Exige Roll Cage................ - LotusTalk - The Lotus Cars Community
Old 11-17-2012, 09:16 PM   #1 (permalink)
Gunpilot's Avatar
Pondering the thought of TT/Wheel to wheel racing.
Have done a bit a research online but somebody may know better.
Need a roll cage for an 07 Exige, with the top on, that can be installed DIY fairly easy. I can weld anything needed but still like to keep it simple, installed the cage in my 72 Baja Bug so sort of know the ass pain I'm going to endure. Have a medium set of mechanical skills and if I don't have the tool I can buy it.
Auto cross as much as possible and drive the car to work 1 day a week to offset the 72 Bug comments but still need it semi functional.
Any suggestions on fabricators, manufacturers, etc.... will be greatly appreciated.
Thank you!
"CHARLIE DON'T SURF"
When it comes down to making out, whenever possible, put on side one of Led Zeppelin IV.
Gunpilot is online now   Reply With Quote
Old 11-18-2012, 03:12 AM   #2 (permalink)
Certified Lotus's Avatar
Sector 111 sells one. A friend of mine has it in his car and it looks nice and provides good protection. No high side rails though, which shouldn't be a major problem as you sit below the aluminum tube anyway. They ship it in pieces and you weld it in place.
http://www.sector111.com/track/interior/r3cage.cfm
'07 Exige S,2bular Header,De-Cat & GT3 Exhaust,Koldfire ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler,Pipes & CF heat shield,Sector 111 Gpan, Accusump,Nitron GT3 shocks,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Sector 111 Trackmount, Lotus High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Personal F1 & Rapidfix II quick release,Traqmate.
Certified Lotus is offline   Reply With Quote
Old 11-18-2012, 06:35 AM   #3 (permalink)
2009 Cup 260 M/Sport
<@¿@>'s Avatar
I've got the OEM roll cage...
It is P/N = ALS3V0023J this attaches to the OEM role bar P/N = A122A0046F
All I want out of life are the keys to Jay Leno's Garage...
A man's mind, once stretched by a new idea, never regains its original dimensions.
[Oliver Wendell Holmes]
<@¿@> is offline   Reply With Quote
Old 11-19-2012, 01:36 AM   #4 (permalink)
The Apex Diet
btotheje's Avatar
Yeah.... I really want one of those!
Maybe I'm overly fussy but OEM or bust. Custom is really the only other option from what my research has gleaned. I'm not sold on the few that are offered. They've still got to look nice as well IMO. With an OEM or custom, you can get those bends nice and tight down the sills and structures of the car, just something that isn't so with most others on offer.
btotheje is offline   Reply With Quote
Old 11-19-2012, 03:06 AM   #5 (permalink)
Regarding the OEM roll cage, you had it installed after you bought the car? Mind sharing the cost of the cage and the install price?
Old 11-19-2012, 03:56 AM   #6 (permalink)
<@¿@>'s Avatar
Mine is a 2009 Exige Cup 260 - ordered to be M/Sport only (not for public roads) from the factory. The 12th character of the VIN is "H"...one of 12 built globally! What made it a track car only over a “normal” Cup 260, is that mine didn’t get any sound insulation, no carpeting, no interior firewall panels, came with a ProAlloy radiator, roll cage and CF seats. All twelve ordered came with a solar windshield. So the short answer is I don’t know how much the roll cage cost to install…or price…sorry.
Old 11-19-2012, 04:57 AM   #7 (permalink)
Thanks. Found out it costs $4513.73 plus shipping from UK PLUS install. Cheaper to have custom one made.
Old 11-19-2012, 05:17 AM   #8 (permalink)
<@¿@>'s Avatar
This is significantly less...
Roll Cage Complete - FIA Approved - LHD ALS3V0023J | BELL & COLVILL Lotus
Old 11-19-2012, 08:16 AM   #9 (permalink)
Lotus Race Prep
VSAMotorsports's Avatar
Here are some pics of our newest Elise/Exige roll cage. Notice the front foot mounting points. They are through bolted to the extrusion in tension shear and compression. The location takes into account all 3 force angles that this connection point may see. It also allows for the front leg tubes to terminate behind the plastic trim panels. This allows much more leg room. This is both good for comfort and for safety. We don't run a door bar as the stock aluminum extrusion in the door is adequate as long as it is tied into the main hoop properly. This also aids in ease of entry as well as emergency exit. If you have ever gotten into an Exige with door bars you know what I mean!
These are just a few of the features we have designed into the cage to make the best out of the small cabin space of our cars. This cage is our first of this design and a reproduction fixture is being built in the next several weeks. We plan on selling this cage as mostly bolt in. The windshield frame needs to be trimmed a bit and a few holes need to be drilled. The cage will come on a palette in 2 pieces and will need to be welded together once installed into the car.
If you have any questions, please post them here or email Stephan@VSAMotorsports.com
Lotus Race Prep and Street Service in Los Angeles.
14819 Aetna St
Van Nuys, CA 91411
818-666-0731
Stephan@Vsamotorsports.com
www.VSAMotorsports.com
VSAMotorsports is offline   Reply With Quote
Old 11-19-2012, 03:28 PM   #10 (permalink)
Gunpilot's Avatar
Looks good VSA, unfortunately I want to leave my roof on.
Old 11-19-2012, 03:38 PM   #11 (permalink)
Lotus Race Prep
This particular car will use a single layer fiberglass roof. This roof will easily attach to the cage using dzus buttons. The original roof could also be used, but It would need mounts fabricated and would also need to be trimmed, not too big a deal. The same goes for the factory cage and sectors cage.
14819 Aetna St
Van Nuys, CA 91411
818-666-0731
