Argh! Gas cap won't open!
Has anyone ever had the gas gap stuck closed? I tried a search and didn't come up with anything...
I have an early model 2005 elise. I hadn't driven it in about 3 weeks. Got back in and noticed i forgot to fill up on my last drive. I still had a 1/4 tank so i drove for 30 minutes or so before stopping at a gas station. When i went to unscrew the gas cap i notice it was closed very tightly. I really had to give it an unusually strong twist to get it to budge. After i got it loose i continued to unscrew (about 1 more turn) and then heard a "click" - and encountered some resistance again. Try again and the same thing happens. It's as if it starts to open and then the screw catches another thread.... Anyone ever had this happen? Did i maybe miss align the cap with the thread last time i put it on? I'm now down to nearly empty and have no idea what to do. I'm thinking i may have to flat bed it to the dealer because i'm almost out of gas... thoughts? thanks in advance!
Pauli33 - Somerville, MA ----------------------------------- 2005 BRP Elise 1987 Porsche 930 - Gone but not forgotten |
Yes. It became more common on my car. And it is really not totally stuck, it just feels like it. If I applied enough leverage, it would eventually open.
#3 (permalink) | |
Did the same thing happen to you Randy. Did you just solve it with more turns?
Uh... so remember that epic fail thread... yeah, that'd be me now...
I tried using some pliers to get more leverage. I tried to twist and pull the cap off. unfortunately the "top" of the cap came off instead. What i'm left with is this. Excuse the poor quality pic, it's from my camera and it was in my parking garage... I tried to use a wrench to twist the white part but i can't get a grip. So now i'm completely lost. Any ideas?
That would be too much leverage.
![]() ![]() You can remove the outer aluminum ring if it helps with clearance. And of course... there is removing the rear clam. ![]() If it was me, I would try some pliers into the spoked area of the plastic and see if you can turn it. But if the top separated, it must be pretty stuck.
#8 (permalink) |
Thanks for the suggestions everyone.
I'm actually gonna sleep on it. ![]() I don't have the proper tools on hand right now anyway.. and i don't want to risk breaking anything else I'll post progress as soon as i've got more news.Feel free to chime in if you have any other ideas! Cheers, -Paul
#9 (permalink) |
Bump for suggestions from the weekday crowd...
Haven't really tried any new approaches. Going to pick up a pair of locking needle nose pliers today and try it out. Anyone have any other thoughts?
#10 (permalink) |
Finally
Also make sure you buy a replacement cap. Once you get the old one out you'll need something else to put in it's place otherwise you will get a CEL.
Bob in NJ 06 Sport Elise # 23 Stage II/Micromirror/Green wire mod/S111 tow hook/BWR front plate holder/Green filter/desnorkled/HID's-Hi & Low/Stealth Bulbs. |
#12 (permalink) |
McLareghini Bugatterrari
I drove around for 24 hours without a gas cap and got no CEL.
xtn
