Lotus 2ZZ Engine - Interference or Non-Interference Engine? - LotusTalk - The Lotus Cars Community
post #1 of 14 (permalink) Old 12-29-2008, 03:11 PM Thread Starter
mirage's Avatar
I've looked around and searched on the net, and I've got some conflicting stories. Some people say that our 2ZZ engines are non-interference as long as its under 6000rpms. Others say that its a flat out interference engine. Whats the real deal? Thanks in advance for any clarification. I very much appreciate it!
mirage is offline
post #2 of 14 (permalink) Old 12-29-2008, 03:17 PM
Icedog_16's Avatar
No, according to this: Gates Part Locator & Interchange
Same goes for the Celica GTS.
Icedog_16 is offline
post #3 of 14 (permalink) Old 12-29-2008, 03:32 PM Thread Starter
mirage's Avatar
Unless I'm understanding this thing wrong, its also saying a '00 Mercury Cougar has a non-interference engine, and I know that's not true.
mirage is offline
post #4 of 14 (permalink) Old 12-29-2008, 04:10 PM
Icedog_16's Avatar
A quick search only turned up a handful of results regarding what you said and others that contradict that. Just the messenger, man. I tend to think that Gates has a bit to lose in the event of a failure - just sayin'. What's the purpose of your question?
post #5 of 14 (permalink) Old 12-29-2008, 04:32 PM
Icedog_16's Avatar
I just remembered an SAE white paper on the development of the engine. Maybe this will help. http://www.celicasg.com/2zzGE-Engine.pdf
post #6 of 14 (permalink) Old 01-10-2009, 08:09 PM Thread Starter
mirage's Avatar
I own a 2k mercury cougar as well. Timing chain jumped time, engine kaboom. Just wondering if the same situation could happen to my new elise.
mirage is offline
post #7 of 14 (permalink) Old 01-10-2009, 08:44 PM
tvacc's Avatar
I can tell you that it correctly noted that the 2001 Jetta 1.8 is an interference design....and that the 2006 Mini was not.
Can not see how they could be wrong....but....they have no mention of the 91 elan....which I know is..
I think if they dont have parts....they dont list the info one way or the other.
Ediot....I just looked at the Isuzu Impulse 2 liter which is the same engine as the Elan....and it says that it is...
So...I think if you look up the Celica and they have parts....they know what they say. I did not look that one up yet.
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus, Drive Fast Take Chances, 93 Caterham 7, 71 Elan, 65 Elan S2, M100
tvacc is offline
post #8 of 14 (permalink) Old 01-10-2009, 09:43 PM
...m...'s Avatar
...toyota uses timing chains only on their interference designs, otherwise they use belts...um, don't ask me for a reference - i read it on wikipedia...
...85,000 miles and aging beautifully...
...m... is offline
post #9 of 14 (permalink) Old 05-28-2011, 04:26 AM
xxxotic's Avatar
I have a 1999 Cougar and the same thing just happennned to me, but they have to take a look at it and see if the engine is gone. I thought it was a fuel filter that was clogged at first, since when I stepped on the gas to accelerate, it made a high reving noise and did nothing, and then started working OK once I let off on the gas a little,.Went about 4 miles and the car dies on me.
In most cases when this happens, is the engine gone?
xxxotic is offline
post #10 of 14 (permalink) Old 05-28-2011, 07:29 AM
stea1thviper's Avatar
I'm no expert, but I'd be willing to bet our engines are interference. Based on what I know, non-interference engines tend to be less efficient, and are more commonly found on trucks? Somebody please correct me if I'm wrong. If a 2zz ever jumped timing I wouldn't be surprised if there were some bent valves somewhere...
2011 WRX - Protuned 328 WHP / 344 TQ on Mustang Dyno
[sold] 06 Exige Phantom Black - Track/touring pack w/ LSD, BWR Supercharger, Volk CE28N matte black wheels, yellow calipers, green filter, Larini SS Exhaust, BOE Surge Tank, CF MotorSports Spoiler, custom splitter, difflow 5 element diffuser
stea1thviper is offline
post #11 of 14 (permalink) Old 05-28-2011, 10:31 AM
E_Swift's Avatar
How is this even a discussion? The engine is an interference design. /end of thread.
E_Swift is offline
post #12 of 14 (permalink) Old 05-28-2011, 07:54 PM
Westrock's Avatar
Depends on the severity of the contact. It can range anywhere from valve being slightly bent. Valve and guide getting messed up. Or hitting the piston hard enough that its compromised.
Ya, but a good point was brought up about the dual cam profile nature of the engine. The valves do not extend the same distance at all RPM & throttle parameters. At lower RPM the valves are not going in as far.
The compression ratio can also play a large role. Domed pistons (often high compression) will almost always have a valve relief because the piston reaches up into the combustion chamber. Where as a dished piston (lower compression) may have no or very little valve relief.
Westrock is offline
post #13 of 14 (permalink) Old 05-29-2011, 04:29 AM
German Reimport
Mr.C's Avatar
Originally Posted by stea1thviper View Post
Based on what I know, non-interference engines tend to be less efficient, and are more commonly found on trucks? ...
Truck engines are mostly Diesel engines, and they are mostly all interference engines. Otherwise you wouldn't get the high compression ratio required for self ignition.
I'm not sure if a dropped valve on a car engine means the engine is toast, but on the many truck engines that I have investigated with broken valves you mostly find metal bits in all cylinders with scuffed liners and all pistons damaged. I'm not 100% sure how those broken bits spread that much, but I see valve and piston parts spread from the intake manifold to the exhaust tract.
And turbo chargers also don't digest those parts very well.
So based on that I would say that a car engine could very well be toast after dropping a valve.
Mr.C is offline
post #14 of 14 (permalink) Old 05-29-2011, 06:19 AM
elise/europa's Avatar
It is an interference engine of course. Plus, the clearance in operation with the intake valve full in advance gives very little clearance, the cam needs to be correctly installed.
Also, the valve pocket on the piston are not perfectly aligned with the valves, and valves floating (exhaust) can generate contact between the valve and the pocket top edge... TOYOTA quality... Reving high the engine with stock piston and stock valve is risky, it depend of the engine OEM machining precision.
Elise 2006, white, BOE REV400/EFI, 310+ whp, K20 coming
elise/europa is offline
Human Verification
