Reinforcing Front Clam
My wife dinged the lower lip a few weeks ago, so I'm going to be pulling the clam off to get it patched.
While it's off, I'm considering adding a layer or two of a carbon/kevlar weave on the inside of the clam to give it more strength. I've read the "uberclam" post, so I know others have tried this. The shop I talked to advised against this though. Their thinking is that if you hit something, you're much better off with the cosmetic damage being down low. They figured that there was too much risk that the reinforcement would just transfer the force of the impact further up the clam where it would crack in a highly visible area. Any opinions or experiences with this? |
McLareghini Bugatterrari
Sounds like good reasoning to me.
I mean you could make the front clam out of 1/2 inch thick plate steel. Even so, if you hit something at 10mph, if the clam doesn't deform, whatever it's mounted to will. xtn
Really Light Stuff
![]() Join Date: Jul 2003
I agree, it will break at the weakest link... reinforcing the lower portion will guarantee breakage elsewhere.
Thomas
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel .. To Order .. RLS Product Links .. |
#5 (permalink) | |
#7 (permalink) | |
-30-
[SIZE="2"]2007 Exige S, Storm Ti. Sport, Track and TC.[/SIZE][SIZE="1"]Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons.[/SIZE] [SIZE="4"][/SIZE] [SIZE="1"]08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C[/SIZE] [URL="http://www.lotustalk.com/forums/search.php"]The Red Pill[/URL] :wave: [URL="http://www.lotustalk.com/forums/profile.php?do=addlist&userlist=ignore&u=5868"]Ignore Me[/URL] :up: [SIZE="1"]*Be sure too save your IL before browsing away[/SIZE] Last edited by ace10 : 05-30-2007 at 09:13 AM. |
#8 (permalink) |
I'm planning to have truck bed liner (Line-X or Rhino Liner) sprayed on the bottom and just rolled over the lip. Hopefully this will handle scrapes ok.
It's the clam's ability to take a 1/2 mph bump into a parking berm or speed bump that I'd like to improve. It seems to me that the flexing in a bump is so localized that the fiberglass just yields. If the flex could be distributed over a larger area, then maybe the glass could survive intact. |
#9 (permalink) |
What we do know, is that if you centerpunch a cone at 60mph, it will damage the clam. What we also know is, it will not damage mine.
![]() The rest is just gut feel. The front of my car is extremely tough. Like if you bonded a surfboard to the front of the car. My point is that if you hit something hard enough to transfer enough force to cause some area behind that to crack, it would have caused major damage to the very front anyway. What my uberclam does... is transfer the load of a hit to a much larger and stronger area. I really can't see how this would be a bad thing. The stock clam has some weak points, specially around the license plate plinth. I have removed those weak points. The stock clam has some areas subject to being a source of scraping, the winglets and the plinth again. I have removed those areas.
Please do not PM me. My box is full. Thanks. |
