2nd Timer
Folks
I swore I wasn't gonna mount my front plate either, then I got chased by 3 people, photographed by another 4, stopped in the street by God knows how many and 'observed closely' by more policemen than I've seen in Maryland in my life... and all of this in one week. This car attracts so much attention I found my bowels loosening everytime I saw a police car! So I mounted my front plate in hopes that I can drive by grinning like the Cheshire Cat. Flame away if you like but I'm 'mostly legal' and frankly don't think the result is too bad. I got used to driving a UK car with UK front plate so this is actually a smaller, neater solution almost Germanic in its aesthetic. Maybe this will help some folks. Yeah, yeah, yeah I know, you've been driving since before the war with no plates at all and your ass hanging out the window and have never been stopped... well alas I was born genetically unlucky so I'm pretty much risk-averse. INSPIRED BY MERLIN... THANKS MERLIN... I bring you: "Borderline Illegal Front Plate" Pictures pretty much tell the story... Bend plate to suit between two bits of wood so it looks kinda straight. Yep I know, that's the illegal part but I figure that most plate surrounds blank the bottom portion of the plate below the number and frequently half (or more) of the state lettering... I mounted it from underneath (for obvious reasons) with two galvanised sheet metal screws into pilot holes drilled into in the clam plate bump thingy (I used a dremel with flexible drive). I'll probably change them out for stainless at some point. The innovation is I spaced the plate off the clam with two rubber grommets, this giving some flexibilty and load spreading/absorbtion. Now at present the grommets I used are a little too small (height-wise) and the plate sits pretty snug to the clam. I'll be looking to change these out for slightly chunkier versions so that the PLATE IS FRACTIONALLY LOWER THAT THE 'CHIN- BUMPS' to the left and right... PURPOSE? If I drop the plate by about 3/8" then IT will hit (scrape) the ground BEFORE the main clam does - thus I build in an early warning of imminent clam-catastrophe. So I'll post the pics now and you can imagine the taller grommets... At the moment I've just put foam tape on the back of the plate to protect the paint - like Merlin I'll replace this with those felt furniture pads next time I 'have it off'. Think that's about it, maybe it'll suit some folks. ![]() |
#5 (permalink) | |
Elise #76
Owner of '05 Elise S/T- touring- LSS-Stage 2 '07 Audi RS4 4.2L V-8 420 HP - 6 Sp..(sold) '07 Toyota Prius |
#8 (permalink) |
No more cone damage!
Two birds with one stone! Nice move!
Jer-2005 Elise (retired from autox) 1993 MR2 autox car 2002 Ford Excursion DIESEL 4 X 4 1993 Miata (throwout bearing or clutch failure) 1987 Toyota Corolla FX16 Lemons car (needs new head) 1984 Chevy Citation Lemons car (needs a motor) |
#9 (permalink) |
Great solution. Thanks for the post! I will be adding my plates in the same way.
Yeah, I get it. You're an outcast, always under attack, always coming in last, bringing up the past. No one owes you anything. |
#10 (permalink) |
I did it the same way but did not want to drill holes at all. I bought a bolt at Lowe's that matchs the tow hook width. I painted it black and attached the plate to the bolt with some rubber "washers" and screwed it into the tow hook opening. Then I used double sided tape to keep the plate from rocking back and forth.
#11 (permalink) |
nice idea,did something similar on my elan rear plate,becouse it was just too tall.
Laser blue,biscuit, micro mirror, "Blue knob" ,HID lights,modded rear lights,rear badge,blue starter button, replaced speakers,perma grin, Club111 ![]() ![]() The Sith lord of the LB's loyal henchman
#12 (permalink) |
i just added my plate to the front this weekend too.
i got a bolt that matched the tow hook and drilled a hole in the middle of my plate and put the bolt through and used a plastic spacer to keep things tight. the only problem i think i might have with the plate in the front is now the grille is covered and engine temperature might rise quicker since airflow is restricted a little more.
2005 Ardent Touring Elise, 2007 Hummer H3, 2007 Infiniti Fx35, 2006 Infiniti M35x (sold), 2002 Audi TT quattro convertible (sold), 1999 Corvette (sold but not forgotten), |
#13 (permalink) |
Fulfilled @ Last AR Elite
Nice adaptation Paul. I'm going to stick with the exterior double-sided tape and try to avoid any drilling in the clam, unless the tape does not prove durable enough. If the tape separates, then your method of mounting the screws from underneath will be my fall-back. Thanks!
I already have the plate extending slightly below the two clam tabs as an early warning for scrapes -- but if I'm hitting it too often and it begins to separate the plate from the clam, then I'll have to raise it slightly (with another layer of furniture pads under the top fold).
Member, AR ELITE a.k.a. Lotus-Eater (one who loses all desire for earthly pursuits or memory of family and home, whose only desire is to live in bliss in Lotus-land) 2005 Elise: Ardent red, touring, biscuit, starshield 2006 WRX wagon (CGM) with short shifter 1999 10th Anniversary Miata (for sale, 25K miles) 1990 Miata (sold) 1985 MR2 (sold) 1976 MG Midget and 1971 TR6 |
#14 (permalink) | |
#15 (permalink) |
Ridge Man
Showed the plate ' wrap-a-round' set up to a policeman friend of mine
and he claimed it was still illegal. Then he added, 'why not use a plain sheet of base metal in the form of the wrap-a-round plate and secure your actual plate to it, setting it so that the license plate's lowest point is positioned at the lowest point of the base plate, thereby allowing the same amount of ground clearance? If you don't want to 'screw' attach it, try magnets like the car dealers do with their dealer plates.' |
#16 (permalink) | |
#17 (permalink) | |
I showed this to an officer friend of mine and he said that bending the plate is not illegal as long as the numbers and state display is clearly visible from direct view. The way the top was bent may cause some closer scrutiny though. |
#19 (permalink) | |
Ridge Man
we need a front plate? Police Officer comment: " If we're looking for a stolen car we are going to see a lot more cars driving toward us than driving with us." Last edited by Ridgemanron : 03-14-2005 at 02:52 PM. |
#20 (permalink) |
Paul,
Exactly how many inches of the plate angle up under your car? It's difficult to tell from the picture. I'm not so sure that I have as much space under my Virginia license plate numbers as you do, and I want to avoid drilling holes to far forward and missing the clam. Thanks.
