Ohlins settings - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 07-13-2009, 05:47 AM Thread Starter
Ohlins settings
Just installed Ohlins on my elise. There is such a wide range of settings, what is the best place to start. Just starting to track my car as much as I can. Most of if not all of the track time will be at Sebring so I need to keep that in mind when setting the suspension, I am also running Hoosier A-6's. For a fairly new track guy, how important is corner balancing.
fuqua914 is offline
post #2 of 10 (permalink) Old 07-13-2009, 06:33 AM
Zinhead's Avatar
The instructions for my Ohlins call for Rebounds of 12 clicks and compression of 1 click for the track. For street, they recommend 18 clicks for rebound and 12 clicks for compression. The rebound adjusted is on the shock, and the compression is on the reservoir. These settings have worked fairly well.
Alignment and corner balancing is critical with these cars. Get a track alignment and have it corner balanced with passenger weights in the car and a half tank of gas. Also, if you are running Hoosiers, make sure you have a track brace for your toe links.
Zinhead is offline
post #3 of 10 (permalink) Old 07-13-2009, 07:48 AM
Are those clicks from the softest setting or the firmest setting?
06 LSS, LSD, TC, Touring
http://exit3.i-55.com/~brian/lotus/avatar.JPG
Currently building a Lotus 7 replica.
http://www.lotustalk.com/forums/f178...4/#post1077592
Harponian is offline
post #4 of 10 (permalink) Old 07-13-2009, 08:39 AM
Bender Unit's Avatar
Those are the setting Ohlins recommand on the their manual which they think its best for Street or Track
Track - Rebounds 12 clicks , Compression 1 click
Street - Rebounds 18 clicks , Compression 12 clicks
I have a stupid question thou.
What's the Compression adjustment for ?
I only had single adjustible (Rebounds) coilover before, never use a set with compression adjustible.
Thanks
Bender Unit is offline
post #5 of 10 (permalink) Old 07-13-2009, 08:54 AM Thread Starter
Zinhead, Thanks alot that is just what I was looking for. I do have the RTD brace on my toe links.
fuqua914 is offline
post #6 of 10 (permalink) Old 07-13-2009, 09:18 AM
Simba's Avatar
The latter.
Simba is offline
post #7 of 10 (permalink) Old 07-13-2009, 11:04 AM
Zinhead's Avatar
Originally Posted by Simba View Post
The latter.
The manual recommends turning them fully clockwise to turn them to the hardest setting, then counting clicks in counter-clockwise to the recommended settings.
Zinhead is offline
post #8 of 10 (permalink) Old 07-13-2009, 11:16 AM
Zinhead's Avatar
Thanks
Compression is how the shock reacts to initial input (upward force) of a bump. Rebound is how it adjusts back to a normal state (downward force).
Zinhead is offline
post #9 of 10 (permalink) Old 07-13-2009, 09:08 PM
dleogml's Avatar
It's vary...
Ohlins settings
Exige Cup 240 - Ohlins Dampers ' ' ' '
Recommended Settings - Road ' ' ' '
Front Damper Full Hard Full Soft
Bump P11 P1 (Clockwise) P22 (Anti-Clockwise)
Rebound P8 P1 (Clockwise) P60 (Anti-Clockwise)
Rear Damper
Bump P15 P1 (Clockwise) P22 (Anti-Clockwise)
Rebound P15 P1 (Clockwise) P60 (Anti-Clockwise)
Front Anti Roll Bar P3 P1 P5
Rear Damper
Bump P10 P1 (Clockwise) P22 (Anti-Clockwise)
Rebound P12 P1 (Clockwise) P60 (Anti-Clockwise)
Exige Cup - Ohlins Dampers ' ' ' '
Bump P7 P1 (Clockwise) P22 (Anti-Clockwise)
Rebound P5 P1 (Clockwise) P60 (Anti-Clockwise)
Rear Damper
Bump P4 P1 (Clockwise) P22 (Anti-Clockwise)
Rebound P19 P1 (Clockwise) P60 (Anti-Clockwise)
Bump P6 P1 (Clockwise) P22 (Anti-Clockwise)
Rebound P3 P1 (Clockwise) P60 (Anti-Clockwise)
Rear Damper
Rebound P17 P1 (Clockwise) P60 (Anti-Clockwise)
[edit]Track Settings
Benchmark Settings - Donington Park ' ' '
Rear Damper
Bump P2 P1 (Clockwise) P22 (Anti-Clockwise)
Rebound P4 P1 (Clockwise) P60 (Anti-Clockwise)
Front Anti Roll Bar P2 P1 P5
Benchmark Settings - Rockingham ' ' '
Rear Damper
Benchmark Settings -Snetterton ' ' '
Rear Damper
Benchmark Settings -Cadwell Park ' ' '
Rear Damper
Benchmark Settings -Spa Francorchaps ' ' '
Rebound P2 P1 (Clockwise) P60 (Anti-Clockwise)
Rear Damper
Front Anti Roll Bar P1 P1 P5
2010 Evora 2+2 / Solar Yellow / Sports Package / Tech Package / Luxury Package / Lotus sports exhaust with titan tip / OE type K&N filter / Larini De-cat -----------------keep tuning-----
dleogml is offline
post #10 of 10 (permalink) Old 07-31-2009, 09:28 AM
Shadow_iX's Avatar
Thanks
Kenny McGormick / MSN: nad_freak@hotmail.com / "Slightly Unmodified" '02 Ellise S2
URL: LotusTalk-Thread
Shadow_iX is offline
Human Verification
