Old 01-15-2008, 05:04 PM   #1 (permalink)
Hello Kitty's Avatar
Tricking your car into reverse gear
A trick I learned a while ago, works on the lotus too. Sometimes you can't get into reverse, or first gear at a stoplight. The stick goes halfway in gear, and if you let out the clutch, the gears grind. Ever happen to you?
The trick is to go into second gear, which is always easy. This aligns the syncros, and then you can effortlessly go into first, or reverse.
enjoy
Hello Kitty is offline   Reply With Quote
Old 01-15-2008, 05:09 PM   #2 (permalink)
Resident Drunk
zygotesoup's Avatar
good tip... took me a a lot of slamming it into gear when i first started driving to learn this valuable trick
1993 Black BMW 325i
2000 Solar Yellow MR-S - SOLD
1987 White on White Porsche 944 Turbo - SOLD
1993 Maroon Lexus SC400 - SOLD
Next Car - Elise, Exige, Exige S... CO, KG, AW???? Too many choices!!!
zygotesoup is offline   Reply With Quote
Old 01-15-2008, 05:58 PM   #3 (permalink)
It's how you use it
MikeSage's Avatar
I've had this problem before in my MINI. I would always move into neutral, let out on the clutch and try it again.
Thanks much for the advice!
'04 Indi Blue MINI Cooper S JCW
MikeSage is offline   Reply With Quote
Old 01-15-2008, 06:10 PM   #4 (permalink)
Derriere Extraordinaire
Z-dculus's Avatar
or just let the car roll a half inch
2006 KG-Sport Pack, LSD, TC, SS, Multivex, Lotus Stage II/powercoated diffuser, CF Zoom Rear View, Sector LidBone, Darth Holder (thanks Kestrel!), Sector 4Tress Harness Bar/CRD Mount, couple exige trim pieces
2004 Nissan 350z - Super Black-too many mods to list-SOLD to my brother
1978 Chevrolet Caprice Classic -(daily driver)
*Seasoned veteran member of the KG Mafia
Z-dculus is offline   Reply With Quote
Old 01-15-2008, 06:16 PM   #5 (permalink)
Aye I do the same, put it neutral, let the clutch out, put it back in and try shifting again
Wasabi is offline   Reply With Quote
Old 01-15-2008, 07:18 PM   #6 (permalink)
Lotus Junkie
BrendanDolan's Avatar
I do the clutch out and in and then try again. Reason being clutching out in neutral spins the gearbox, and then selecting first uses the synchro to engage the gears. If you've been sitting with the clutch in, sometimes the gears don't line up just right.
Don't do this for reverse though. Reverse doesn't have a synchro, and you will get a nice little crunch out of the gearbox if you slide the shifter to reverse while the internals are still spinning.
Brendan Dolan
Former Internet Sales Manager
Boardwalk Lotus
Out of sales, and working my passion in aviation
BrendanDolan is offline   Reply With Quote
Old 01-15-2008, 07:29 PM   #7 (permalink)
mikecronis's Avatar
Images: 1
To get into Reverse, try going into first gear beforehand.
To get into first gear, try going into second gear beforehand.
Check your linkage.
mikecronis is offline   Reply With Quote
HTML code is On
