Track Addict
hardtop storage
How do you store your hardtop?
I am thinking to just lay it upside down horizontally. Is that OK? Or should I just lay it against a wall (vertical)? If vertical, how do you do it? With the inner hardtop against the wall? Or the outside? Thanks |
Track Addict
the hardtop comes with the bag storage, but i m just wondering how the hardtop is laid on. since the hardtop is not flat on both side (the exterior has a lil arc), so i m just wondering whether the orientation of the hardtop placement really matters or not in storing the hardtop.
I have mine stored in its bag vertically against a wall in my car trailer. I bolted two D-rings on either side of the hardtop case (upper and lower) and use two bungie cords in an "X" across the front of the case. I think the top of the hardtop is facing out, but I'm not sure that would matter. As long as nothing is putting weight against the hardtop--whether stored vertically or horizontally--I would think it would be okay. You could use this same method in a garage or anywhere you don't mind installing hardware into your wall.
2006 Elise British Racing Green; LSS, LSD-TC, 2bular exhaust, Blackwatch Racing front bar, BWR Supercharger, Tillett Seats |
McLareghini Bugatterrari
I store mine between the sunvisors and the rollbar.
xtn
#6 (permalink) | |
GR8 SCAPE
I actually wasted a second thinking about this!! I must be slow today... Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
#7 (permalink) |
Perfectly timed thread as I'm contemplating this as well. My main concern is that if it lays on its rim, interior side down, the weight of top may warp the edges as it is not flush to the ground. Alternatively laying it topside down will put the apex of the roof on the floor and cause warpage.
![]() Babak Club111 Central Plains Coordinator '05 Elise - Touring, HT, StarShield '99 Ducati 996 Bip '05 Freelander SE |
#8 (permalink) |
insert clever title here
In my last garage, I had a flat loft area over one end. Under that, I hung four very large L-shaped screw-in, rubber coated hooks. The hardtop would just slide into that area. The one downside was that, even though the hooks were large, the clearance to the loft above was not great and I had to be careful while sliding it over the hooks that the hardtop didn't contact the loft above.
I haven't decided what to do in my new garage, but will probably just build a custom wall bracket instead.
#9 (permalink) |
Mine's coming off soon (although the wife keeps reminding me we could get alot more snow).
I store it in its bag on a padded platform I built out of plywood and 1"x2" supports, suspended from the garage rafters. I just slide it in there for the spring, summer and fall. Tom |
#11 (permalink) |
Fly N Lowr
If you're not living on the edge you're taking up too much space!www.GoodBodyHealth.com |
#12 (permalink) |
perfututum futūtor below
just got my hardtop storage system (D-ring hanging padded case) late last week. It's great. Got a great deal on it from John at FVMC.
#13 (permalink) |
Grrrrrr Baby
I have no idea what to do with my hard top. I try to take my soft top off as much as possible.
Thinking about selling it. What do you guys think about giving up the Hard top?
2005 Lotus Elise LSS 2003 Corvette 50th Anniversary Convertible |
#15 (permalink) | |
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
#16 (permalink) |
2005 Ardent Red, Touring
So now thanks to this thread I am paranoid about storing my hard top
Last year it came off right from the dealer, I put it in the included Lotus bag a had it propped up in my closed resting on one side, carpeted floor. Can it really warp or bend over time if left like this? Does it need to be hanging? I put it on after having it in storage for about 6 months and it seemd to line up ok on the edges and windows. Now wondering if I need to hang it in my closet?
"You can run over an insect and know just from the messages coming through the wheel how many legs it had. Was it a beetle? Was it a spider? Hang on......... spider." Jeremy Clarkson - Top Gear |
#18 (permalink) |
I am always not sure whether to leave it on, or store it. I really like the way it looks with the hard top on a lot more than with it off, but I like the open air feeling too.
Decisions decisions... Once our horrid heat of Houston summers hits, I'll likely leave it on most of the time. (assuming I don't sell the car) lol |
#20 (permalink) |
There was a thread with this exact same title posted just a few days ago:
http://www.elisetalk.com/forums/show...ardtop+storage |
