Old 09-27-2009, 06:38 PM   #1 (permalink)
Mods are good for you
Dave's Avatar
Rear stock panel exhaust exit w/ bumperettes
I'm not much for the looks of the rear panel eliminators, so decided to figure out a way to modify the stock panel of my '08 S240 to install an Arqray Ti.
While the bumperettes are not very attractive and likely useless in a fender bender, I still wanted to keep a stock look (without reverting back to an '05/06 panel.) I did a custom exit on my '05 Elise which required only some minor fab of the heat shield and right rear panel. Unfortunately, the bumpers extend further out from the center, so a standard hanging exhaust tip would not clear. The tip needed to exit 2+ inches further right, so I decided to shift the exhaust. Doing so went beyond the reach of the driver side hangar, so I picked up a 7/16" stainless tube at the hardware store. I heated the tube with a torch and tapped it on the hangar, extending it about 4 inches.
To extend the exhaust pipe, I just bought a $3 2 1/2" ID/OD adapter and clamp from Autozone.
Used a Dremel on the rear panel to cut the exhaust hole exit, then trimmed with black edge molding. The tip extends well beyond the rear clam so I'm not expecting any exhaust heat issues. I'm pretty happy with the way it turned out and it was a fairly simple 4hr project.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 09-27-2009, 06:39 PM   #2 (permalink)
Dave's Avatar
Almost done...
Old 09-27-2009, 06:42 PM   #3 (permalink)
Wizard of Pugz!
qball's Avatar
Images: 3
Very nicely done!
qball is offline   Reply With Quote
Old 09-27-2009, 06:42 PM   #4 (permalink)
really light stuff
Thomasio's Avatar
Looks good.
07 SY Exige S
Old 09-27-2009, 07:29 PM   #5 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
Nice work! I would've liked to keep a more stock look also, but the ReVerie diffuser won't fit properly with the bumperettes. I'm still thinking that a black mesh (like the Exige hatch mesh) might look a little more OEM than just a panel eliminator, without trapping any heat.
Old 09-27-2009, 07:59 PM   #6 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
good work my friend. Those darn bumperetttes don't leave much room for creativity!!!
Below diffuser exhaust is for the birds
Old 09-27-2009, 08:04 PM   #7 (permalink)
really light stuff
Thomasio's Avatar
What did you use to line the hole in the panel? I've seen door edging used successfully.
07 SY Exige S
Old 09-27-2009, 08:21 PM   #8 (permalink)
Project Nirvana Elise
shinoo's Avatar
That is a clean look. Good work.
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
Old 09-27-2009, 08:50 PM   #9 (permalink)
Meow!!
darkSol's Avatar
Nicely done Dave!
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 09-28-2009, 04:56 AM   #10 (permalink)
Dave's Avatar
Compliments appreciated Thomas, I picked that up from a buddy that owns a body shop...think he gets from TrimCo
