Old 12-10-2008, 10:59 AM   #1 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
Wink Is there a "fat passenger" fault code?
so I picked up my friend from the airport yesterday(he is ~210lbs) and shoved his backpack into the trunk...
after one second gear pull(the IC was super heat soaked from sitting at a traffic light) I think I wash hitting limiter at ~6k
I took him up the mountain later and while not as fast as my typical trips I did manage to give him adrenaline sickness (and he rides super bikes and has an early 90s civic with a K swap thats faster(straight line) than my 240) tho once in the cooler air the car was back to its usual self... I might need to jump on the RLS group buy and get a decat
He has a really nice camera that records HD video and a HUGE memory card so I am gonna try to get a video of the hill "commute"
Dude, there's my car!
Monsi is offline   Reply With Quote
Old 12-10-2008, 11:09 AM   #2 (permalink)
High Roller
JUNGLISTluder's Avatar
Images: 6
i'm pretty sure the limiter is only 6k until the car is warm. once up to temp, it should always rev to 8k. Even when heat soaked.
96 Ferrari F355 Berlinetta
06 Lotus Elise Supercharged - SOLD
88 BMW 528is
JUNGLISTluder is offline   Reply With Quote
Old 12-10-2008, 11:10 AM   #3 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
the car had been running for about an hour so I am fairly certain it was up to temp
the second gear pull I did went all the way out to 8
after that it wouldn't tho, I'm thinking maybe the knock sensor tripped and it went into limp mode?
Old 12-10-2008, 11:22 AM   #4 (permalink)
OSX Black hat
charliex's Avatar
could be a cam problem, might want to look into it, especially if there is no code.
Old 12-10-2008, 11:29 AM   #5 (permalink)
2005 Ardent Red, Touring
Combined max weight limit of passengers & cargo is 500lbs , when you have a heavy passenger you will notice a big difference in performance and even cornering - 210lbs = - 21 HP . Did you have the car off for a while waiting at the airport ? They actually cool off pretty quickly. I drove and hour up to a weekend canyon run, had a quick 30 minute breakfast and as I pulled out to start the drive I floored it up a hill. The car hesitated a bit and was hitting the limiter and I was confused as hell. Then noticed I was not at temp yet ...... after a few minutes of driving all was good
"You can run over an insect and know just from the messages coming through the wheel how many legs it had. Was it a beetle? Was it a spider? Hang on......... spider." Jeremy Clarkson - Top Gear
delise is offline   Reply With Quote
Old 12-10-2008, 11:35 AM   #6 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
he was waiting for me at the airport... car was at like 206 when I did the pull
Charlie... define cam problem, as in there is a solenoid issue switching the cams?
later last night while in the cooler mountain air the car was pulling hard as ever and I could perceive the switch... granted if you floored it right at 4k it would hesitate a bit(less than a second) but I think thats cause of the engine coping with TP change AND cam change
Old 12-10-2008, 11:39 AM   #7 (permalink)
perfututum futūtor
RoadDad's Avatar
Here's a start:
http://www.lotustalk.com/forums/f3/t...-engine-40743/
Camshaft cover defect causing rocker-arm breakage (P1302)? - LotusTalk - The Lotus Cars Community
What's Your Cam Status?
Code 1302 & 1301 years and miles
Me... I don't need to.
Bite me." -Randy
Old 12-10-2008, 11:41 AM   #8 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
I have read PLEANTY on THAT cam problem... you think that will happen with only 1.5k miles on the engine???
Old 12-10-2008, 11:41 AM   #9 (permalink)
OSX Black hat
charliex's Avatar
i'd say its just something to note if it happens again, there are a couple of issues that cause the light to flicker, but if it limits the engine as well and does not throw a code or having one pending, then more often than not its a problem with the cam switching, that itself has a couple of different problems, but again if no code its generally something mechanical with the cam itself, the lifters usually.
however i wouldn't worry too much, i'd just keep an eye on it and see if it happens again, or if you feel substantial power loss, there has been a few reports of phantom 6k limiters.
Old 12-10-2008, 11:45 AM   #10 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
engine check light never came on (the fat passenger thing was a joke)
if the car detected alot of knock would it throw a code?
Old 12-10-2008, 11:46 AM   #11 (permalink)
OSX Black hat
charliex's Avatar
right so its engine limit with no code/light , so thats why i mention it might be a cam issue.
it does for excessive knock yes.
Old 12-10-2008, 11:49 AM   #12 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
wrapped out third this morning coming into work everything felt good... will keep an eye on it thanks
Old 12-10-2008, 04:03 PM   #13 (permalink)
wantanelise's Avatar
210 is fat? ouch, thats tough...
wantanelise is offline   Reply With Quote
Old 12-10-2008, 04:37 PM   #14 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
haha well its kind of an inside joke... he used to be a swimmer and all cut and now he is pretty pudgy... I'm not exactly Mr. fitness either but I am about 30lbs lighter... so with the both of us the exige was huffing and puffing
Old 12-10-2008, 05:33 PM   #15 (permalink)
It's probably just the electrical going stupid, I've had my air not working once, another two times or so the rev limiter was on at 6k... just turn the car off, and turn it back on again - problem goes away
Wasabi is offline   Reply With Quote
Old 12-11-2008, 12:26 AM   #16 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
turned on and off many times...
tonight in third gear by myself if I floored it it would pull till 6k then sputter for a few seconds and then pull to 8
if it was a cam problem wouldn't it be kicking in at 4.2k with my foot all the way down?
Old 12-11-2008, 01:28 AM   #17 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
All kidding aside, there's no "weight limit"... you just get progressively slower as you add weight... I'm around 200 pounds, and my best friend is around 255 pounds... (he doesn't really fit well in the Exige seat). The engine revved normally, although it was noticeably more sluggish than with only me in the car.
If you notice a substantial change in power/smoothness at 6k rpm... there's a good chance you've got a problem somewhere...
Old 12-11-2008, 01:44 AM   #18 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
I had problems with no one but myself in the car
Old 12-11-2008, 03:22 AM   #19 (permalink)
Live to Drive
Bavarian Motorist's Avatar
It sputtered at around 6k? Can you elaborate? Did the throttle cut?
Old 12-11-2008, 10:27 AM   #20 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
it sounds kinda like rev limiter just kinda gurgles and sticks at almost exactly 6k
but it only does it when it feels like it... it did it last night but not this morning
again by myself
