LinkBack (3) | Thread Tools | Search this Thread | Display Modes |
#201 (permalink) |
(Formerly PESTODUDE)
Seemed to help the aero... maybe it was just my imagination ; )
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune. |
#203 (permalink) |
No, but Ive still gotta get the OEM tray (that they replaced with this one) back home whemn I pick up the car! So...maybe more pics to follow.
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune. Last edited by Illumiloti : 12-11-2008 at 05:47 PM. Reason: spelling |
#204 (permalink) |
Form and Function
Pat...seriously....give your car to Al Qaeda - they'll fix it right up for you!
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
#205 (permalink) | |
How you doin'?
However, I don't have any contact info for Bin Laden (well, I don't see it in my BlackBerry or Outlook contacts. ) Anyone on the board with the contact info? Perhaps I can give him the car, and also collect the ransom money, too. ![]() Eddie, did you figure out what caused your engine oil to disappear? Is the car running now?
'06 Lotus Elise (Laser Blue/Black/Sport-Pack/Touring-Pack/Hardtop/TRD airbox/Stage-II Exhaust) - VIDEO |
#206 (permalink) | |
The Azteks are coming!
I too have been watching this thread with great interest. Does your exhaust system eliminate the Catalytic Converter? I am wondering if you have tried this in conjunction with your exhaust system? Lotus Elise/Exige Check Engine Light Eliminator - StickerCity.com While it adds 1.5 pounds weight to the car, I would install one just to get rid of that annoying problem in a heartbeat - even just to TRY it. Apologies in case this is something you have already tried out. I certainly hope Lotus gets this sorted for you. Best wishes.
The difference between ordinary and extraordinary is that little extra. F The System - ChuforiaGraffix.com SweetDaddyDelicious(at)hotmail(dot)com |
#207 (permalink) | |
Form and Function
Engine is almost done...ready for track on dec. 21 at BW!!!! Hope you get this sorted out....it's ludicrous!
#208 (permalink) | |
#209 (permalink) |
How you doin'?
Jan. 18, 2009 - 26,532 miles
![]() Found another nail in one of the rear tires... Front - Yokohama ADVAN A048 (195/50R16) - Believe or not, at 26,532 miles, I'm still on my factory original first set with some tread left... (even after one track day at Cal. Speedway) ![]() Rear - Yokohama ADVAN A048 (225/45R17) - replaced @ around 12,000mi (nail in tire and wear) by Newport European - replaced @ around 17,000mi (nails in both tires) by Lotus Beverly Hills To-Do List 1. All four (4) tires need to be replaced. The question is, do I go with Yokohama ADVAN A048 or something else? (I'm thinking Toyo Proxes T1R after reading some good stuff about them. Your thoughts?) ![]() 2. Both rear brake pads needs to be replaced -- OEM Brembo or Pagid??? ![]() 3. Oil change! (I never wait for the factory-recommended 7.5k miles... usually get one around 5k miles.) In terms of the P0420 MIL/CEL issue, I erased the code with the computer a couple of times and they are not coming back on....
'06 Lotus Elise (Laser Blue/Black/Sport-Pack/Touring-Pack/Hardtop/TRD airbox/Stage-II Exhaust) - VIDEO Last edited by PatrickShim : 01-18-2009 at 07:57 PM. |
#210 (permalink) |
Form and Function
Refreshing to get your car back Pat!
Depends on what you will use your car for...if you are going to AutoX and/or track, I would recommend the R888's. I'd also then upgrade to Pagids or Hawks. If you're just going to street it, I wouldn't waste $ on either of those...and even get street tires.
#211 (permalink) | |
How you doin'?
, although I do have Kumbos on my Z28 -- they are actually fairly good tires.)I don't think I'm going to track the Elise anymore. Probably I'll get an Exige and make it my track car. I put together a budget for myself for '09 and '10, and I think I might take a stab at an Exige around Fall of this year. I wonder if I can get my hands on a 260, considering they are only making a handful of them....
#213 (permalink) | |
How you doin'?
![]() If you don't mind me asking, where did you get the tires and how much did you pay for them?
#215 (permalink) | |
How you doin'?
More amazing thing is, @26,532 miles, I'm still on my factory original first set in the front with some tread left... ![]()
'06 Lotus Elise (Laser Blue/Black/Sport-Pack/Touring-Pack/Hardtop/TRD airbox/Stage-II Exhaust) - VIDEO Last edited by PatrickShim : 01-18-2009 at 08:52 PM. |
#216 (permalink) | |
Rotary Refugee #2
#217 (permalink) |
Keep it simple and real
T1Rs have been a good choice for street tires for my Exige. They provide good wet traction, good try traction, a compliant and quiet ride, and with 15,000 miles they are about 50% worn. I'll get another set when needed.
Note: they take a few hundred miles to break in / release molding agent, during which time they might feel a bit squirmy.
#218 (permalink) |
They do feel squirmy new. Tall tread so there’s a bit of flex too to them when new. But to me at least they do all that I ask. Good predictable feel at the limits and good in the wet. I’m on my 3rd rear now to 1 front. But the life of one set of rears got cut short buy a hack to a sidewall of one. That set may have had 2,000 to 3,000 more to go but o-well.
I found Super Autobacs to have the best price and have them in stock. I paid about 370.00ish out the door (mounted and tax) for the last set of rears. |
#219 (permalink) |
How you doin'?
Awesome! Sounds like Toyo Proxes T1R is a good choice! I'm going to order them tomorrow.
(Found this cool video on YouTube.com) What about the brakes? Any good brake recommendations for street use? ![]()
'06 Lotus Elise (Laser Blue/Black/Sport-Pack/Touring-Pack/Hardtop/TRD airbox/Stage-II Exhaust) - VIDEO Last edited by PatrickShim : 01-18-2009 at 09:04 PM. |
#220 (permalink) |
I run Pagid Blacks, but I would recommend Pagid Blues for street. Check with plastique...he uses Blues...about their streetability. I'll try them next once my Blacks toast. The Blacks are great, but they are noisy (groan and squeek) on the street until warmed up, then they yank the car down from speed like nothing else that I know of. I got the Blacks for track days, but the tanked economy has taken my track budget with it...so more street friendly pad are next for me.
I would expect the Blues to have similar stopping power but be less noisy. There are a number of other good choices...Ferodos, OEM (Lotus) pads are actually decent, etc.
LinkBacks (?)
LinkBack to this Thread: http://www.lotustalk.com/forums/f3/lotus-daily-driver-blog-patrick-shim-51131/
| Posted By | For | Type | Date | |
| Hi-Res XP4 pictures - Automotive Forums .com Car Chat | This thread | Refback | 06-01-2008 01:21 PM | |
| Hi-Res XP4 pictures - Automotive Forums .com Car Chat | This thread | Refback | 06-01-2008 10:32 AM | |
| PATRICK Y. SHIM | This thread | Refback | 05-08-2008 09:17 AM | |
| Display Modes | |
