LinkBack (3) Thread Tools Search this Thread Display Modes
Old 01-18-2009, 10:35 PM   #221 (permalink)
NomisR's Avatar
Man, how the hell do you make your AO48 last 12000 mi and 22000 mi? My fronts are basically heat cycled out at 5600 mi and rears were gone at 4000 and i'm on my 2nd set of rears already. Thinking about getting the R888s though, heard they handle heat cycling better.
Brake pads, I'd recommend the Pagid Blues, I have those on mine, much better than stock. But if you're not tracking your car, your stocks should last forever. And since your tires lasts that long, your brakes should still have at least 100k mile or more life left.
2006 Lotus Sport Elise #4 of 50
NomisR is offline   Reply With Quote
Old 01-18-2009, 10:47 PM   #222 (permalink)
How you doin'?
PatrickShim's Avatar
I wonder driving the car regularlly (almost daily) helps the tires to last longer....??? I don't know.
Old 01-19-2009, 08:54 AM   #223 (permalink)
How you doin'?
Originally Posted by Lotusmotion View Post
I run Pagid Blacks, but I would recommend Pagid Blues for street. Check with plastique...he uses Blues...about their streetability. I'll try them next once my Blacks toast. The Blacks are great, but they are noisy (groan and squeek) on the street until warmed up, then they yank the car down from speed like nothing else that I know of. I got the Blacks for track days, but the tanked economy has taken my track budget with it...so more street friendly pad are next for me.
I would expect the Blues to have similar stopping power but be less noisy. There are a number of other good choices...Ferodos, OEM (Lotus) pads are actually decent, etc.
Your thoughts on the OEM Brembo pads?
Old 01-19-2009, 09:00 AM   #224 (permalink)
NomisR's Avatar
Pagid Blues > OEM, but they're way noisier. But as long as you bed them correctly, they stop on a dime!
Old 01-19-2009, 09:02 AM   #225 (permalink)
Man of Steel's Avatar
I'm VERY happy with my Pagid blues. A little squeeky but not as dusty as the stock pads. I don't know which made a bigger difference - fresh brake fluid or the Pagid pads, but after bedding in the brakes (following the instructions to the letter ) the difference was astounding.
It's really an easy do-it-yourself project with a little patience and a $75.00 investment in a brake system pressure bleeder.
2006 Ardent Red Elise
Touring Pack, Star Shield, hard top, Valentine 1 and bracket, sun visor delete, micro mirror, carpet buttons, new mats, Sector 111 "bootie", racing stripes FAIL :-( ;Chuforia graffix, Stage II exhaust, de-snorkeled, Green filter.
Man of Steel is offline   Reply With Quote
Old 01-31-2009, 03:16 PM   #226 (permalink)
How you doin'?
[Service #13] January 30, 2009 - 26,579 miles
The guys at Mulholland Motorsport did wonderful job with my car. It was great to see Stephan (formerly with Lotus Beverly Hills) at Mulholland Motorsport!
Julio and Stephan replaced my tires (Toyo Proxes T1R), brake pads (OEM pads), oil change, and some minor works (rethreading a couple of holes for the undertray screws).
They also helped me to install the Sector 111 Boomerang Rear Tow Hook on the car.
Great service!!! Highly recommend them!
A couple of pictures of my happy Lotus after a day at Mulholland Motorsport.
All the services since new
[Warranty Service Items]
- ECU (replaced) - LBH
- catalyst/downpipe (replaced 2x) - LBH
- camshafts (replaced) - LBH
- O2 Sensors (replaced) - LBH
- fuel injectors and coil packs (replaced) - LBH
- exhaust (Stage-II cracks, replaced 4x) - SMC/LBH/LC
- wiring Harnesses - LBH
- front/right turn-signal housing (replaced) - LBH
- A/C relay (replaced) - LBH
[Warranty Accessory/Part Items]
- soft-top bars (not supplied by dealer) - SMC
- blower motor resistor kit (update) - LBH
[Undocumented-Warranty Items]
- front/right turn-signal bulb (replaced) - LBH
- loose handbrake lever (repaired) - LBH
- passenger-side window making wind-noise (repaired) - LBH
[Non-Warranty Items]
- oil changes w/ Mobil Delvac Synthetic 5W40 (@ around 1,000mi, 7,000mi, 12,000mi) - SMC
- oil changes w/ Havoline Synthetic 5W40 (@ around 17,000mi) - LBH
- oil changes w/ Havoline Synthetic 5W40 (@ around 22,000mi) - LC
- oil changes w/ Castrol Syntec Synthetic 5W40 (@ around 26,500mi) - MM
- rear tires Yokohama ADVAN A048 (replaced @ around 12,000mi, nail in tire and wear) - NE
- rear tires Yokohama ADVAN A048 (replaced @ around 17,000mi, nails in both tires) - LBH
- front & rear tires Toyo Proxes T1R (replaced @ around 26,500mi, nail in tire and wear) - MM
- front brake pads w/ OEM parts (replaced @ around 18,000mi) - LBH
- rear brake pads w/ OEM parts (replaced @ around 26,500) - MM
- "ECU Upgrade" with factory upgraded software (added then removed) - LBH (SSL)
- new front clam and clearbra (Star Shield) - SCC
[Accessories Added]
- Rear "Round" Lotus badge (Sector 111)
- Front Tow Hook (Sector 111)
- Rear Boomerang Tow Hook (Sector 111) - MM
- Lotus Cup/TRD airbox upgrade - LC
(*LC - Lotus Calabasas, *LBH - Lotus Beverly Hills, *SMC - Symbolic Motor Cars, *SSL -Silver Star Lotus, *NE - Newport European, *SCC - Specialty Car Craft, *MM - Mulholland Motorsport/Dent Works)
Old 02-16-2009, 02:22 PM   #227 (permalink)
jayhillgolf's Avatar
[Accessories Added]
(*LC - Lotus Calabasas, *LBH - Lotus Beverly Hills, *SMC - Symbolic Motor Cars, *SSL -Silver Star Lotus, *NE - Newport European, *SCC - Specialty Car Craft), *MM - Mulholland Motorsport/Dent Works)
Wow.... I had a 79 P. 911 turbo that was always in the shop... I teach golf on the PGA Tour. Full swing, short game and mental game..
You must read this every day..
Patience is the ability to endure waiting, delay, or provocation without becoming annoyed or upset, or to persevere calmly when faced with difficulties. Your good..
jayhillgolf is offline   Reply With Quote
Old 04-23-2009, 02:05 PM   #228 (permalink)
How you doin'?
- I was in West LA for a lunch yesterday, and parked on the street.
- I returned from the lunch, I noticed there is a black Merc. C300 parked in front of my car, just inches bumper to bumper.
- Talked to a security at the nearby business, and he said he saw the black Merc. hitting my car twice. No alarm.
- No noticeable damage on neither cars... not even a small chip. Looked fine.
- I drove off (the space behind me was empty, so it was easy for me to get out)
- I got on the street, and my left-side blinker fell out of the car, only attached by the wires...
- I drove back to the scene and looking carefully at my front clam, there was a very very fine crack under the starshield...
Now I'm pissed.
- I called the LAPD... well, the problem is the "LAPD" covers such a large area, I didn't know who to call.
- After Googling several different sites in my Blackberry, I found the main 800 #. (877-ASK-LAPD)
- I called and they patched me to the West LA division
- I told them about what happened, and they said they will send someone over "right away".
- I had to wait almost two hours... and also called them 4x. I know it's not an emergency, but it was quite ridiculous.
- The entire time, the black Merc was still there, no sight of the owner.
Finanlly the officer came out. He was a really nice guy, and who was really interested in learning about Lotus. He considered the case as "hit-and-run", as the owner of the black Merc. didn't leave me a note. He talked to the witness (the security guy) and spent a meaningful amount of time taking notes, taking pictures, etc.
I made it clear that I have NOTHING against the owner of the black Merc, and although it's technically a hit-and-run, I don't want the person to get in any trouble (misdemeanor?) I wanted to have the police report, only for the insurance purposes.
So yeah... that's the deal.... damaged front clam. time to get a new clam again...
Old 04-23-2009, 03:53 PM   #229 (permalink)
Registered Shmoozer
mikester's Avatar
Geeze, sorry to hear. I'm surprised and glad that the LAPD came out and took it seriously. I hope things turn out as best as they can. Very nice that you had a witness, at least.
Specialty Car Craft are good guys and do some really good work, you might consider bringing it to them. [EDIT: from the post above, sounds like you already know about them]
Covered in Brandy and Lard
mikester is offline   Reply With Quote
Old 04-23-2009, 04:42 PM   #230 (permalink)
Shish Kebab
Cali's Avatar
It definitely could have been worse... You could have been parked behind a 1980 Chevy Impala (with hydraulic suspension and a big LA Dodgers sticker) in downtown LA Good luck with the repair. I'm glad you had a witness too...
Now I'm pissed.
"Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?" - George Carlin
Cali is offline   Reply With Quote
Old 05-09-2009, 03:22 PM   #231 (permalink)
How you doin'?
[MM - Drop-off] - May 6, 2009
I dropped off my Lotus at Muholland Motorsports/Dent Werks to get my front clam replaced. This will be my second front clam replacement...
I got hit while parked on the street (read post above re. incident), and it caused a minor crack in the front clam behind the clear-bra.
I know Julio and Stephan at Mulholland Motorsports will take care the car well for me, and I am looking forward to picking up the car in a couple of weeks!
[MM - Pick Up] - June 1, 2009
The car is now done!!! I am so excited to get the car back! The car looks good, and the Venture Shield (instead of Star Shield) looks fantastic!
- new front clam and clearbra (Venture Shield) - MM
[Accessories Added]
- rear "round" Lotus badge (Sector 111)
- front tow hook (Sector 111)
- rear boomerang tow hook (Sector 111) - MM
Old 05-09-2009, 05:04 PM   #232 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
- I was in West LA for a lunch yesterday, and parked on the street...
Repeat after me:
I will not parallel park my Lotus
Just a Patrick, sorry to hear about the damage...
2007 AW Lotus Exige S. Factory Opts: Track Pack, Touring Pack, LSD
Latest Mods: Sector111 RTDBrace, V3 eliminator, V2 Steering Arms & UltraDiscs, ChaseCam/Traqmate, Innovative 60A Engine Mounts, Moroso pan, NitronDA & Eibach 525/650, Gotham265, ReVerie CF front splitter, "banana" rear wing, and 5 element diffuser, TWRD CF side scoops, custom intercooler ductwork, Saikou Michi catch cans, TRD/Lotus Cup Air Box, Hawk HT-10 brake pads, LPL muffler
Old 05-09-2009, 06:00 PM   #233 (permalink)
How you doin'?
Originally Posted by apk919 View Post
Repeat after me:
HAHAHA!
Old 05-10-2009, 10:22 AM   #234 (permalink)
Form and Function
plastique999's Avatar
Oh Patrick....replace the front clam with Knucklehead's GT3 clam!!!!!!!!!!!!!!
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 05-10-2009, 10:42 AM   #235 (permalink)
(Formerly PESTODUDE)
Illumiloti's Avatar
I was looking into this (after my off track at the last LCS event), but there's no
Openings for the oil coolers. He would have to ditch the oem coolers for something else.
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
Illumiloti is offline   Reply With Quote
Old 05-10-2009, 11:01 AM   #236 (permalink)
thats what she said...
Sleazy E's Avatar
Saw your car the other day Patrick all lonely and tucked away in the corner ... i was at Mullholand Motorsport picking up a diffusor and putting on my eliminator kit
eric
'06 Chrome Orange Lotus Elise
Stage II exhaust | Hardtop | Black LSS Wheels | Toyo R888's | De-Snorkeled | Green Filter | Sector 111 Folding Tow Hook | Exige Mesh | Front Clam Seam Delete | Sector 111 rear panel delete | Black Pack Diffusor | Chrome Orange Center Console
Sleazy E is offline   Reply With Quote
Old 07-04-2009, 10:22 PM   #237 (permalink)
How you doin'?
[Service #14 Drop-off] June 18, 2009- 33,369 documented miles
The car is back to Silver Star Lotus in Thousand Oaks for P0420 issue. Hopefully Ritchie will figure it out.
[Service #14 Pick-up] June 29, 2009- 33,373 documented miles
I've asked the motor-mounts and throttle body to be replaced, but only thing they've replaced are the cat (3rd time) and the Stage-II exhaust (5th time)... I don't think this would do it. I'm getting tired of this.
- catalyst/downpipe (replaced 3x) - LBH/SSL
- exhaust (Stage-II cracks, replaced 5x) - SMC/LBH/LC/SSL
- wiring harnesses - LBH
- "ECU Upgrade" with factory upgraded software (added then removed/then added again) - LBH (SSL)
[Accessories Added]
Old 07-04-2009, 10:25 PM   #238 (permalink)
How you doin'?
July 4, 2009.... less than a week since the last service, P0420 code back on again. This is getting ridiculous....
Old 07-05-2009, 01:37 AM   #239 (permalink)
NOT ßANNED!
Demonized's Avatar
Get a different Elise.
Old 07-05-2009, 08:32 AM   #240 (permalink)
Rotary Refugee #2
Rob T's Avatar
I don't understand how this car would not fall within the Lemon Law.
Rob T is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.lotustalk.com/forums/f3/lotus-daily-driver-blog-patrick-shim-51131/
Posted By For Type Date
Hi-Res XP4 pictures - Automotive Forums .com Car Chat This thread Refback 06-01-2008 01:21 PM
Hi-Res XP4 pictures - Automotive Forums .com Car Chat This thread Refback 06-01-2008 10:32 AM
PATRICK Y. SHIM This thread Refback 05-08-2008 09:17 AM
