06 Elise, Blue/Tan
Nitrogen tire pressures
My left rear got lose on me recently at the track and I could really feel it in a long high speed sweeping right turn. I got off the track, checked the pressure and had a reading of 40. The tire was at 28 cold and returned to about 30 in 15 minutes.
I have another track event this weekend and am going to use nitrogen. My tires are the stock AD07s. What pressure should I run with nitrogen for both front and rear? |
You don't need to use nitrogen. You just need to set the cold temps such that they will reach the appropriate operating temperature when hot and do a couple of easier laps to get them there.
Checker or Wrecker!!! We're all here because we're not all there. |
#4 (permalink) | |
06 Elise, Blue/Tan
I have run nitrogen with good success on my track cars back when I used to club race and be into this more. The pressue with nitrogen can still fluctuate a little, but no more than maybe 2 pounds. I can deal with 2 pounds, but 12 pounds on the left rear while the right rear went up only 4 degree to 32 is not good. The car felt pretty good when the rears were between 30 and 32. Should I run 28, 29, or 30 if my target hot temp is 30 with the ADO7s and such low starting tire pressures. |
registered nipple
from my experience, you should use air, AND a pyrometer, the probe type.
check the temps across the surface of the tire, and make the surfacetemp of the tire even by setting air pressures to do so. if your tracking w/o a pyrometer, your not going to be able to set pressures correctly. i tried to do so w/o, and with.............. night and day difference in ease and tires performance. Fish
2008-2009 SCCA AZ Regional "Driver of the Year" 1986 Swift DB-1 Sold 2008 HSR-West FF 3rd generation Champion 2008 "The Series" FF 3rd generation Champion 1987 Porsche Spec 944 2008-2009 season SCCA AZ regional Champion |
06 Elise, Blue/Tan
Fish:
Thanks. I may be using air again soon enough. I am switching suspensions, wheels and tires before my next event October 28 - 30. I just need to get another weekend out of these AD07s and, after 3 track events with air and a lose rear end when really hot, I want to try nitrogen. It may be a waste of a few dollars, but I don't care. I know it probably ain't necessary and . . ., but having a lose rear due to a hot tire is less fun. I am really just looking for: (1) advise about tire pressures for these AD07s; and (2) how much expansion I can expect with nitrogen with AD07s and starting at such a low pressure to begin with. Does anyone else agree that the AD07s seem best at about 30 to 32 hot. |
#8 (permalink) |
registered nipple
doug, i think whether you use nitrogen or oxygen, you still need a pyrometer. my experience was even 1/2 lbs psi made a BIG difference in contact patch. if you dont know how to use the pyrometer, PM me and I will tell you how I used mine . it was , for me at least, impossible to set the tires correctly w/o it.
fish
#9 (permalink) | |
Laughin' Easy
Unless your air supply is full of water, there's no way you see this much difference between air and nitrogen. |
#10 (permalink) | |
Air v. Nitrogen
Russ Newton Elite (Type 14, 1962) Elan+2S (Type 50, 1971) |
#11 (permalink) | |
06 Elise, Blue/Tan
I candidly have no stake whatsoever in whether nitrogen will alleviate those high readings so I will let you guys know how it went. Out of all of these posts, only one recommended pressures and those seem a little off to me. I was seriously not trying to debate the merits of nitrogen, nor do I care to change any one's mind about nitrogen. A post relating to pressures (hot or cold) would have been helpful. Fish: Got one. Kind of know how to use it as Dad uses it for club racing. I am seriously not that worried about 1/2 to 1 psi. My skills are not at that level. I am trying to avoid wild fluctations and keep them in the hot ranges I listed above. If I can stay within those ranges this weekend, I will be happy. Car is on the trailer and I am off . . . |
#12 (permalink) | |
Laughin' Easy
#13 (permalink) | |
McLareghini Bugatterrari
xtn
#14 (permalink) | |
Laughin' Easy
To be fair, I have seen liquid water come out of gas station air pumps. |
#15 (permalink) | |
I typically run 21/24 F/R cold (mid-summer) and it doesn't screw up anything. A bit mushy for the first couple of turns but after a lap or two they are up to temp and pressure.
#16 (permalink) |
06 Elise, Blue/Tan
Just got back. Will post video tomorrow. Nitrogen seemed to work well. I started out at 26 and 29 cold. My rears stayed between 31 and 32.5. Fronts stayed around 27 to 29. Temps were hotter on inside of outside rear tire and it seemed to get a little lose after about 15 laps. I dropped the outside rear to 27.5 or so cold and it stayed around 30 to 30.5 hot. 30 on the outside tire seemed about PERFECT for these tires on this track which is a fairly fast and demanding track, Gateway.
BTW: My "coach" as he refers to himself had nitrogen in his compressor this weekend. He has been racing professionally for over 30 years and seemed really adament about using it even in his toy hot rod 69 911 with slicks. Anyone going to Fort Worth this weekend for the Lotus track event? |
#17 (permalink) |
registered nipple
Not trying to be rude, but, If you have a "coach" who has been racing for 30 years, dont ask us(the internet), go with what he says.......... he has to know his stuff. AND if he is there at the track, what more can you ask for.
have fun and be safe
#18 (permalink) | |
06 Elise, Blue/Tan
#19 (permalink) |
registered nipple
take the front shims out, and just dial the car in with the pyrometer. i always write everything down. it makes adjustments much easier. the tires dont do well when run w/ incorrect pressures for a long period of time.
I would usually start out at 24 front/ 26 rear here in AZ, and adjust from there. it will be different per track, time of day/year, and driving styles. enjoy. Fish
#20 (permalink) | ||
short angry bloke
http://www.elisetalk.com/forums/showthread.php?t=28089 http://www.elisetalk.com/forums/showthread.php?t=28771 Quote:
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. |
