. I pull over and listen to the idle. MIL light on steady. No obvious noises except a slight bit of what appears to be serpentine belt slippage - has been slowly getting worse for a while - but belt is still there and working. Engine idles very well. Step on the throttle and the engine begins oscillating again, no power, and sounds like it's running on two cylinders.
Car towed home. Damn good towing job!
Got the following fault codes:
P0076 - Intake Valve Control Solenoid Circuit Low (Bank 1)
P0508 - Idl Control System Circuit Low
P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open
P0447 - Evaporative Emission Control System Vent Control Circuit Open
P2648 - A Rocker Arm Actuator Control Circuit Low (Bank 1)
P0134 - O2 Sensor Cucuit No Activity Detected (Bank 1, Sensor 1)
The last code (0134) is listed as "Pending". All others are "Stored".
(All data collected with Gendan software and thes are the descriptions it provides.)
After downloading codes I reset the MIL and disconnected the battery for about 2 minutes. Reconnected battery and started car. Engine behaves the same - Oscillates after trying to stall upon throttle application. Check engine light has not come back on after idling for about 5 or 6 minutes... until the smoke detector in the garage went off.
Any ideas, suggestions, etc.?
lotusdriver2001 is offline
post #2 of 6 (permalink) Old 01-15-2013, 11:14 PM
Mulholland>SCC
agirls's Avatar
I would check fuse R6.
R6 fuse blowing
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
agirls is offline
post #3 of 6 (permalink) Old 01-15-2013, 11:26 PM
Mulholland>SCC
agirls's Avatar
Btw, R6 is located in the engine bay. A diagram can be found in your owner's manual on page 137. When you get a lot of codes, it can be an electrical problem such as a fuse.
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
agirls is offline
post #4 of 6 (permalink) Old 01-16-2013, 12:26 PM Thread Starter
Perfect!
Thanks for the input. Nailed the answer! Damn fine job!
Thanks so very much
Dennis
post #5 of 6 (permalink) Old 01-16-2013, 02:15 PM
Mulholland>SCC
agirls's Avatar
Sweet! I was wondering if I steered ya in the right direction. Checking fuses is much cheaper than towing it to a repair shop.
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
agirls is offline
post #6 of 6 (permalink) Old 01-16-2013, 06:43 PM
Gamera The Atomic Turtle
komiko's Avatar
sweet work girl!
Lotus Elise #134 - S O L D BOE REV400 street car built at BOE in KC. , Stock motor, low boost w/stock cat/mani, 292whp, (5.95 lbs/hp) passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, BOE Oil Cooler Relocation, BOE Surge Tank/750cc injectors, BOE Race Links, MWR Rear Lift Kit etc. 0-100 = you bet!
Build thread :
http://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline
Human Verification
