engine overheating after wash and long sit - LotusTalk - The Lotus Cars Community
post #1 of 6 (permalink) Old 08-21-2011, 10:56 AM Thread Starter
OK, so my car has been parked in the garage for a couple of months now awaiting a new tune and a couple other small things. It recently had its turbo replaced and engine inspected but nothing real major.
I decided to pull it out today and give it a good wash as well as limp it around the block once just to see if anything was leaking (which was one of the initial problems). Well after washing it and hopping in it about halfway around my block the temperature starting shooting up FAST. By the time I was 200 yards or so from my garage it had jumped up to 225-226 and was flashing. I immediately turned it off once I was able to pull in and, after lifting the engine cover, noticed that it smelled like something was burning.
Other things to note is that it is currently about 100 degrees outside and the car was sitting under direct sunlight for the 30 or so minutes it took me to wash it. In addition, I probably got some water in the engine area...I'm not sure if that is a big deal.
Would the car sitting for a long time + being out in the sun potentially cause this? Should I be concerned about the burning smell? Thanks.
2006 ST Exige - GT-28RS, Darton sleeved/decked/line-honed, ARP hardware, Wiseco 8.8:1 pistons, MWR valves/springs/retainers, RC injectors, Walbro pump, CWorx oil pump, Moroso oil pan, S111 TrackMounts, Spearco intercooler, GReddy catch-can, Turbosmart BOV, Fidanza clutch/flywheel CF Panels/scoops, S111 Rear Diffuser/Rear-Panel Delete/discNOIR Brakes w/SS lines/RTDbrace/Towhook, APR CF Splitter Alpine unit w/MBQuart, CF binnacle/shifter, Schroth harness, S111 shift brace (Sold)
bpfergu is offline
post #2 of 6 (permalink) Old 08-21-2011, 07:57 PM Thread Starter
By the way...this has NEVER happened. The highest I've ever seen the car was 205 for a split second, and that was in stop an go traffic when it was 105 outside.
Could it sitting in a garage for 6 weeks really cause this? Or is it something that the shop potentially did?
bpfergu is offline
post #3 of 6 (permalink) Old 08-30-2011, 01:13 PM
Elise Driver
Was the radiator fan running?
Was it driven much after the turbo install?
Matt @ Monkeywrench
2010 Evora Test Mule - Turbo Intercooled Daily Driver
2005 Elise V6 / E153 340hp NA, 415hp Supercharged
2005 Elise Turbo 450whp / E153
2001 Toyota Celica 2ZZ Turbo 950 crank hp, 200+ mph
2001 Toyota MR2 Spyder 500+hp, 10's
http://www.monkeywrenchracing.com/
Monkeywrench is offline
post #4 of 6 (permalink) Old 08-30-2011, 09:24 PM
Puff Daddy
Bane's Avatar
Sounds like something the shop did.
If you have a water cooled turbo, they may have failed to bleed the coolant properly after replacing it.
Bane is offline
post #5 of 6 (permalink) Old 08-30-2011, 09:50 PM
lt0302's Avatar
check
fluid levels
fan working ie coming on
thermostat could be stuck closed - do you use watter wetter?
05 Lotus Elise TVS, Stage II, OBX header, Moroso Oil Pan, RTD Brace, PRoAlloy Aluminum Radiator, SS Break Lines, S111 Oil Catch Can, ACT HDC, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, , S111 front & rear tow hooks, tail lights-LED, Driving lights, LETSLA, CF interior, 2lbs SS shifter knob, 2010 Exige Spoiler, Lotus shop Seats, RA clam, Light Flywheel, ATI pulley, 2010 Exige Cup mirrors
lt0302 is offline
post #6 of 6 (permalink) Old 11-04-2011, 07:23 AM Thread Starter
Raising this thread from the dead as I'm hoping to solve this issue soon and get the car back on the road.
I'm not real sure if the radiator fan was running. Is there an easy way to check beyond getting out of the car and looking? Honestly, once I saw that the car was overheating I went straight back home and parked the car.
My reflash is set up so that my intercooler fans will continue to run until the car drops below a certain temperature, even after the car is shut off, and they ran for like 30 minutes after the car was turned off.
After talking to the shop, the said they drained some of the coolant out when replacing the turbo, so it seems like an air pocket forming in the lines is what is most likely. I tried topping off the reservoir (as it was a bit low) after the engine cooled down, but do you think that any air pockets are still going to be in there?
Originally Posted by lt0302 View Post
fluid levels
I'm not real sure what a watter wetter is, so I'm leaning towards no? haha
bpfergu is offline
Human Verification
