#61 (permalink) |
Finished the install tonight. All is well since using the MSD pickup. This project took too long. What I thought would be the hard part was easy. The part that I thought would be straightforward gave me the most grief.
![]() I'll post final install pics tomorrow. ![]() Thanks for all the helpful suggestions and encouragement, JP
'06 Elise - Laser Blue, LSS, TP, TC, Starshield. Mods: Stage 2, LETSLA, Manly MM, Exige Seats, Bollocks, De-Snorkeled, Viper's AC Mod, Alpine PDX/JL Stealthbox, 35% Tint, Color Matched Tunnel/AC Surround, Switchblade Fob. To Do List: Mesh, S/C (Someday) A twirling visual overload, explosions of terror and beauty. Colors of fear and pain within clash into unanything. |
#62 (permalink) | |
Hydrocarbons Rule
and the weekend and the MSD pick up to come in the mail.
#63 (permalink) |
Finally done! I am very pleased with the results. Here's the pics:
#64 (permalink) |
GR8 SCAPE
Hi Jonathon,
Very nicely done! ![]() Looks a lot cleaner than I would have imagined. ![]() Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
#65 (permalink) |
jpryor27... that's a very impressive install!
![]() For reference, you can install without the pickup. You can download fitment details for both the S1 and S2 from the website... S1 Fitment Guide S2 Fitment Guide |
#66 (permalink) |
Morning Gents
I must admit the double angle of the S2 binnacle did cause a few problems with embedding! The fit into the S1 is nice as there is a steady curve along the top and I covered it in black Alcantra anyway to cover up the plastic work. from a technical angle, it is best if all the lenses are exposed! The unit cannot be wired to operate upside down as the LEDs are on the board though I will chat to the designer later to check if it is is possible with software only. From your picture have you considered raising the unit a few mm, then creating a new flat section in front of the Shift-i? this could then be covered with Alcantra (which also has the benefit of being non-reflective and hides any scratches on the binnacle). This would expose the lenses but not leave any gap underneath the unit. ![]() Gary Suffling (gaz) Spitfire Engineering |
#67 (permalink) |
Meow!!
Hmm. You might consider taping off the top of the shift display and spraying the rear with a couple light coats of (subtle) semi-gloss black crinkle paint to match the finish of the binnacle... it would also hide the screws / connector...
Then a very small bead of black caulking to make it look seamless... ![]() Should be able to find paint like that at a hobby shop... Just a thought... ![]() Looks awesome - I'm jealous! ![]()
