Old 02-08-2009, 08:13 PM   #1 (permalink)
Side Vent Mesh Solution
I have been working with TurboPhil on a different mesh solution for the side vents. The different look really compliments the lines of the car. the mesh used is very close (small diamond) to the mesh used on the exige. The front of TurboPhil's car matches perfectly.
These are direct fit replacement and will fit on standard elise and clam hinge modified elise cars. TurboPhil has a set on his (his car in the pix).
I make these 2 sets at a time and could make more if enough interest. Price $150+your old side vents. Instructions on mounting will be included. The original hardware is used.
Let me know what you think. Any comments/questions appreciated!
Derek
Trouble uploading pix, should have them up before Monday, Sorry!
dgilmore is offline   Reply With Quote
Old 02-08-2009, 08:38 PM   #2 (permalink)
madden's Avatar
how do you remove the stock vents?
madden is offline   Reply With Quote
Old 02-08-2009, 09:22 PM   #3 (permalink)
madden's Avatar
i think he is just talking about the side scoops, check turbophils log thread there are pics in there
Old 02-08-2009, 10:16 PM   #4 (permalink)
GG #668
biscoradio's Avatar
Images: 2
I'm interested. Hopefully the mesh is similar to kiowapilot's (see interior/exterior board).
biscoradio is offline   Reply With Quote
Old 02-09-2009, 03:05 AM   #5 (permalink)
shadowhusky's Avatar
Here are a few of the pics from another thread.
As for removing the vent,there are two bolts to get the vents off. One very easy to get to bolt if you have Phils clam kit.
Tjis was how I was originally going to do my side vents, but I changed m mind.
2005 Elise, Aubergine, Touring Pack, Sport Pack, Hardtop, Quicksilver Exhaust, Cup Air Box, Tilting Clam, Mesh Grills all around - ( fabricated, not purchased ) 55w 6000k HID's, Painted Engine Covers, Center Console, A/C Surround, Polished Shifter Arm, Ball,and E-Brake Handle, Multivex Mirrors.
2008 Jeep Liberty, Jeep Green Metallic
2002 VW Jetta TDI, Metallic Blue, Daily Driver, 155,000 miles and going strong
shadowhusky is offline   Reply With Quote
Old 02-09-2009, 05:20 AM   #6 (permalink)
POSITIVE!
newman's Avatar
looks really cool!
2008 Aspen White Exige S240: CF splitter|CF wing|CF diffuser|CF side scoops|CF mirrors|Arquay Titanium|Von-hep delete|Saikou Michi catch can|Cup car airbox|6000K HIDs|Custom short shift|Stan+sector111+ctn shifter mods|vinyl wrapped floorboards|Flat black AC surround & center gusset|Tow hooks|Bootie|Led park & plate lights|Smoked front sidemarkers|DRL delete|Hella Supertones|JVC KDAVX44 head unit|Boyo 420t back up cam. PICS
E30GTR Build... too slow... http://www.onyxsyndicate.com/newman
newman is offline   Reply With Quote
Old 02-09-2009, 05:22 AM   #7 (permalink)
Mods are good for you
Dave's Avatar
You can reach the vents by jacking and pulling the wheel wells.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 02-09-2009, 05:32 AM   #8 (permalink)
Sports Cars
Vampyre's Avatar
That looks great... very interested in these
2006 Chili Red / Touring / LSD / TC / Forged Wheels / Hard & Soft Top / Lifestyle Paint / Desnorkeled / Odyssey Battery / Sector 111 Extinguisher Bracket / Sector 111 LidBone / CF Splitter / CF Bits / Lotus Stage 2 / Pure X
C3 Corvette 383 TPI Stroker 6.3 liters of Torque / 1976 MG Midget, fun run about / 2005 Mits Evo 8 ACD/SSL / Dodge Van for hauling stuff / http://www.photobucket.com/mygarage
Vampyre is offline   Reply With Quote
Old 02-09-2009, 05:46 AM   #9 (permalink)
I was able to load a few pix of Phil's car.
These are plastic pieces (actuall original pieces) so they aren't powder coated. The mesh is plastic coated from a local store. I usually paint them flat black or I can use semi-gloss, gloss. I send them put together and ready to install. I could also not attach the mesh so if anyone would like to have them painted to match the body color. But there are black extensions still on the car that might stand out more.
Clam hinge cars: one bolt that attaches pointed towards the front of the car and two slots the vents slide into.
Non Hinged: best way is like Dave said, remove the rear wheel and wheel arch liner. Then are TWO bolts (I believe 10mm): one towards the front (same as above) and one pointed towards the outter fender. Remove these, slide out the old, slide in the new and reattach the bolts.
Shadowhusky's idea is great and will work for hinged. this will work for non hinged or someone that doesn't want to attach to mesh permanently to the car.
The vents can be taken back to stock should the need arise and can be purchased through Lotus Garage.
Yes, it's $150 for both Right and Left vent + your old vents. I pay for shipping to you and you ship the old vents back.
Dave, Yours are looking good and are being shipped out today at lunch. I'll have a tracking number for you this evening. Thanks!
Hope this helps.
Derek
Old 02-09-2009, 06:20 AM   #10 (permalink)
EliseAtLeast's Avatar
Will this fit a 07 Exige S? What is the main purpose for it? More airflow to the engine bay or mainly for looks? Thanks.
'08 Honda S2000 CR (Rio Yellow Pearl)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'04 BMW 330 ci (White)
EliseAtLeast is offline   Reply With Quote
Old 02-09-2009, 07:26 AM   #11 (permalink)
I don't know if these will work on an Exige. I think the main concern would be how the side scoops attach to the body. If there is a bolt/clip into the body panel, then you would have a hole that would need to be filled and painted.
I wouldn't expect an increase in air flow to the engine, especially when compared to the side scoops.
Mainly the prupose is looks and trying to get rid of the vent design.
Derek
P.S. I have exige scoops on my elise with the hole drilled in the body panel, so I probably won't be using these on my car. Just saw an opportunity make a great looking car look even better.
Old 02-09-2009, 07:52 AM   #12 (permalink)
Big head man
slaughtr's Avatar
Images: 3
I keep looking for a solution to get rid of all my "fins" at the same time, with the same material. Any plans for that?
My car both sucks and blows.
Now with added all natural smoky goodness!
slaughtr is offline   Reply With Quote
Old 02-09-2009, 09:40 AM   #13 (permalink)
They look great - good job
They won't fit an Exige as the set up is slightly different. Unless you cut the clam a bit Also - you'd have 3 holes left in the car as the side scoops currently need 3 screws into the clam to hold them in place.
X7LDA is online now   Reply With Quote
Old 02-09-2009, 10:27 AM   #14 (permalink)
Thanks for the reply. They do look great by the way
Old 02-09-2009, 10:49 AM   #15 (permalink)
Every Car is a Project
sleeprfocus's Avatar
I've done this mod on my car a while back and I definitely prefer the cleaner lines over the Exige side scoops. SCC was the first to do this mod, basically involves cutting the factory Elise side scoops, removing the fins, and replacing it with mesh.
2005 Lotus Elise (Jet Blue Metallic) - ForcedFed 340
2002 Ford Focus SVT (Pitch Black) - Powered by 4.6L of V8 goodness
sleeprfocus is offline   Reply With Quote
Old 02-13-2009, 02:22 PM   #16 (permalink)
Lotus Wannabe
Greenstreak's Avatar
Much cleaner then the originals. Very clean and smooth looking. I never really liked the fins.
2000 MR2 Spyder(s)
Greenstreak is offline   Reply With Quote
Old 02-13-2009, 02:30 PM   #17 (permalink)
sleepe's Avatar
Pictures of the inside?
Do you have pictures of where the mesh attaches to the plastic from the inside of the duct?
Where do you get your mesh?
Finally, You might consider offering a complete set that replaces all the fins with the SAME mesh.
-robert
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
Old 02-13-2009, 03:23 PM   #18 (permalink)
Is it only me or anyone else thinks this is a bit TOO EXPENSIVE for a couple mesh grilles?
Love the look though! Nice work
lutterfer is offline   Reply With Quote
Old 02-13-2009, 03:28 PM   #19 (permalink)
madden's Avatar
I'm working on doing the same thing to my vents and it is a ton of work to smooth them then fill the top fin gaps, $150 is a good price
Old 02-13-2009, 07:39 PM   #20 (permalink)
Stone Age Gamer
Likuid's Avatar
Yes please ... these look real good.
- Likuid
Stone Age Gamer - Store
2005 Ardent Red Elise
Likuid is offline   Reply With Quote
