| View Poll Results: Should Lotus have a Recall for the Toe-Links? | |||
| Yes - Before someone gets killed |
85 | 57.82% |
| No - a Recall is overkill |
51 | 34.69% |
3 | 2.04% |
8 | 5.44% |
| Voters: 147. You may not vote on this poll | |||
#41 (permalink) |
What's a registered user?
I also suggest sending a note to Lotus as well.
http://www.grouplotus.com/contact/ge....php?section=1 |
#42 (permalink) | |
![]() Babak Club111 Central Plains Coordinator '05 Elise - Touring, HT, StarShield '99 Ducati 996 Bip '05 Freelander SE |
#44 (permalink) | |
http://www.elisetalk.com/forums/showthread.php?t=23291 |
#45 (permalink) |
Can't believe you guys are asking for a recall. It's a roadgoing car and lotus states that they can understand if you take it to track occasionally (not timed runs!!). In normal circumstances problems won't happen. In the one occassion it does, I'm sure Lotus will uphold warrenty.
If you're planning to track the car more often, spend some extra dollars on getting the brace (I did).
Nico MY07 Exige S British GT243 #032 MY04 Silver Subaru Legacy 2.5L Wagon MY92 Sunburst Yellow Miata (traded for a MY09 Yellow Opel GT) |
#46 (permalink) | |
TWRD & Blip advertising
I understand Tim's view about the negative effects of the brace and appreciate him pointing out the other side of the coin when most are reacting (with emotions at times) to the situation. Maybe the "recall" offer is giving the owners the choice and explaining the pros and cons of the brace. And if the brace is still wanted that it is offered at cost with free installation. The thinking is that the car if originally equipped would have cost this amount more. Lotus doesn't loose much money. And we as owners are offered a choice at an affordable solution. Jacob |
#48 (permalink) | |
A Heim joint is mounted in double shear, so it would not rotate (at least not as much) about it's mounting point. There would be no (or at least less) bending of the threaded portion - this would cause more of the load to be transfered to the chassis, possibly damaging the chassis. Note also, in that photo, the tie rod link ball joint is intact - it's mounting bolt (the one the fails that passes through the a-arm bushing) is intact. The joint is twisted, but the "bold" is still securely attached to the chassis. Additionally, it appears that the Heim joint is "sealed" (which is a good thing), but the Heim joint would have a smaller bearing surface than the ball joint, so I would still expect it to wear out sooner than a ball joint. How much sooner, I have no idea...
#49 (permalink) |
Probably Lurking
I didn't realize the problem was occurring on mild-use cars with stock tires when I voted. This seems like a serious issue to me. I thought it was just an issue with a loose nut that we needed to check. It seems to me now that if it has come loose, it's reasonable to suspect the integrity of the link. How do I change my vote?
#50 (permalink) | |
I moved your vote for you. |
#52 (permalink) |
Mountain Road Nut
[QUOTE=MyElise] [http://www.elisetalk.com/forums/atta...6&d=1148492437 /QUOTE]
Well, I like a certain amount of Lotus cheeleadering. However, the one you showed is, well, ugly. Can't we find a prettier cheerleader? She/he should be in the proper Lotus chearleading outfit, of course. |
#54 (permalink) |
Fortunately I have not had that part break yet, but had the two bolts that keep the hub carrier on the rear suspension completely sheer off.
Everything is still completely stock on the car and has been driven very gently... Thankfully I was traveling at a slow speed at the time on the freeway, so damage was pretty minimal, it would have been another story if I were traveling at speed. I have over 21,000 happy miles on my Elise now, which may have something to do with not finding a similar problem on this site yet? Last edited by macsuibhne; 12-12-2006 at 10:41 PM. |
#55 (permalink) | |
I can run very fast
#57 (permalink) | |
Seriously, it's been quite a while since this problem first appeared. There have not been massive numbers of failures on cars. In fact, I have not heard of any problems for quite some time, other than those that changed to the brace complaining about the short life time of the heim joints. As I've always said, if you are tracking your car, or have stickier than normal tires, you may need the brace. If you are using your car on the street, you probably do not need the brace and may be better off without one.
#58 (permalink) |
Out of perhaps 3000 cars sold in the US how many have failed? How many have failed on cars that were not tracked? How many have failed on cars that were tracked only with A048's? We need statistics to make an educated decision. Even Lotus might not know how many were running stickier tires if owners swapped their wheels back before the car went to the dealer.
#59 (permalink) | |
#60 (permalink) |
i have scanned through these threads but haven't seen a picture of the exact culprit? what exactly are they to be torqued to? maybe someone can PM this info to me?
bourdeaux elise SOLD 2008 toyota yaris hatch...71 volkswagen type 2 with 79 hydraulic type IV 2.0/dual 40 idf webers! faster than a single speed bicycle oh yeah...i apologize in advance to the weak... |
| Thread Tools | |
| Display Modes | |
