Does the wing work on the exige??
Has any body run there car without the rear wing on the track? Does it really add down force or is it the body shape of the exige that gives the down force? I know that my cornering speeds are no faster in the exige then they were in my elise. Were going to be running 2 days this week @ BW with and with out the wing. It may just be causing drag and not really aid high speed cornering. I think I'll ask Craig Stantion to test my car both ways to see what he thinks. If it gives less drag with it off and adds straightaway speed and doesn't hurt the stability I'll give it a shot. These cars run out of steam above a 100 anyways because of drag..Besides I'm a little old for the boy racer look..carl
ReallyLightStuff.com
![]() Join Date: Jul 2003
The magazines have claimed a slight difference... for what it's worth.
Thomas
07 SY Exige RLS Blade 300 #001 RLS Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 2.9" Pulley . RLS Wing Plates . RLS CF Window Panel .. Lotus Elise & Exige Parts .. RLS Discussion Links on LT .. Wisconsin Milwaukee Traffic Speeding Ticket Lawyer Attorney It is quicker to e-mail (PM fills up fast!): reallylightstuff [ a t ] gmail [ d o t ] com |
More track time please.
I'd imagine that the added drag is negligable. Given that there is nearly no rake to the wing and very little frontal area. I am confident it adds downforce but not sure how much. So a guess the question is how many pounds does it need to add to offset the top end loss due to drag. I would think that question would vary from track to track, right?
The top end differences are slight either way. like 1 or 2 mph. The issue isn't so much the poor top end but how fast the corner exit is. Given that, I'd give a couple of pounds of down force on the key corner before the straight the benefit of my doubt. I look forward to your findings though. Good luck. will you by chance be using a good datalogger? |
Lotus engineers spent a lot of time in the wind tunnel making certain that the aero surfaces of the Exige were all functional, and working together. That why the subtle differences in the clams (from the Elise.)
Obviously, the wing and splitter setup isn't adjustable like on an F1 car, so the efficacy is going to be determined by the type of track you're running - high DF vs. low, or wherever in between. Just look at the difference in wing on the F1 cars in Monoco vs. Canada (or upcoming Indy for that matter)
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
#7 (permalink) |
Xx-------Exige-------xX
Well I don't know anything technical about it but I know that if I pop the lid on the highway the trunk stays tightly closed. It's definitely pushing down but it's not the most sturdy structure in the world... it wobbles all over the place on the highway.
#9 (permalink) |
Any downforce it creates is of value. I agree with the statement previously posted about corner exit speed. Being able to get on the gas faster and feeling the rear planted is a good thing. Just my two cents.
#10 (permalink) | |
McLareghini Bugatterrari
#11 (permalink) | |
#12 (permalink) |
short angry bloke
So... "dirty air," that's the stuff that has the bugs and grime in it?
![]() To answer the original question, yes, it works - according to the Lotus engineers. Of course, if we base everything we know about cars on what a bunch of boffins say, then I'd say Mitsubishi engineers are twice as smart - after all, the Evo rear wing produces twice as much downforce.
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. |
#13 (permalink) |
See my avitar. Please note the rear wing in the "extra downforce" position as specified in the owners manual.
#14 (permalink) | |
Unregistered alien
Seriously, though, the vast majority of us "track nuts" are either driving below the limits or hitting artificial limits by lowering the limits of the car through driver error. That said, the purpose of a rear wing is so you can set up the car to oversteer on the slow corners (where aero DF will be nill) and still be stable (neutral to mild understeer) in fast corners (where aero DF will be significant). That is the ideal setup for a race car and it's pretty hard to get a chassis to do that without an aero package. Perhaps you could tweak your suspension toward more oversteer to take advantage of the wing. (go softer in the front and/or stiffer in the rear to reduce understeer)
Fine. I'll go build my own car... with blackjack and hookers. In fact, forget the car and the blackjack. Ahh, screw the whole thing. |
#15 (permalink) |
Carl,
you might want to consider removing the front splitter in conjuction with the rear wing removal. They should be working together giving downforce on both ends of the car(if they actually work on the Exige). If they do work, you will be light on the rear of the car(w/o wing, and with splitter), and heavy up front, making the ass end of the car loose, not from mechanical grip, but from aero grip. this would be a bad thing to play with at speed, and could cost you a car or worse. Did you see what happened to castro nieves(sp) a few weeks ago when his wing just blew off? I know thats a bit of an extreme example, as they use a great deal of downforce in the design of those cars, but you might want to consider keeping the car balance with splitter/wing both either on or both off. Good luck Fishguy
1977 Crossle 32F 1999 Spec Miata 1987 Porsche Spec 944-2008-2009 season SCCA AZ regional Champion 2008-2009 SCCA AZ Regional "Driver of the Year" |
#16 (permalink) | |
#17 (permalink) | |
short angry bloke
more like "lack of driver talent."
#18 (permalink) |
I don't remember where but I remember reading that at 100mph the splitter and wing together generate ~100 pounds of downforce. 60 pounds by the rear wing and 40 pounds by the splitter. No idea if that is true or not. I do know that when running on the Cal Speedway Roval I was not able to reach the same speeds as mlk-f1 in his elise.
AJ - Akua Solutions - #128 Lotus Exige - MonkeyWrench Racing - Carbonetic - Innovative Mounts - Toyo Tires - JRZ Suspension - PPE Engineering |
#19 (permalink) | |
![]() The first one is the airflow underneath the wing, which is catching the clean, undisturbed air, causing drag (although I'd imagine it can still effectivel provide downforce between the pressures over and under the wing). The second one has the airflow passing directly over the wing, pressing down on the car. The clean air would be hitting the wing's top surface, this is why some members saw the back half of the top of the wing more grimey than the front, which is catching dirty air coming over and off the top of the car. The third is pretty much the opposite of the first. I'm presuming Lotus was going after the second style. |
#20 (permalink) |
Haxord but mine
I have thought about taking mine off just for the clean fastback shape. But I'm afraid of tempting fate. But again, up to and under 100MPH are really going to feel anything. Has anyone gone from an Elise to the Exige and thought "what a difference"?
As far as keeping the front splitter on, I don't think it would make a huge difference as far as the back end being unbalanced. Were talking about a car with like 36/64....all the weights in the back to begin with...if anything I'd keep the front splitter on.
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? | Big Wing now! |
| Thread Tools | |
| Display Modes | |
