16" all around
Best way to remove paint off wheels??
Ok, ive tried doing a little research about the elise "standard" wheels and believe the conclusion that the wheels are originally powdercoated black, and then painted silver last.
Say i want to remove the silver paint off the wheel, and just get down to the base powdercoat. Is there a paint remover that would be suggested? I just would like to get down to the powdercoat, re-sand, and get a new coat of paint on the wheels. On my old S2000, before I got my wheels powdercoated, I used "aircraft paint remover" bought at a walmart, which got the all the paint, and clearcoat off and down to a smooth base surface. would "aircraft paint remover" be suggested to get down to the base of the wheels, or would it be too harsh? Or would anyone suggest just to strip down past the powdercoat, and get down to the aluminium cast of the wheels? Any suggestions would be greatly appreciated, as I would like to be able to do the wheel paint removal/strip process at home. Thanks! ![]() |
Drunk on alcohol
I assume if you strip off the paint, the powdercoated layer will be stripped as well. I would suggest sand blasting or get them re-powdercoated and the shop will sand blast it for ya.
'06 Evo IX Stage 1E Tuned by Road Race Engineering: Stock:turbo,intake,internals,ECU,Walbro 255lph fuel pump,RC Engineering1000cc Injectors,Espelir downpipe, RRE High Flow Cat, AVO catback, RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com |
#3 (permalink) | |
16" all around
i guess i'll be doing a paint strip/removal down to the base alloy of the wheel. |
Drunk on alcohol
are you gonna paint the wheels yourself?
Sticker Guy
you have to test a spot first but I think aircraft remover would remove the paint and not the powdercoat if you work fast. Many years ago working for an American OEM we had coil spring issues. Much testing was done in salt spray chambers and other things to attempt to intentially weaken or partially remove the powdercoating, then put them on the spring cycling machine. (which as soon as they had some rust on this particular app they would shatter after only a couple thousand cycles- they were supposed to be able to endure one million before failure). Anyway, aircraft stripper would barely touch the powdercoat. We would soak them, leave them in a plastic bag for a week with it on, and it still would still only remove about 20% of the powdercoat.
"Starshield" Group Buy: http://www.lotustalk.com/forums/showthread.php?t=51323 ChuforiaGraffix.com Custom decals, magnetics, banners, stripes, racing numbers,etc.SweetDaddyDelicious@hotmail.com |
#6 (permalink) | |
16" all around
#7 (permalink) | |
16" all around
#8 (permalink) |
insert clever title here
Isn't it possible that the silver is a powder paint as well?
Either strip all the paint, or just paint over the powder paint that's already there.
#9 (permalink) |
Drunk on alcohol
You also have to scuff up the paint so the primer/paint will stick to it. Ask your powdercoating shop what grit paper to use to prep it.
#10 (permalink) |
McLareghini Bugatterrari
I'm suprised if it's true that they painted over wheels that were already powdercoated.
xtn
#11 (permalink) | |
16" all around
#12 (permalink) | |
1/3 Rotweiler, He Crazy
Dean 2006 Pontiac GTO 2006 Infiniti G35 2008 M-B C63 AMG 1997 BMW 318 iC |
#13 (permalink) | |
#14 (permalink) |
I just had a thought, the black might not be paint but may instead be an e-coat. It's still like a paint (ie, it's a layer of plastic), but is applied differently and often used to protect metal castings. Might be less expensive than painting.
#15 (permalink) |
Way back in the day....
I had a Austin Healey 3000. The club went to a shop that did bead blasting. I saw the owner take the word Camel off a cigrette. Very expensive but does no harm. The shop was out side College Park Md on Rt1. That was in the 1980s. I do not know if the shop is still around. If I wanted to take paint off a wheel that is what I would look for. John |
#16 (permalink) |
Elise...Best Daily Driver
The silver metalic is water borne paint and the all of the base lotus exige and elise wheels are black power coated. It is the toughest stuff to get off. I have may esprit wheel down to raw aluminum so I can scrub on them when ever I choose it is nice but it was a bear to get to. Soak each wheel in a five gallon vat of BIX stripper and you will get the silver off then you will need to glass bead the final on the black. The BIX has little effect on the the powder coat.
2005 Elise, Starlight Black/Red, stage II exhaust, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and custom wheels that favor the M250, no understeer and a variety of the simple mods. |
#17 (permalink) |
At Dawn They Sleep...
Wish there was a way to completely take the silver paint off and leave black powder coat intact...
05 Elise: Ardent Red, Touring Pack, StarShield, Hard Top, scrape guards 98 Jeep Cherokee Sport: red, dents, scratches, dirt |
#19 (permalink) |
#334
I had to remove the Lotus black powder coat without damaging the wheel because I was going to anodize the wheel, which would show defects/imperfects/scratches/etc. more than paint. The solution that finally worked was to blast the wheels with little pieces of plastic. Sand or glass beads would damage the wheel surface (cosmetically). The plastic was just barely hard enough to remove the paint without damaging the wheel. I do have "before" and "after" photos if anyone wants to see them ...
If you can't find a shop locally, you can drive up to Santa Barbara and take them to Santa Barbara Industrial Finishing. --Joe |
