#41 (permalink) |
Wiring issue. No tach signal.
Hey guys,
I am having tach signal wiring issues. The shift-i isnt picking my revs ups. The unit powers up fine. I need to to have you guys verify a few things for me: 1)I want to be sure that I should be tapping into the orange wire (like Waydui's install). 2)Also, can anyone tell me what the RPM calibration value should be? I have double checked my wiring connections, but my multimeter needs a new battery so I cant rule out for sure that my wiring isnt the issue. Frustrated at the moment. ![]() Thanks, Jonathan
'06 Elise - Laser Blue, LSS, TP, TC, Starshield. Mods: Stage 2, LETSLA, Manly MM, Exige Seats, Bollocks, De-Snorkeled, Viper's AC Mod, Alpine PDX/JL Stealthbox, 35% Tint, Color Matched Tunnel/AC Surround, Switchblade Fob. To Do List: Mesh, S/C (Someday) A twirling visual overload, explosions of terror and beauty. Colors of fear and pain within clash into unanything. |
#42 (permalink) | |
I have it attached to the top wire of spark plug #1 (far right). I did have to tweak the RPM values on the Shift-I. You use values that are half of what you'd normally use. Eg. 3250 and 4050. I hope this helps. If you get it working without the pickup, let me know. BTW, you have to run a 3-conductor wire from the engine bay to the switched power cables on the radio to power the pickup.
2005 Saffron Elise :: Pro-1 Exhaust, Cup Car Airbox w/ TRD filter, Manly Engine Mounts, Shift-I, Bollock, 1/4-turn fasteners, Esta C/F Decklid, de-stuffification, other stuff... |
#43 (permalink) |
Thanks for the response cobrabyte.
By top do you mean closest to the front of the car when installed? If so, my current configuration (and waydui's, I think) would be the rear-most wire (orange). Maybe I should just look at the schematic to confirm where it really should go. I was hoping not to buy the pickup module. Plus, after all the messing around I did with wiring today, I REALLY dont want to run more wire. I would like to get this running without the pickup if possible. I'm not sure if you're aware, but the Shift-i has RPM calibration settings that can be adjusted. I think, if set correctly, it would eliminate the need for the halfing of RPM values. Thanks for the help, Jonathan
#44 (permalink) | |
User Restricted By ΑDMIΝ
I use the same tach pickup to sense revs for my Traqmate (and the Traqmate provides power too... of course you have to provide power for the Traqmate... ).Here's a pic from this thread: Traqmate & Chasecam Install Exige S (not my install, but very similar) ![]()
#45 (permalink) | |
Thanks for the tip on the calibration setting. I used 0.5 setting and it works now. I did pull the signal from the front-most wire on the plug wire. Try setting to 0.5 calibration and maybe that'll work. ![]()
#46 (permalink) | |
GR8 SCAPE
The RPM signal pick up is from the GREEN wire, not the orange one. See pic. I used the #1 cylinder, far right when looking from rear of car, as the pickup point for the RPMs. The calibration value for my car is "1". It does take a few iterations of setting the value before you find the sweet spot.
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
#47 (permalink) | |
I'll tinker with it today to see if I can pull a good signal off of that wire, as well.
#48 (permalink) | |
![]() Also adjusted the RPM calibration with no sucess. Based on the feedback it seems picking up a signal is hit or miss. I guess I'll just have to get the ignition pickup since I don't want to continue to strip additional wires.
#49 (permalink) | |
GR8 SCAPE
Good idea on getting the pickup module. I didn't want to strip any wires either, particularly on something like the coil pack. Regards, Wayne
#50 (permalink) |
Checked five local stores, none in stock. Guess this project is on hold.
#51 (permalink) |
Keep it simple and real
Summitracing.com has it.
#52 (permalink) |
GR8 SCAPE
#53 (permalink) |
Wayne,
I was looking around today for the communications cable that you were talking about. The only stuff that I found was reasonable priced was telephone wire. It is solid core. Not really what I expected to use. I was thinking a small gauge stranded wire would be best. I have a ton of 20AWG laying around that I could use. I would just have to run three wires. Wondering if yours was stranded or not. Also, got the pickup in the mail today. Maybe I can finally finish this!
#54 (permalink) | |
You can also see my 'glove box' as a result of removing the passenger airbag and the inertia sensor. I'll be working this weekend on a way to attach the cover in a decent way. <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/KHwplQzuivo&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/KHwplQzuivo&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
#55 (permalink) | |
GR8 SCAPE
My wire is stranded. It is much more flexible than solid core, has no "memory", so it's easier to run through the car. I used computer/telephone grade shielded wire, 20/3C grade. I started with 3 separate wires and it was a DISASTER!! Don't do it.Go to a computer store, MicroCenter or something, and get the cable there. It'll make your life a lot easier. Regards, Wayne
#56 (permalink) |
2/3 hp to the paws.
There's really no reason to run three wires into the car for an RPM pickup. Just run the tach signal wire from the pickup and pick the power and ground up from the ECU harness, or rig up a relay for switched power right off the battery.
I use the same pickup for my RaceLogic traction. I would be amazed if you powered it from the radio supply and didn't get some pretty crazy noise as a result. |
#57 (permalink) | |
Thanks in advance!
#58 (permalink) |
Thanks for the replies gents. I suppose I could find ignition and ground somewhere in the engine compartment. I just intended to do it neatly all from one source. Hadn't thought about the noise issue. I DO use my stereo.
#59 (permalink) | |
2/3 hp to the paws.
I run the MSD pickup, my intercooler fan and associated relays, and a few other things from that line. Works great. |
#60 (permalink) |
Exige Cup 255
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
Sorry for the late reply, I just wanted to reiterate, so that you can continue with your integration project.
1 - I tapped the same RPM wire using Wayne's diagram. Though more old school, cut and splice. 2 - My calibration on my Cup car is also 0.5, took me awhile to figure out, was worried if I had the wrong RPM wire. But eventually, I realize that the calibration figure somewhat varies. I now have a bit more experience, after having gone though this installation setup in a few different makes and models. So far, I'm unlucky, every setup has bond to have some installation issue (getting wrong wires or using wrong calibration). But eventually, I did manage to figure everything out. |
