Custom oil cooler setup questions/suggestions - LotusTalk - The Lotus Cars Community
Old 07-31-2010, 09:19 AM   #1 (permalink)
Driver for hire
Conan's Avatar
Images: 24
I've wanted to put my own oil cooler solution in for a while now. I did one for my 944spec car and was really happy with the setup and results. I find the stock oil cooler setup in the Elise to be fairly poor in design:
  • Long lines add avoidable weight
  • More stress and power is required the further the oil has to travel
  • Oil pressure is harder to maintain with longer lines
  • too much old oil remains in the system during an oil change (unless you purge the entire system which is too difficult for weekend warriors like myself)
  • Repairing potential leaks/breaks is excessively difficult
After reading Rob's thread, I'm motivated to go through with a custom setup, although I'll go with a air cooler versus a water cooler because it's just easier.
So my question is, where do I put the cooler? I'm thinking one of three spots: 1) Driver's side air intake (see pic); 2) Passenger's side air scoop intake (see pic); 3) Above the naca ducts near the bottom-front of the engine bay. I think I've seen at least one implementation using one of these. Any suggestions or experience would be greatly appreciated.
Fast in, fast out.
2012 Audi S4, 2007 Honda Odyssey (the wife's), gone: 2006 Elise
Conan is offline   Reply With Quote
Old 07-31-2010, 09:43 AM   #2 (permalink)
too easy!
txdude's Avatar
I suggest the passenger side scoop due to the fact that it appears some/most F/I setups I've seen utilize the driver's side intake scoops. Whatever route you take, post pics because you caught my interest on this.
txdude is offline   Reply With Quote
Old 07-31-2010, 09:45 AM   #3 (permalink)
lt0302's Avatar
passanger side
I am working on mine and i will be putting it on the passanger side with a small electric fan for heavy traffic....sort of an just in case thing......I bought the kit from a fellow lotustalk member who is parting out his car.
05 Lotus Elise VF2 to TVS, MWR Fuel Rail, Stage II exhaust w/ Larini Decat, Moroso Oil Pan, RTD Brace, PRoAlloy Aluminum Radiator, SS Break Lines, S111 Oil Catch Can, ACT HDC, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, S111 front & rear tow hooks, tail lights-LED, Driving lights, LETSLA, Cup holder center console and painted ac surround, 2lbs SS shifter knob, 2010 Exige Spoiler, Lotus shop Seats, RA clam upgrade
lt0302 is online now   Reply With Quote
Old 07-14-2011, 05:30 AM   #4 (permalink)
[Pē]'s Avatar
Did anyone end up doing this project? I'm interested in what size oil cooler will fit in the passenger side pod.
[Pē] is offline   Reply With Quote
Old 07-14-2011, 05:47 AM   #5 (permalink)
jwb4bb's Avatar
I saw one of these setups on turbophils car yesterday at the track. I was very interested for the above reasons listed in the OP. I wasn't thinking, but I should have taken a pic. His was located on the drivers side. I didn't think to ask him why he decided to put it there vs the passenger. From what I could tell it looked like the stock oil cooler bolted to a custom fabbed bracket. The cooler was positioned after the air intake at about a 45deg angle very close to the rear drivers wheel well. He also had slits cut into the wheel well to allow air to escape more easily.
Now I'm really kicking myself for not taking pictures.
jwb4bb is offline   Reply With Quote
Old 07-15-2011, 02:09 PM   #6 (permalink)
jwb4bb's Avatar
Pics!
Old 03-02-2012, 11:58 AM   #7 (permalink)
Carbon Fiber
FistHammer's Avatar
Images: 181
This thread needed dug up! This one is about 2 times the size I got... I might order this one. Thread owner, do you have a part number??
FistHammer is offline   Reply With Quote
Old 03-22-2012, 09:42 AM   #8 (permalink)
Any more pics or info from those who have done a rear mounted air to oil cooler?
Toledo Cars and Coffee
https://www.facebook.com/pages/Toled...74943495860461
pistolpete is offline   Reply With Quote
Old 03-22-2012, 09:48 AM   #9 (permalink)
I'll snap some of mine in a few days (week maybe?) once I complete it.
Also going to go to the driver side scoop. That way I can keep the passenger side scoop available for other things later on down the road (BOE's heat exchangers come to mind).
440bhp E85 2006 Solar Yellow Elise.
The way it should have been delivered from the factory with Honda Power!
WhatsADSM is offline   Reply With Quote
Old 03-22-2012, 03:33 PM   #10 (permalink)
lotus_dp's Avatar
lotus_dp is offline   Reply With Quote
Old 03-22-2012, 03:55 PM   #11 (permalink)
Exiged's Avatar
Here is a sneak of my setup. Dual Setrab's one for the engine and one for the rotrex I'm installing. Idea borrowed from BOE's heat exchanger. You could stuff a big Setrab in there if you tried. Btw this thing is FIRMLY mounted.
Sent from my Autoguide iPhone app
DIY 2007 Exige S K20A2 C38 Rotrex
OneHotLap build thread
http://www.onehotlap.com/2012/07/lot...rned-into.html
http://www.onehotlap.com/2012/07/lot...d-into_11.html
Exiged is offline   Reply With Quote
Old 03-22-2012, 05:16 PM   #12 (permalink)
Carbon Fiber
FistHammer's Avatar
Images: 181
What is this "setrab"????
Old 03-22-2012, 05:36 PM   #13 (permalink)
Exiged's Avatar
Swedish company which makes high end oil coolers
Old 03-22-2012, 06:25 PM   #14 (permalink)
ZJChaser's Avatar
old photo but my oil cooler is still in the same spot.
ZJChaser is offline   Reply With Quote
Old 03-22-2012, 06:46 PM   #15 (permalink)
Exiged's Avatar
Nicely done on the aluminum bending. And the whole car as well!! I have some goodies to do the same type of front splitter but I am a little gun shy on cutting up the front clam
Old 05-18-2012, 11:14 AM   #16 (permalink)
Here is what I did. I got the parts from Phil at BOE and had Pure Tuning put it in. I added foam under it and an aluminum panel on the side to better force air through the cooler.
Stock cooling system still in car as I'm wait to see what Lotus does for the recall.
Pic during install:
Old 05-25-2012, 09:08 AM   #17 (permalink)
^ At what point would a fan be needed for a smaller oil cooler setup? In follow up to that; what would be the best practice for wiring the fan activation - manual switch/custom timer?
slightly2ned is offline   Reply With Quote
Old 05-25-2012, 09:52 AM   #18 (permalink)
I don't have the experience to answer that, but those who know will likely want to know if this is a track or street car.
Many "in the know" believe the car would be fine on the street with no oil cooler at all.
Old 05-25-2012, 09:56 AM   #19 (permalink)
qz5gxt's Avatar
I had gone the new NCI lines that are very well made and no issues. But If I had to do again I would have gone the rear remote oil cooler for my track Elise
BOE REV400TVS,Nikasil SB, Arias pistons, NGK 02, Difflow 5, Fidanza V2 Clutch/Flywheel, MONOballs, Ultradisc, Carotech XP10 XP12 pads, BOE Tilt Clam, BOE Catch can,TRACK mounts, Braille, Larini header/de Cat/BOE exhaust , AIM full Data, Nitron Doubles, V2arms, V2linx, RTVbrace, Profi II 6-Point, Tillett B6F race seats, V-Force Harness bar, Hoosier R6, Roto Torque wheels, GUT frt Spoiler, gPAN, mess grills, CF Exige Side, V2 gas tank and BOE fuel surge tank, ProRad radiator/Samco hoses.....
qz5gxt is offline   Reply With Quote
Old 05-25-2012, 11:39 AM   #20 (permalink)
Gamera -The Atomic Turtle
komiko's Avatar
just to beat the dead horse...my rear Setrab oil cooler installed by BOE, textbook oil cooler relocation...highly recomended if you can figure out how to do it, or get it done. I chose the "get it done". My ITG intake shares the drivers scoop with the oil cooler. But the wheel well liner is modified for more airflo. I've been trying to figure out if that is to help get heat out, or more cooling air in. Pretty cool. Just leave it to Phil and this kind of stuff is gonna happen. Don't let it scare you, it's called engineering
Lotus Elise #134 - June/2004 build date - BOE REV400 installed on stock motor w/stock cat/mani 336.4bhp, passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, etc. 0-60 = under 4 seconds.
Build thread :
http://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline   Reply With Quote
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Lubricating System
