#41 (permalink) |
hinged rear clam
I have a 05 Elise and would buy a clam kit from you....would really help in the turbo install.
05 Elise, (sold )2002 BMW 330ci convertable, M package 1998 Range Rover (stolen) 1972 BMW 2002 supercharged, fuel injected, liquid intercooled, Haltech E6A ECU...and lots of other stuff 1988 BMW 535Is |
#43 (permalink) |
not just turbo install but work/maintance in general! Sure it helps you install that turbo kit/ or supercharger, but also a good way to maintain it or fix on the go! I definately would want one of these! My dream car (F40) is out of reach, yet this would be the next best thing!
#44 (permalink) |
Elise...Best Daily Driver
Have not seen a tilting clam since Germany. Phil very happy to see you working on it. Count me in on the purchase when you are ready.
2005 Elise, Starlight Black/Red, Modified tilting clam, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and Cup Wheels & Tires. |
#46 (permalink) |
That is not possible in the standard configuration. You really need a two piece clam for that to work; but a cool doable idea with some creativity.
#47 (permalink) |
McLareghini Bugatterrari
Here is me wondering if it will work the same for an Exige?
#49 (permalink) |
Plug Whisperer
I don't see why not...just have to take the hard top off first...I've got the service manual for both. Mounting hardware appears to be similar so you're in luck
![]() ... ........ Still a little ways off. Need to get the last bits ironed out before it's ready for the DIYer. Atleast the first hard part is behind us (first of two)... One more to go, then the rest should fall into place nicely... Best, Phil
#50 (permalink) |
Will this require that the car be lifted off the ground? It would be extremely useful to have the ability to open the clam with the car sitting on the ground.
Thanks for taking the time to develop this. ken
All torque, no traction...Exige S. Real sports cars don't have A/C! |
#51 (permalink) |
Sports Photographer
Swweeeeet! And when you market this thing you can get some new tires from the profit as those are shot! <grin>
Looks really nice and love the color. ![]()
2005 Elise Ardent Red/Black LSS, TP, HT, Knoxville, TN. Surrounded by: Deal's Gap (318 curves in 11 miles) Cherohala Skyway (45miles of sweeping mountain curves) Devil's Triangle (Deal's Gap but with more attitude) ...and of course, the Great Smokey Mountains Parks! Welcome to Elise Country |
#52 (permalink) | |
JabStrongFierce
the tilt is totally awesome, great work plenty of people here will want it
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning |
#53 (permalink) | |
Plug Whisperer
![]() Reagrding the tires, as Kaz said, they're just now ready to run ![]() To clear up a couple questions I've been getting: -The diffuser was removed for ease of the fabrication, but it doesn't need to come off for the tilt. -The car was jacked up for same reason as above... -We'll be making a special rear panel eliminator that will tie into the frame rails rather than clam. The idea is that within a couple minutes, I can go from driving the car to tilting the clam up with no special tools, floor jack, or 4 letter words. So far so good ![]() Best, Phil
#56 (permalink) |
Phil, if you don't mind:
1. Do you have to remove the hinges for the clam lid before? If so, how do you access the bolts? 2. What happens with the weatherseal for the top? Do you peel it off each time and then re-adhere it? 3. Do you have to remove the gas door trim screws? 4. I assume you still have to remove the fasteners to the diffuser on the lower outside points? 5. Do you still use the bolts inside the boot to the frame to attach (where the shims are)? 6. Do you then no longer have to have access to the inner bolts where you now have to remove the back trim panel and seats? 7. Do you have to lengthen the harness to the rear tail lights?
#57 (permalink) | |
Plug Whisperer
Qood questions: See below...
Hope that helps, Phil
#58 (permalink) |
Plug Whisperer
Correct.
#59 (permalink) | |
06 S280
Even with the rear hatch vs the lid? I'll be honest, I can't really recall how the elise's lid is attached, only seen it once.
#60 (permalink) |
Excellent answers Phil. Leaves me though with two more questions.
1. How Much? 2. When? ![]() p.s. Interesting idea on slitting the weatherstripping. I like it.
