Old 02-05-2008, 04:46 PM   #1 (permalink)
Mods are good for you
Dave's Avatar
Gut Sport Wing Installation
Finished the install today. A keen eye will notice something missing I love the wing, but wasn't much for the platform. We fabricated under clam mounting braces...rock steady and looks pretty sweet. Uprights were painted stripe black, and wing Saffron. Of course, there's 6 small holes in the clam, but I don't have a problem with that...they're easily filled if I ever want to dismount.
Dave is offline   Reply With Quote
Old 02-05-2008, 04:47 PM   #2 (permalink)
Dave's Avatar
Old 02-05-2008, 04:48 PM   #3 (permalink)
Resident Drunk
zygotesoup's Avatar
looks great... gorgeous car!
1993 Black BMW 325i
2000 Solar Yellow MR-S - SOLD
1987 White on White Porsche 944 Turbo - SOLD
1993 Maroon Lexus SC400 - SOLD
Next Car - 2005 Lotin Elite
zygotesoup is offline   Reply With Quote
Old 02-05-2008, 04:52 PM   #4 (permalink)
道のお父さん
RoadDad's Avatar
Looks very nice. I looked at the pictures before reading your comments and thought "that wing sure looks like the Gut but it's not a Gut..." I like it much better. Nicely done.
"There are two things no man will admit he cannot do well: drive and make love" -- Stirling Moss
Old 02-05-2008, 04:52 PM   #5 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
As always with you, VERY NICE! Very classy and OEM look... Well done!!!!!
Best,
Phil
| '05 GG LSS Elise | WAY WAY Too Many Mods to List | Collaborative Boosting by Ronin & S111 & BOE | EFI Standalone Engine Management | ClamHinge |
See my car here:http://www.boefabrication.com ----->Last Updated: 6/15/08
Two things:
1. Do the Right Things Well and Good Things Will Follow
2. Advice is something we ask for when we already know the answer and wish we didn't
turbophil is online now   Reply With Quote
Old 02-05-2008, 04:54 PM   #6 (permalink)
The Mad Scientist
darkSol's Avatar
Oooooo how much LESS does it weigh without the docking platform?
Serious.
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
Supercharged 2005 Graphite Grey Lotus Elise: 230whp, 1876 lbs. 12.41 @ 110.1 mph.
darkSol is online now   Reply With Quote
Old 02-05-2008, 05:17 PM   #7 (permalink)
Heretic
tandemracer's Avatar
The install looks great.
Did you add anything inside the trunk to spread out the load of the wing? Hopefully you won't get any cracks in the clam.
06 Elise, AW, Touring, Sport, Premium, Hardtop, Starshield -- Sector 111 Harness bar, Schroth ASM 4 point Harnesses, Seat Grommets, Folding Front folding tow hook, Boomerang rear tow hook, Halon fire extinguisher, Polk speakers, MicroMirror, Odyssey PC680 battery, desnorkeled intake, removed shims, ekological HID kit, Pagid RS14 pads, SS brake lines, Stan's shifter mod, CF Center Console, CF AC Surround, urethane motor mounts, Titanium Dave's Sub Belt Bars, Heater Core Bypass
tandemracer is offline   Reply With Quote
Old 02-05-2008, 05:20 PM   #8 (permalink)
Scott's Avatar
Okay settled. THAT's what Im going to do! I love the GUT rear wing... not so fond of the platform. Now that I know that can be done... I will do that! Grat work Dave as always!!!
05 Saffrron Yellow, Sport, Touring, Star Shield, Larini w/ sport cat, Katana with 3.2" pulley.
Scott is offline   Reply With Quote
Old 02-05-2008, 05:22 PM   #9 (permalink)
2-Y-CHROMOSOMES's Avatar
Nice job Dave. Can you increase the height on that wing. I doubt it but wanted to check.
2005 Elise | Forcedfed Custom Intercooled Supercharger | EFI | Forcedfed Street Header | Fujita CAI | TB Bypass | Toda flywheel | ACT HD Clutch | Forcedfed Prototype Exhaust | Micromirror | Forcedfed Half Carbon Splitter | Greddy Catch Can | ForcedFed Engine Damper
2-Y-CHROMOSOMES is online now   Reply With Quote
Old 02-05-2008, 05:48 PM   #10 (permalink)
Dave's Avatar
Mark - can't adjust the height. It's maybe a 1/2" lower without the platform.
Tandem - yes, fabed some plates to spread the load. Also used some thin rubber washers to act as a simple damper, and adhesive automotive trim foam between the uprights and clam.
David - saves about 3lbs w/o the platform.
Appreciate all the kind comments.
Old 02-05-2008, 06:51 PM   #11 (permalink)
240 Exige-S Enthusiast
SIIK2NR's Avatar
Looks MUCH better without the platform. The platform ruins the a$$ view of the car IMO.
Good work. Nice attention to detail.
SIIK2NR is online now   Reply With Quote
Old 02-05-2008, 06:59 PM   #12 (permalink)
raggedy1's Avatar
schweeeet!
It's Delux son, Delux. It's not that hard.
http://itsdeluxson.com/
raggedy1 is offline   Reply With Quote
Old 02-05-2008, 07:02 PM   #13 (permalink)
Very sharp looking. Dave can you show us a picture of your mounting solution inside the clam?
Old 02-05-2008, 07:08 PM   #14 (permalink)
raggedy1's Avatar
I should have said that the wing looks pretty good considering it's "tacky" crap from sector111!!!!! ha!
I'm just kidding of course. I'm sure you've all seen the other thread regarding the removal of a GUT wing.
Old 02-06-2008, 05:51 AM   #15 (permalink)
Dave's Avatar
I'll try to get a pic this weekend...should have taken some along the way, but must have been too anxious Here were my steps:
1) I put the platform on the car; used a grease pencil to mark the 3x3 holes. Remove platform, drilled holes in clam.
2) Cut 2ea 4"x8" pieces of aluminum, and set the platform on them as a hole guide, drilled holes. Then mounted to the underside of the clam with epoxy. Make sure the aluminum is flexible enough to contour to the inside of the clam.
3) Applied 1/4" automotive foam adhesive weather seal to the perimeter of the upright bases. This filled in any small gaps between the clam & uprights, and keeps the water out.
4) You need screws that are about 15mm longer than the supplied, so I bought some M6x1x40mm stainless, along with 30mm washers.
The whole thing didn't take 2 hours.
Old 02-06-2008, 06:15 AM   #16 (permalink)
Legend in my own mind
MightyMike's Avatar
Images: 4
Looks factory perfect; very nice!
really cool 2006 ST Elise
MightyMike is online now   Reply With Quote
Old 03-27-2008, 10:41 PM   #17 (permalink)
Resting Heart Rate 38bpm
ozoney's Avatar
this mod
I like the wing without the platform. But what of the numerous concerns of clam weakening under the weight of the downforce? If there is potential for this weakness over time/duress, would using the provided base upside down in the boot alleviate that (and if the base doesn't fit like that, something similarly functional)?
Also, what is a typical cost to get the wing painted the same as the car? I am contemplating such a mod. I am also thinking of adding the Esta side skirts and I haven't decided on a front splitter. But would paint all three ST. Any one done similar mod and can provide a paint cost estimate?
ozoney is offline   Reply With Quote
Old 03-28-2008, 12:23 AM   #18 (permalink)
91MR2's Avatar
I like that wing a lot on the Elise.
1995 Lotus Esprit S4
1993 Toyota MR2
1991 Toyota MR2
1991 Mazda RX7
www.91MR2.multiply.com
91MR2 is offline   Reply With Quote
Old 03-29-2008, 10:23 AM   #19 (permalink)
NoFear99's Avatar
If I had an elise I would have that wing on it for sure
07 Lotus Exige S , Solar Yellow, Touring Pack, Traction Control, Lotus Stage 2 Exhaust, KandN Air Filter, Velocity funnel intake, JVC KDNX5000 DVD+GPS, Compact Sub Kenwood KSC-SW1, Tinted windows, Lotus Sport windshield and front plate decal,HID Kit 6000K,Parking Light,license plate Led conversion.
Next mods :Gotham 265 Flash ...
http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 03-29-2008, 04:12 PM   #20 (permalink)
mikecronis's Avatar
Images: 1
You should send your version to the GUT site to show them that it doesn't have to be overly ricey but actually tasteful as you've keenly demonstrated. Well done!
mikecronis is offline   Reply With Quote
HTML code is On
