Car to car battery charger
Hi,
I've built something that I find very useful and wonder if others might as well. The garage I store my Lotus doesn't have a nearby power outlet so I've had to deal with ways to keep the battery charged. The garage is at my work and so I can park my daily-driver next to it and use it as a power source. Instead of installing a battery disconnect switch, I built a car to car battery charger based. Basically the device connects two cars via the 12V cigarette outlets and has an electronic circuit to keep the current within the safe limit of standard outlets. Of course both vehicles need to have 'always on' outlets and fortunately the Elise does. If there is enough interest in something like this, I could make a group buy on the parts and either sell them as a DIY kit (some soldering required) or I could assembly them and sell them for a bit more. best, Brad |
| Sponsored Links | |||
Advertisement | |||
Yea I have one of those jump starter packs too but don't like using it. My battery cover is a pain to remove because the way my audio amp is wired. However the more important reason is using the pack means the battery is already deep-discharged which isn't good for most batteries (deep cycles are more tolerant). Periodically using the car-to-car charger keeps the battery healthy if I don't drive the car frequent enough.
So its similar to this?
![]() Black & Decker Tools | Simple Start? Vehicle-To-Vehicle Battery Booster BBC2CB So the Lotus would be taking a charge from another car's battery? both are off?
2006 Black Exige Chimera R.B.S./ITB airfilter/Composite Worx |
Kimgt,
Yes the BBC2CB looks fairly similar. Although based on reviews it sounds like the current-limiting circuitry isn't very good as people were able to blow out the fuse by trying to use it to jump start a car with dead battery. |
Painful Novice
Is your current limiter passive (resistor), linear (transiter CE junction that climbs in resistance with current) or switching mode (duty cycle/frequency which varies with current)?
Storm titanium 2005 Elise with carbon fiber spoiler, BWR sway bar, BOE toe links, gPan2, LidBone, sector 111 wheel studs, Grey RAC Monolite wheels with toyo R1R, Team Dynamics 1.4 with Hoosier A6/R6s, Katana2 Supercharger, ECU with 265 flash. PPE headers w/decat, CEL angle eliminator, Silent touch catback, Rear Panel Eliminator, HKS intake, V2 fuel tank, Walbro255 fuel pump. HID lights. |
#7 (permalink) | |
If I was doing this type of product in higher volume then I would probably go with a dedicated switcher-mode power supply. There are some pretty nice single chip IC boost converters that can do 5 amps. There are also dedicated ICs found in commodity lead-acid battery chargers that could be connected after the boost switcher to provide the reverse polarity, under, and over voltage protection. Lots of options. Configure the boost for ~18V and then let the battery charger IC do this rest. |
#9 (permalink) |
I regularly trickle charge through my cig lighter with a some Mercedes branded tender/wall wart. If you wanted to go ghetto, you could plug a cheap inverter into the source vehicle, then chain the tender to it. Obviously not the most efficient method though.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
