Old 02-20-2008, 09:26 PM   #181 (permalink)
CLR
chuck_risen's Avatar
Location: I live in Glen Ellyn IL, a suburb of Chicago.
I love the idea and it looks like you put a lot of good hard work and thought into it. I just can't give up my rear panel. I like it too much. With it off I feel like my car has a big hole in it's pants and you can see its "package". Any way you might have an option for those of us that do not mind removing the rear panel? As in a kit that does not include all of the hardware for eliminating the rear panel?
chuck_risen is offline   Reply With Quote
Old 02-20-2008, 09:32 PM   #182 (permalink)
I ain't Yella'
muttpep's Avatar
Sounds like you need a secondary Mod that would allow the rear panel to swing out for tilitng.......
WARNING: Objects in mirror are bigger than your Elise!
2005 SY Elise. Sport Pack, Touring Pack, Beverly Hills Lotus "Stage II" exhaust, Venture industries starshield.
muttpep is offline   Reply With Quote
Old 02-20-2008, 09:39 PM   #183 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
It will work with the rear panel. Again, it won't be quite as slick, but still slick. I'll include instructions for keeping the panel in place.
Operators are standing by
Best,
Phil
| '05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 275whp/175wtq | EFI Standalone Engine Management |
See my car at BOE Fabrication: www.boefabrication.com ----->Last Updated: 11/09/08
If something ain't worth doing right, it ain't worth doing at all...
Old 02-21-2008, 12:54 AM   #184 (permalink)
Mountain Road Nut
ChrisH's Avatar
Hey Gang-
I hope that covers most of the details. Thanks again for the support and let me know if you have any questions.
It seems like this would be a good time to make a video of the full process of opening and closing the clam with your kit.
Also, a few pictures to make a few things clearer to everyone:
1) Rear panel issue: Which bolts would be permanently eliminated, and which would remain in place and have to be removed and replaced to tilt the clam.
2) Slight trimming of the interior rollbar cover: a trimmed picture, and an untrimmed picture.
One thing you mentioned earlier in the thread, but not in your last big post, was something about the lifting the weatherstripping a bit for the top along the rollbar cover, and people's concern about water leakage. Can you give more information on how that was done and the potential for leakage? (With pictures if possible.)
Old 02-21-2008, 10:28 AM   #185 (permalink)
XPRMTL
perryeyges's Avatar
Phil,
These would go nicely on both sides of the clam behind the side vents. I could inset them as well. Just unlatch and open, about 10 seconds..YES!
The other alternative would be aluminum old style hood pins that protrude through the clam just to the rear of the door on the top of the rear 1/4 ledge. Much cheaper and easier to install
05 Elise Spyder II, Chrome Orange, 1586lbs. Stasis/Alcon "lotus cut" brakes, Supercharged and Intercooled @305 Crank HP
"My dream car is now operational!"
perryeyges is offline   Reply With Quote
Old 02-21-2008, 05:40 PM   #186 (permalink)
XPRMTL
perryeyges's Avatar
Phil check out this crude attempt at a clam hinge by MTM on the Esthi. They just drilled a hole at the bottom of the fender liner support structure. OUCH! Looks heavy. I think they were lying about the weight of the car @2,100lbs..
Old 02-21-2008, 05:52 PM   #187 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Ya, they had to trim the roll bar cover on that car as well for it to clear. Fiberglass is sacred to me It's darn difficult, if not impossible to clear the roll bar with a conventional pivot hinge like they used (or the others I've seen). Even with my hinge, it's tight. The clam really has to go UP like ours does before it pivots back...or have a pivot point about 6 feet behind the car... The latter would just look goofy
I think your latch system will work, but it's a bit more extreme than I'm going to go with the body of my car. More power to you though. Are your going to french in those latches like the car in your post?
Best,
Phil
Old 02-27-2008, 04:14 PM   #188 (permalink)
XPRMTL
perryeyges's Avatar
I decided to go with these instead. Plan to mount them about 6-8" aft of the passenger compartment on either side of the "C" Pillars on top of the rear 1/4's. Chop, chop, cut, cut....
Old 02-27-2008, 04:32 PM   #189 (permalink)
tvacc's Avatar
Originally Posted by perryeyges View Post
I decided to go with these instead. Plan to mount them about 6-8" aft of the passenger compartment on either side of the "C" Pillars on top of the clam. Chop, chop, cut, cut....
Where did you get those latches. I need a set for the Elan I am doing.
Edit...yeah...right there in front of me. 034 Motorsport
Tony Vaccaro
2005 Ardent Red, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield.
www.lotusowners.com
LOONY (Lotus Owners of New York) and the Church of the Holy Lotus
Supplier of the Polycarbonate Shield for Rear Window and Sachs Coil Over Suspension
Drive Fast Take Chances
tvacc is online now   Reply With Quote
Old 02-27-2008, 04:49 PM   #190 (permalink)
XPRMTL
perryeyges's Avatar
I saw these latches on the Catena and the 211 and was wondering where to get them and how they worked. A few days ago a customer stopped in with a set on his modded A4 C/F hood. They looked great. He told me the name "Aero catch" so I googled it and found a speed shop in Fremont, Ca. that stocked them. Fremont is local to me so I ordered 2 sets to play with.
034 Motorsport tel#(510)657-6707
www.034motorsport.com
Old 02-27-2008, 04:52 PM   #191 (permalink)
tvacc's Avatar
I am fairly sure you know what a 71 Elan looks like...right?
I need new latches for the hood. Currently has those stupid pins that stick up with sliding latches. Lots of room below hood. Do you know which ones would work best for me?
Tony Vaccaro
www.lotusowners.com
Old 02-27-2008, 05:47 PM   #192 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
GREAT FIND PERRY. I'm going to order one of those for my boot lid. I currently use a hood pin since I did away with the factory lock), but this would oh so much more interesting!
Thanks, Phil
Old 02-28-2008, 08:03 AM   #193 (permalink)
XPRMTL
perryeyges's Avatar
I thought the looked pretty trick but had no idea how they worked when I saw these photos.
Old 03-03-2008, 09:13 AM   #194 (permalink)
2zz parts scattered about
MaineLotus's Avatar
How are the hinges going? Please finish this project ASAP, I have another idea you need to work on... (Hint: it works in conjuction with your hinged rear clam)
My car is modified.
MaineLotus is online now   Reply With Quote
Old 03-03-2008, 09:17 AM   #195 (permalink)
knucklehead's Avatar
Lambo doors?
Jacob
Join Lotuscar.ning.com for LA Lotus social events
05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels
knucklehead is online now   Reply With Quote
Old 03-03-2008, 09:32 AM   #196 (permalink)
MaineLotus's Avatar
Ha ha, no! A mod that I think is long overdue... And Phil has the technical expertise and creativity to pull this off.
My car is modified.
Old 03-03-2008, 09:54 AM   #197 (permalink)
Baysailor's Avatar
Quick release latches for the hardtop?
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Odyssey PC625, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, 6000k 35w HID kit, Moroso Oil Pan, Plinthless front clam, Team Dynamics Pro Race 1.2 Wheels w/ RE01-R's for street use, Heater Core By-Pass, Shifter Reinforcement
Baysailor is offline   Reply With Quote
Old 03-03-2008, 09:57 AM   #198 (permalink)
sfelise's Avatar
That would be cool!
But don't do anything to slow down the tilting clam, any updates?
Eric Jennings
2005 Elise
2004 S4 Avant
1995 M3 (RIP)
sfelise is offline   Reply With Quote
Old 03-03-2008, 10:20 AM   #199 (permalink)
MaineLotus's Avatar
Bingo! The OEM system is poorly executed. It bugs me everytime I remove and replace the top - cheap and flimsy. I have some ideas, similiar to a bicycle skewer, but I think Phil could improve on this. Besides, I don't have a fab shop in my garage!
My car is modified.
Old 03-13-2008, 07:36 AM   #200 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Quick Update
Hey All,
I want to apologize for the delay in updates and getting kits out. The demand was high enough for these kits that we've had to farm out some of the fabricating. While "my guys" are normally very fast, they got a bit back logged, which put a wrinkle in our timeline. Current status is that we should have our farmed out parts "anyday". Then we just need to powder coat and they'll be out the door...
Since I know you're concerned about me still finding time to enjoy my car, I've been enjoying driving Liz in our great spring weather the past several days and using my clamhinge quite frequently to gain access to the ECU and wiring to add more sensors to my Dash2 project.
Cheers,
Phil
PS- Maine- Drop me a PM about your idea
PSS- Perry, have you rec'd those locks yet? I'm going to order one today for the boot lid, I do believe
HTML code is On
